Question about Toshiba GSC-R30 Camcorder
Helpppppppppppp llease i just purchased a toshiba gsc-r30 camcorder and when i go to play the files i recorded i get a codec error
Hi what error code you have>??? did you fix that>???? becaue I have a same camcorder and have same problem, I have a code003
Posted on Jul 01, 2008
Toshiba gigabit r30 oK button not working, remove hard drive
Can you just format or wipe the drive and reload from scratch? You may need another working machine with which to conduct the operation.
Sep 02, 2017 | NEC Toshiba Gigashot Gsc-R30 30Gb 2Mp Hard...
Have a GSC-R30 Toshiba camcorder, have had it for a few years. never used it to download my movies, although I installed the software on my old Windows XP computer. NOW, I just bought a new computer with...
I question your use of the word 'new' to describe a Win 7 computer, and with a camcorder that old, it will be impossible to find drivers for any OS later than XP.
Jun 03, 2017 | Toshiba GSC-R30 Camcorder
My gsc r3o quit working, battery is good but it will work as long as I have the dc adapter plugged in...I need to find a reliable repair shop...
if its work with the adater its should work
with the battery pack may try a new battery
if it not check the battery contact, some one comme
corroded very fast or broken if not
bring to your local repair shop its a singular problem...
Feb 09, 2010 | Toshiba GSC-R30 Camcorder
USB CABLE FOR TOSHIBA GSC R30
I would try Target and Best Buy, the cable is pretty standard.
Jul 02, 2009 | Toshiba GSC-R30 Camcorder
I recorded a video on my samsung sc-dc 164 camcorder and i used my SD memory card instead of the disc. when i try to play my video from the SD card recording it won't play but can only hear audio from my...
how did you transfer the video from the card to your PC?
did you connect the camcorder to your PC or did you use a memory card reader?
if you can play the audio then what you need is the right video codec for the unit
try searching for video codecs through search engines
make sure that the software that you are using to play the video plays the file format of your video,
try using roxio, then connect the camcorder to your computer via USB, make sure that the drivers are installed, play the video through your camcorder then use roxio to capture it real time instead of the usual "copy-paste"
Jun 28, 2009 | Samsung SC-DC164 DVD Camcorder
Av cable for GSC-R30
finally found the cable after much time searching, in a small mall across the big road from merry king mall close to china town in bangkok. cable is the same as a sony cable
Jul 20, 2008 | Toshiba GSC-R30 Camcorder
Toshiba GSC-R30 error code
I had the same problem the 003 error I formatted and reset it, then I turned the camera off and beat the top (where the little speaker is) with the palm of my hand. Turned it back on and the error was gone. May be the lense or hd gets jarred or something.Hope this helps
Jun 29, 2008 | Toshiba GSC-R30 Camcorder
Recording session stops itself
the camera has a anti drop protection and anti ground shooting try setting up at home inside first
Mar 07, 2007 | Toshiba GSC-R30 Camcorder
How do I play MPEG recordings?
Using Windows Media Player You need Microsoft Windows Media Player Version 9 or higher and Sharp G.726 Audio Codec in order to play MPEG4 files from the Memory Stick on your PC. If you are not currently using Microsoft Windows Media Player Version 9 or higher. Important: The Sharp G.726 Audio Codec needed to play MPEG4 files is no longer signed by Microsoft. If Sharp G.726 Audio Codec is not properly installed on your PC, it will not play MPEG4 Audio. Using DivX® You can also download a free DivX® Player and codec to play your MPEG and other video format files. DivX® for Windows is a free codec built to play every version of DivX content. The DivX codec also plugs into your existing video software so you can view and create high-quality DivX videos at a fraction of the original size. The DivX codec also adds DivX video playback support to most popular media players.
Sep 06, 2005 | Samsung DouCam VP-D5000i Mini DV Digital...
Open Questions:
My Hitachi VM H710A plays just fine, and the picture looks fine. But when it playsback footage or records footage, five to ten seconds later, it stops abruptly, and flashes the word "TAPE". First thing I must add, is that I was using a prerecorded videotape, and was testing it from the beginning of the cassette and the middle of the cassette. I thought maybe the heads were dirty, and so I cleaned them using a cotton swab and rubbing alcohol. I cleaned the head drum with a piece of paper soaked with rubbing alcohol so that I wouldn't get any fibres in the heads. I waited for it to dry and then I put a cleaning cassette inside. To which, it still stopped abruptly five to ten seconds in during playback. I then decided to look at the manual of the camcorder and see the symptom. It says that due to temperature changes that it might cause this symptom. I placed it in a cool room and left it there all day and checked on it, and the camcorder is still doing the same thing as before hand. Then another cause said that it might sense some moisture. I made sure that the camcorder was dry externally and internally, and yet still, same problem. Thats when I decided to take it apart and look inside to see if there was anything odd inside the camcorder causing it to function the way it does. The belt seemed to be working fine, and there was no missing parts. The tracking poles and path alignment was fine, and not loose. Everything simply seemed just fine. So I am unsure as to why my camcorder is operating like this.
Sep 17, 2018 | Hitachi Video Cameras
See all Toshiba GSC-R30 Camcorder Questions
Toshiba GSC-R30 Camcorder Logo
87 people viewed this question
Top Toshiba Video Cameras Experts
Marvin
Marvin
Voros101
Tom Chichester
Are you a Toshiba Video Camera Expert? Answer questions, earn points and help others
