I need to see how to wire it from thermostat to blower motor.
  • gussie doucet Oct 08, 2009
    Thanks, the system is at my fishing camp and is 112 miles away so I can only tell you what inforation that I have here. Its An Intertherm electric air and heat. On the blower it has mocel number 901282 Intertherm-multispeed `air circulator. Central electric furnace model no. FEH-015HA. The unit was working fine when we turned it off. With back 2 monts later and it would not come on automatically thru the thermostat. If I pushed the switch at the unit it worked, but didn't come on or off on its on. Called a service person and he broke it completely. Touched some wires together at the thermostat, they sparked and that was the end of it working. Had another person come out and he got it to running but not automatically. I am in the same place that I started. What I need to know is the wiring diagram to the blower. There is a blue wire not connected. I have purchased a new thermostat and Sat I will try to connect it. Thanks again
  • 334 Answers
First we need to know what type of system you have. Gas furnace, heat pump, etc. Then we need to know what color wires you have, then exactly what terminals you have on the back of the thermostat, and if it is battery operated.
Please understand this is obviously not your solution, but a request for more information so I can provide your solution. So if you could refrain from rating until we have answered your question it would be appreciated.
Posted on Oct 08, 2009
  • Danny Clark
    Danny Clark Oct 08, 2009
    OK With an electric furnace you probably have the following wires.
    red
    white
    green
    blue
    yellow
    The following color codes are industry typical but the rare unit can be wired differntly in the field.
    Yellow = AC condensor
    Blue = common
    Green = blower fan
    red = hot24V
    white = furnace
    The thermostat should have terminals similar to the following, but please nmot certain brands/models may vary.
    R
    W1/W2
    g
    y
    c
    You would wire the thermostat like this
    R = red wire (24V)
    W1 = white wire (furnace)
    G = green wire (blower motor)
    Y = Yellow wire (AC condensor)
    C = Blue wire (common)
    From what you stated above it sounds like the transformer was blown when the "sparks flew".
    The system will have to have 24V coming out of that transformer to work.
    If any of your situation is different or you require further assistance please let me know. Thank you for choosing FIXYA!
I installed a run capacitor for my blower motor on my RUUD ac model UGPH10EBRJR. now it runs all the time. I even disconnected my thermostat and it kept running. is it my thermostat? or something else
An open limit switch may make the fan run all the time. Try disconnecting the Green wire @ the furnace...if that does the trick, then either the thermostat fan relay is stuck, or there is a short between the Red & Green wires somewhere in the thermostat wire.
Jan 18, 2015 | Ruud Heating & Cooling
Main blower runs all of the time.
If you bypass tstat, meaning hot wired blower, does the blower cycle on and off by touching and removing red with fan?? If yes than obvious problem in tstat. I was leaning towards a bad relay but if you can make it work by passing tstat, there's you problem.
Jun 23, 2017 | Heating & Cooling
What causes insufficient air flow across evaporator coils
Dirty filters is number one, other blocked ducts.
Bad or slipping blower motor
Slipping belts , if you model has it/ them.
Jul 20, 2014 | Ruud RGTC07ERBGS N/A Achiever 75000 BTU...
Need to wire furnace blower
Gas valve should only have a couple of wires...24 Volt & common. the blower will use one speed on a gas furnace & a common. If you have AC or a fan switch on your thermostat, then the high speed will also be connected on the blower.
Dec 16, 2013 | Ruud Rheem Furnace Blower Motor...
Cannot get the heater to work
CHECK SEE IF HEATER BLOWER MOTOR WORKING, REMOVE HEATER BLOWER MOTOR HOT WIRE HEATER BLOWER MOTOR SEE IF BLOWER MOTOR WORKING BLOWER MOTOR FAULTY OR YOU HAVE FAULTY WIRING AT BLOWER MOTOR AND RESISTOR.
Nov 05, 2011 | 1996 Mercury Grand Marquis
Hello, im trying to install a booster fan to add more CFM to one room, my question is what is the best way to wire it up so it goes on and off with the furnaces blower motor? thnaks in advance
The "best" way would depend on you system's layout. If the booster fan is not too far away from the blower motor, you could drop pair of low voltage wires from the booster fan to the blower motor relay switch (coil side) along the duct. Connect the low voltage wires to a relay switch for the booster fan (again... coil side). This way, when the thermostat closes the circuit and engages the blower motor relay switch, it would also engage the booster fan relay switch; thus turning on the booster fan. If the booster fan is close to the thermostat, you would connect the low voltage wires to the thermostat instead. Either way, the wiring is essentially the same.
