Question about Averatec 3200 Notebook
Mt cd drive doesnt play anything?
It was just working last time i used the cpu....now it doesnt play anything I put into the drive. I see a little black part on my copper colored piece that runs across the drive could that mean its bad?????? and my wireless internet doesnt work, i pick up signal but no internet
My p5kpl-am mobo doesnt power on,last time, i change the processor, its ok but then ii put the original processor i doesnt power on anymore, what is the problem, is there anything to fix it
Hi
Changing the CPU may have corrupted the BIOS.
Disconnect the power cable , then remove the small silver CMOS battery for 2 minutes to reset the BIOS memory of the change of CPU., the try to power up again.
I hope this helps.
Aug 29, 2011 | ASUS P5KPL-AM - Motherboard - micro ATX -...
I have a panasonic SA-PM19 cd player. Last night as I was putting in a cd it wasn't on the tray all the way, I gave it a little push (too hard of a push) and the cd fell off the tray inside the cd...
remove the cover, and carefully remove the CD that fell in, use EXTREME care not to force anything,, everything in those is plastic, the clicking is probably the tracking rubbing on the cd that fell off
Jun 01, 2011 | Audio Players & Recorders
Why is there gaps in the playing of you tube? this interuption have a few seconds apart.
update to the latest flash
if this doesnt fix your issue then your processes are using alot of CPU try to turn off any CD burning applications or anything that uses the CPU alot also if you want to see what exactly is using alot of CPU press Control Alt Delete and if it asks pick task manager, then click the processes tab and see whats using 100% system idle process is fine, also if you dont know the program thats using alot of CPU do a malware scan with a program like spybot or adaware
Mar 01, 2011 | YouTube Computers & Internet
When i put the cd in for the network adapter ...it just doesnt play.....i also tried attaching the adapter but it doesnt detect it....whats next?
If you have win 7 switch the pc on and at the same time press delete several times and a box comes up.press the down arrow until it comes to the cd drive click on this,press enter and save and exit f10.Now see if you can play the cd.If it plays fine if it doesn't try putting it in the other c drive (if you have two drives)Some of these cd's only work on the ROM drives or" Master" drive.You should 've had a piece of paper with the xbox that gives you a "command" prompt like,"set up.exe"
Sep 02, 2010 | Microsoft Wireless Network Adapter Xbox...
My burner won't play or burn anything
Try using a lens cleaner cd, if it still doesnt work try a firmware upgrade if available thru Dell website if the system is manufactured by Dell. If it still doesnt work then it is time to get new drive as there is no point fixing the old one as you can get a new drive for approximately the same cost of repairing it.
Aug 11, 2010 | Dell Computers & Internet
Having a problem with windows media player. I put in a cd and try to get it to rip and it comes back and tells me to put in a disc. I put a disc in to play and it tells me to put in a disc. It is like it...
Does it only happen in Windows media player? If it does try gettting the updated version of media player. if it happens in other applications try changing the dics. If that doesnt work, you need to delete the lower and upper filters in the registry *Note* if you are not really comfortable in doing that then dont, Wrong move in the registry can mess up the operating system, here is the link how to delete the lower and upper filters
http://support.microsoft.com/kb/314060
if these doesnt work uninstall then reinstall the driver for the optical drive..
try also getting an update from your computer manufacturer. update for the optical drive, or BIOS
lastly, try reinstalling the operating system, if these doesnt work change the optical drive because its a hardware issue..
Mar 07, 2010 | Computers & Internet
Not playing games
Well, this could be quite a few things.
1) Reformat your entire system
2) Could just be as easy as a dirty/cracked lazer lens. Take some canned air to it, if that doesnt work, there are cleaning products out there that look like a dvd, it will spin around and actually clean the lense for you. This is going to sound a little elementry, but if it's standing up, try laying it down. I had a PS2 that did the same thing if it was standing up, the second i laid it down it worked.
3) It could be an internal problem because since you bought a new disc drive, it could be the connector you plugged the drive into. Make sure it's not dirty or anything like that.
4) Trade it in and at least get some money off of it and buy the new XBOX 360 elite. Don't tell them it is having problems though.
Sep 17, 2009 | Microsoft Xbox 360 Console
Ok....my cd-rom drive is not reading the cd's?
first remove the cd and restart the computer and see if the E:driver if it is not let me know if it is there put the cd and try it again
Apr 14, 2009 | HP Compaq Presario V2403NR Notebook
Averatec 3200 Notebook Logo
12 people viewed this question
Top Averatec Computers & Internet Experts
Rommel Balcita
Are you an Averatec Computer and Internet Expert? Answer questions, earn points and help others
