Question about Dishwashers
A valve from a sippy cup has fallen into the bottom of the dishwasher not allowing it to drain?
  • 715 Answers
Remove drain line from under the sink and try to blow thru it
Posted on Oct 08, 2009
My dishwasher does not completely drain. how do you remove the plastic strainer?
If after the cycle there is about a cup or two left in the bottom of the dishwasher than it is likely the check valve located on the drain line close to the connection at the dishwasher.
If you listen carefully as the unit pumps out draining the sump if the pump sound increases as if the sump has emptied than you can assume it is the check valve.
It might clear itself over time. Each cycle the valve is purged. If not than you may need to replace the valve. The purpose of the valve has two important functions.
  1. Prevent water from the sink drain reentering the dishwasher. This is particularly true if the sink should ever get stopped up.
  2. The second it to prevent the small amount of water trapped in the drain loop from refilling the sump
Dec 02, 2015 | Dishwashers
Dishwasher draining / emptying of water
If the water doesn't drain from your dishwasher, check these:
Drain line/air gap
A clog in the drain line or air gap (if there is one) is the usual reason that a dishwasher won't drain. Often the problem is at the point where the drain line attaches to the garbage disposer or household drain line. If you remove this line, you can clear any debris from the hose or hose connection. Be sure to reattach the hose before starting the dishwasher again.
Pump
Your dishwasher pump ejects the water. The pump is usually mounted directly to the motor, then attached to the bottom of the dishwasher. You can reach the pump from inside the dishwasher, but first you need to remove the lower rack, the spray arm, and the spray arm support.
Look for an impeller--a round plastic fan blade-type of device that spins around. This is the wash impeller, which forces the water through the spray arm. Beneath the wash impeller is the drain impeller, which is similar in size and shape to the wash impeller. The drain impeller pushes the water toward the drain port. These components make up the pump. If any of the pump components are defective, you need to replace them.
Drain valve and/or solenoid
Many dishwashers use a drain valve with an electric solenoid. When electricity flows to the solenoid, the valve opens and diverts the water to the drain. Sometimes the solenoid, or the diverting lever, sticks and prevents the dishwasher from draining or filling properly. Try to free up the solenoid to lubricate the lever. Otherwise, you may have to replace the solenoid or pump assembly. With these systems, the motor always rotates in one direction. When it's energized, the drain valve diverts the water.
Other dishwashers simply reverse the direction of the motor to drain the dishwasher. These units don't have a drain valve. Instead, there's a drain hose connected directly to the pump housing.
Belt
One brand of dishwasher uses a belt to drive the pump. If this belt is broken or has fallen off, replace it.
Motor
If the motor isn't turning or working, the unit won't drain. First check to be sure you have power to the dishwasher. If not, see the section "It doesn't work at all." If the motor hums but doesn't turn, it may need to be replaced.
Some dishwashers are susceptible to getting stuck if you don't run them regularly. If you haven't run the dishwasher for more than a week, you may need to manually spin the motor to free it up. If the motor is defective, you need to replace it. Dishwasher motors can't be serviced.
Timer
Part of what the timer does is control the motor and drain valve. If the timer doesn't work properly, the water may not drain and you need to replace the timer. This problem is uncommon.
Oct 27, 2008 | Frigidaire Dishwashers
Asko fifteen eighty five dishwasher completes cycle, but the drain cup area still has water in it.
The drain cup normally has water in it after it drains. The pump runs it empty, but when it stops, some water runs back down from the drain hose, which you see in the drain cup. If there is water in the bottom of the tub, you may be having some siphoning coming back after draining. Check to make sure the drain hose has been routed up to the bottom of the countertop as per the installation instructions. That's what prevents siphoning, and its very important so it doesn't suck sewer water back in with the clean dishes!!