Aug 05, 2011 | Heating & Cooling
My empire heater wont turn off and just keeps blowing cold air. pilot is lit and all thermostat wires seem to be connected. any ideas?
Sounds like the thermostat for the blower motor (not the gas thermostat) has shorted. Remove front cover on stove. Follow the wires from the blower motor back to the blower thermostat. Replace with new one. Blower model # DRB-1.
Dec 04, 2010 | Empire DV-35 Heater
F8 heat low it goes up to 494 and stops there
It generally is the IR Element that has gone bad. Look for burned wiring where the IR Element enters the oven cavity. Check for continuity through the IR Element.
1. Check that the blower motor is moving air.
o Blower motor is not moving air: Check blower motor assembly
and verify motor is stalled. Unplug oven and correct obstruction or
replace motor. (For access to motor shaft, remove top panel.)
o Blower motor is moving air: Verify high-limit thermostat is
not tripped. See the high-limit thermostat information below.
High-Limit Thermostat:
o Thermostat tripped: Reset and determine why the thermostat
tripped (See Figure 38, Item 114). Look for excess build up of
grease inside the oven or any other source for a fire.
o Thermostat is not tripped: Check main convection heater.
1. Convection heater is defective: Unplug oven and replace the
convection heater and verify the K4 SSR (Figure 37) is not
shorted across output.
2. Convection heater OK: Check the K4 SSR.
o K4 defective: Unplug oven and replace.
o K4 OK: Unplug oven and verify all wiring. Verify P1 voltage on
I/O board is 5.0VDC (+/- 0.02) -
Aug 28, 2010 | TurboChef TORNADO Electric Oven
The blower will quit blowing
If this is aair handler/ Gas or Electric.
1) Shut power off
2) Remover blower door and locate blower motor
wires and then reconnect them. Restore power If
that does not cure them problem then:
1) Shut power off and remove blower door again, find
the thermostat wires and remove the wire from the
G-Terminal. Restore power if that cures the
problem, then you need to make sure the
thermostat wires are not touching either at the
thermostat or between furnace and thermostat.
If that does not work then:
2) It could be the high temperature limit that is
inserted into the unit above the burners usually.
If it is failing the switch opens up and the blower
will operate on its own.
3) Turn power off and locate this switch, put a jumper
wire or connect the two leads that go to this
switch, restore power, blower should not be
operating. The High limit switch is bad
Jun 22, 2010 | Goodman GMS90703BXA Heater
The fan in the airhandler wont shut off.
The fan is controlled by a blower timer board located inside the air handler, or on older units it has a relay called (of all things) a blower relay. If these items were at fault I doubt removing the thermostat would cause the blower to go off. if bad causing this problem the blower would continue to run even with thermostat removed.
But it is also controlled by the thermostat.
You mentioned that if you remove the thermostat it cuts off. There are 2 switches on most thermostats.
1 has Cool, Off, Heat, and Emergency Heat (on a heat pump stat)
2 The other switch has On and auto (it is for the fan motor only)
I believe because it stops when you remove the thermostat that the switch on the fan is set to on possibly. It should be on auto-matic. This way the fan motor only come on with cooling or heating. If in the on it stays on all the time. If this is the case just switch to AUTO.
Or the thermostat may be wired wrong. The G terminal is where the fan motor gets instructions from the thermostat. Make sure its on G at the stat and the correct wire at the blower coil is being used for the corresponding wire going from the stat to the blower for G. Don't confues G for green it could be any color. The terminals are not for color but it makes more sence to make them color - letter identified. On the other end soemtimes the wires are not colored the same so look carefully.
Also a whisker of a thermostat wire could be touching inside the thermostat and causeing the motor to run 100%. Look carefully at this and see if it has too long of thermostat wires stickinhg on out under the screws to where they may tough other things.
If neither things stop or show the problem and it deffinately stops when thermostat is removed the thermostat is most likely bad.
If this helps you 1 way to make the repairs your\self or helps you realize you need a technician please rate mne as high as you can.
May 14, 2009 | Heating & Cooling
Heating & Cooling Logo
63 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
