Question about Whirlpool LER5636P Electric Dryer
I have ler862opwo its not heating but i checked element and dont beleive its out does it have a fuse inside the dryer
  • 80 Answers
Yes it does and you should get continuity through it... click to see part
Posted on Oct 08, 2009
The dryer dont heat
What is the make and model of your dryer?
Often a dryer heating element burns out, but doesn't trip the circuit breaker or blow a fuse. The heating element is simply a long coil of special wire. You can check it for continuity with an ohm meter. No continuity means the element is bad and you need to replace it--electric heating elements aren't repairable. On many dryers, there's a thermal fuse mounted to the exhaust duct inside the back cover panel. The fuse--which is about an inch long--is usually embedded in black resin and mounted in a white plastic housing. If the fuse has blown, you need to replace it. (You can't re-set it.)
Dec 28, 2010 | Kenmore Dryers
DRYER RUNS BUT NO HEAT BELEIVE IT TO BE HEATING ELEMENT
With the gas machine you won't actually have a heating element. What you will have is a burner assembly. There are a few common things that can cause a gas dryer to stop heating.
The dryers have a square cap on the front near the bottom. Remove this with a knife or small object. Looking through this hole you are face to face with the burner assembly. Turn the machine on, if after 10-15 seconds you see a glow and the flame starts, you probably have a bad set of coils. Coils can allow the dryer to start, but after the flame goes off, they have problems starting it again. So, when you come back and find damp laundry, it may actually be heating, just not very well. IF there is no glow when you look through the peep hole, keep reading.
The most common part is a thermal fuse. This fuse is located on the back of the dryer. Simply unplug the dryer, pull it out, and remove the back (Eight 1/4 screws). The fuse looks like this http://www.appliancepartscompany.com/xcart/images/D/3392519.JPG it will be on the lower left hand side. If you do not have a multimeter to check continuity you cannot be for sure. This is a cheap start to figuring out your problem.
If you have a multimeter simply check the two terminals where the wires were plugged in for continuity. It should read about .1. This fuse goes bad when it gets to hot. There are few reasons this happens, but the #1 reason is that the vent to the dryer is clogged in some form or fashion. Outside the house where the vent exits should have a strong air flow while the dryer is on. If it is clogged by any means, the hot air cannot escape the dryer and the fuse will blow.
Two of the other commonly replaced parts are inside the dryer, accessible from the front. These parts are the ignitor and the coils.
May 28, 2010 | Whirlpool LGR3624JQ Gas Dryer
My electric dryer runs but no heat.
Hello there:
There's no heat If your dryer doesn't heat, check these: Power from the house Check to see whether there's power getting to the dryer. Is it plugged in? Check for blown fuses or tripped circuit breakers--your dryer uses two fuses or circuit breakers. The dryer could tumble but not heat if only one of the two fuses is blown. If you have circuit breakers, one of the two circuit breakers can trip, even if the two for the dryer are connected. Heating element Often a dryer heating element burns out, but doesn't trip the circuit breaker or blow a fuse. The heating element is simply a long coil of special wire. You can check it for continuity with an ohm meter. No continuity means the element is bad and you need to replace it--electric heating elements aren't repairable. Thermal fuse On many dryers, there's a thermal fuse mounted to the exhaust duct inside the back cover panel. The fuse--which is about an inch long--is usually embedded in black resin and mounted in a white plastic housing. If the fuse has blown, you need to replace it. (You can't re-set it.) Wiring A common problem is for the main wiring connection from the house, at the dryer, to burn and break its connection. Because the dryer can still tumble with partial power, the connection may be only partially defective. You may need to replace both the power cord to the dryer and the terminal block inside the dryer that the wire is attached to.
I will post the pictures of the heating element in a seperate post
Best regards mike
May 27, 2010 | Amana NDE2335AY Electric Dryer
KENMORE GAS DRYER NOT HEATING UP
Hi
Thanks for using FixYa. No Heat issue in dryer is usually caused due to three things mainly: Thermal Fuse, Wiring Harness and/or Heating Element. Start with checking the Thermal Fuse which ismounted inside the back cover panel to the exhaust duct and is mounted in white plastic housing. If thats fine then the Heating Element should be checked. Please do revert for further assistance.
