Question about Dell SP2208WFP 22 in. TV
Dell 2208wfp how to remove the base? - Dell SP2208WFP 22 in. TV
    Problem Solver:
  • 6 Answers
Check to see for a latch on the back.
Posted on Oct 08, 2009
Dell 2208WFPt no power - nothing.
Check the cord at the wall and the back of the monitor. If you can use a known-good cord, and still nothing, then your best bet is replacing the monitor completely.
Dec 12, 2012 | Dell UltraSharp 2208WFP 22" Widescreen LCD...
2208wfpt
The problem is caused by one or more capacitors that have opened in the power supply/inverter board, sometimes they show a bulge at the top making it easier to spot.
Apr 22, 2012 | Dell UltraSharp 2208WFP 22" Widescreen LCD...
Vertical line has been shown on right side of screen of dell lcd model no. 2208wfp
That is the LCD panel failure, not much you can do but replaceing the panel whick will not be worth it. It will get worst with more lines.
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
Failed TV and Monitors: http://s807.photobucket.com/albums/yy352/budm/
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Or www.digikey.com just make sure to use caps with low ESR, 105c, high ripple current, long life rating such as PANASONIC FM or FC series.
Dec 24, 2010 | Dell UltraSharp 2208WFP 22" Widescreen LCD...
I connect an external hard drive to my Dell monitor and the usb wont work.
Will any USB device (keyboard, mouse, memory-stick) work when connected to your Dell monitor?
Will those USB devices (including your external disk-drive) work when _directly_ connected to your computer?
Dec 22, 2010 | Dell UltraSharp 2208WFP 22" Widescreen LCD...
I have a Dell 2208WFP Monitor. When it poweres up it stays on a couple of seconds and the display goes off, If the power is cycled same thing. Has problem connected to VGA or HDMI. I replaced the inverter...
The problem can be the lamp assemblies also, it will be hard to verify unless you have test lamps to find out if it is the lamps or the inverter problem, that is one of the first thing I check first if the board has no sign of damage. I save a lot of lamp assemblies for testing purpose.
http://s807.photobucket.com/albums/yy352/budm/Inverter%20test%20lamps/
http://s807.photobucket.com/albums/yy352/budm/Bad%20backlight%20lamp/
Inverter tester: http://lcdparts.net/IT01.aspx
May 10, 2010 | Dell UltraSharp 2208WFP 22" Widescreen LCD...
Dell 2208WFP won't power up. No LED's, no clicking, nothing at all. Power button click seems OK.
You need to open it up and inspect the main fuse (red round part by the AC inlet), DC filter caps (look for bad caps with leaking or bulging tops).
Board: http://www.lcdrepair.us/E2208WFPt-inverter-power.html
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
http://www.badcaps.net
May 04, 2010 | Dell UltraSharp 2208WFP 22" Widescreen LCD...
DELL 2208WFP LCD-Comes on normally, but almost immediately goes dark You can see something on the screen if you look closely. Turn it off and back on you see it then dark. any help?
I believe the power led button is still on while the screen goes dark, if yes, it means the picture board of your monitor is bad that is why it appears for a second and goes dark after that
Since the power led button is on, It means the picture board on your monitor is faulty that is why it appears for a second and goes dark.
The best thing for you to do now is to take the monitor to a local repairer or any service center within your vicinity to help with the replacement of the picture board because the fault is not something you can fix yourself in other to complicate issues.
Take care.
May 01, 2010 | Dell UltraSharp 2208WFP 22" Widescreen LCD...
Dell 2208wfp usb port
your ports have lost their driver .
go to start
right click on my computer
click on properties
click on hardware tab
click on device manager
scroll until you find port tab double click on port tab
right click on each port one by one and click on update driver .
this normally should do it .
If it does not , go to Dell support :
http://support.dell.com/support/downloads/index.aspx?c=us&l=en&s=gen
and download new drivers for your port
Oct 24, 2009 | Dell Computers & Internet
Dell SP2208WFP 22 in. TV Logo
177 people viewed this question
Top Dell Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Jaime Hernandez
Are you a Dell Televison and Video Expert? Answer questions, earn points and help others