Thanks
Rylee
Apr 17, 2010 | Zanussi TC180W Electric Portable Dryer
My Whirlpool Ultimate Care II dryer does not heat up, however it does tumble. Any help would be greatly appreciated. Thanks.
There's no heat If your dryer doesn't heat, check these: Power from the house Heating element Thermal fuse Wiring Power from the house Check to see whether there's power getting to the dryer. Is it plugged in? Check for blown fuses or tripped circuit breakers--your dryer uses two fuses or circuit breakers. The dryer could tumble but not heat if only one of the two fuses is blown. If you have circuit breakers, one of the two circuit breakers can trip, even if the two for the dryer are connected. Heating element Often a dryer heating element burns out, but doesn't trip the circuit breaker or blow a fuse. The heating element is simply a long coil of special wire. You can check it for continuity with an ohm meter. No continuity means the element is bad and you need to replace it--electric heating elements aren't repairable. Thermal fuse On many dryers, there's a thermal fuse mounted to the exhaust duct inside the back cover panel. The fuse--which is about an inch long--is usually embedded in black resin and mounted in a white plastic housing. If the fuse has blown, you need to replace it. (You can't re-set it.) Wiring A common problem is for the main wiring connection from the house, at the dryer, to burn and break its connection. Because the dryer can still tumble with partial power, the connection may be only partially defective. You may need to replace both the power cord to the dryer and the terminal block inside the dryer that the wire is attached to.
Jan 02, 2010 | Whirlpool Dryers
No heat.... how do I locate the heating element
Jan 02, 2010 | Kenmore 700 6973 Dryer
Hello, my maytag neptune dryer runs, but will not dry. where do i find the serial # ?
There's no heat If your dryer doesn't heat, check these: Power from the house Heating element Thermal fuse Wiring Power from the house Check to see whether there's power getting to the dryer. Is it plugged in? Check for blown fuses or tripped circuit breakers--your dryer uses two fuses or circuit breakers. The dryer could tumble but not heat if only one of the two fuses is blown. If you have circuit breakers, one of the two circuit breakers can trip, even if the two for the dryer are connected. Heating element Often a dryer heating element burns out, but doesn't trip the circuit breaker or blow a fuse. The heating element is simply a long coil of special wire. You can check it for continuity with an ohm meter. No continuity means the element is bad and you need to replace it--electric heating elements aren't repairable. Thermal fuse On many dryers, there's a thermal fuse mounted to the exhaust duct inside the back cover panel. The fuse--which is about an inch long--is usually embedded in black resin and mounted in a white plastic housing. If the fuse has blown, you need to replace it. (You can't re-set it.) Wiring A common problem is for the main wiring connection from the house, at the dryer, to burn and break its connection. Because the dryer can still tumble with partial power, the connection may be only partially defective. You may need to replace both the power cord to the dryer and the terminal block inside the dryer that the wire is attached to. serial # should be inside door jamb!
Jan 01, 2010 | Maytag Dryers
I have a Whirlpool dryer Model # LGR7648K20 that just stopped heating. THE DRUM TURNS BUT IT WILL NOT HEAT.
Wiring A common problem is for the main wiring connection from the house, at the dryer, to burn and break its connection. Because the dryer can still tumble with partial power, the connection may be only partially defective. You may need to replace both the power cord to the dryer and the terminal block inside the dryer that the wire is attached to Good luck
Regards:
VOTIT
Dont forget to rate:
Jul 01, 2009 | Whirlpool Dryers
Not heating
Heating element
Thermal fuse
Wiring
May 20, 2009 | Dryers
Whirl Pool Dryer Model # LGR7646DQO
Wiring A common problem is for the main wiring connection from the house, at the dryer, to burn and break its connection. Because the dryer can still tumble with partial power, the connection may be only partially defective. You may need to replace both the power cord to the dryer and the terminal block inside the dryer that the wire is attached to. Hope that helps! Should you have any further questions, please feel free to post them here.
P.S. - If you find that the solution/answer I provided led you to, or resulted in a fix, please close the ticket with a FixYa! rating. I would be very grateful for your show of appreciation.
Thank you for using FIXYA!
Cheers!
IrishDruid
Sep 29, 2008 | Dryers
Whirlpool LER5636P Electric Dryer Logo
51 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