Jul 08, 2014 | Asko 24 in. D3250 Built-in Dishwasher
Water will not suck out of my son's sippy cup (Dr. Browns hard spout).
there is a hair problem. it is not getting air to replace the liquid.
look for blockage
Aug 22, 2013 | Dr Brown Soft Hard Spout Training Sippy...
My dishwasher is not draining water - there is standing water at the bottom of the bin (I used a cup to get out as much as I could before I shot the video). The back part that looks like a drain is no
Pull the bottom sprayer out. There should be two clips on either end of it that allow it to come out. Then remove the screen from the bottom of the dishwasher floor. This can be tricking and may take some effort to get out. I'm betting the drain in the bottom of the washer is plugged and needs to be cleared out. I usually have to do this every few months.
Nov 24, 2012 | Dishwashers
My model DU810swkqo dishwasher will not drain completely [leaves about a couple of qts of water in the bottom after cycle.It has started dripping water out the bottom of the door.Can or does it need drain...
Hello
If the water won't drain from the dishwasher, first manually remove as much water as possible and then check the sump area for paper or any other large object. Make sure the door is properly latched. The pump will not drain if the door is not latched properly. Check the belt, drain line, air gap, drain valve and solenoid assembly, the motor, and the pump. If your dishwasher uses a belt to drive the pump, and it has broken or come off the pulley, replace it.
A cup or so of water in the sump area of your dishwasher is normal. It is there to prevent the seals from drying out. The dishwasher will pump this old water out before beginning to wash.
If you have recently installed a garbage disposer in your home, make sure that the drain plug on the disposer has been removed. It's just a little plastic piece that blocks the hole where you hook the dishwasher drain hose. If your dishwasher drains through the garbage disposer, you need to run the garbage disposer before you run the dishwasher to make sure that the drain is clear.
There is a drain hose between the drain valve or pump and the garbage disposal or drain line. If an obstruction has blocked this, then your dishwasher won't drain. The drain hose is connected by clamps to the drain valve and the disposer or drain pipe. Remove it and visually inspect it for a clog or a kink. Try to remove any debris. If it is in good condition, just put it back on, and if not, purchase a new one to install.
If you don't have an air gap in the drain line, at least use a high drain loop. Making a large loop about 18" off the ground with the drain line can prevent any back flow into the dishwasher from the sink.
If you have one, the air gap will be located on top of the sink. The air gap is there to prevent any siphoning of standing water from the sink. When your dishwasher drains, the air gap diaphragm will form a seal and allow the water to drain properly. If the diaphragm in the air gap is faulty, it's possible that water can leak onto the cabinet and into the sink area. When this happens, then the air gap must be replaced.
Like the inlet valve, there is also a drain valve on most models. When no power goes to the drain valve it remains closed and prevents water from leaving the machine. When the valve receives power during the drain cycle, the solenoid opens and allows the water to leave the machine. If your drain hose is attached directly to the pump, you don't have a drain valve. The motor simply reverses and the pump sends the water in the opposite direction, which is out of the machine.
If the motor doesn't turn or work properly, the dishwasher may not drain. Make sure you have power to the unit. If you notice that the motor hums but won't turn, it could be seized, and you probably need to replace it.
Small objects can sometimes get stuck in the pump. When this occurs, you'll need to open the pump and remove any debris buildup. The dishwasher pump is usually mounted directly to the motor and runs off the motor as well. The pump is also attached to the bottom of your dishwasher and pushes the water from the dishwasher.
Aug 06, 2011 | Dishwashers
Miele dishwasher finishes the cycle with water in the bottom and the dishes not clean
In the bottom of the dishwasher you have a filter. under the filter is a non return valve. it is a one way valve that keeps the dirty drain water from draining back into the dishwasher. if it is dirty or broken, the dirty water that your machine drains out, is running right back in as soon as the drain pump shuts off. this will keep happening and your dishwasher will just spray the dirty water back on the dishes over and over again.
to get to it, you will need to get the water out of the machine. if you have a wet dry shop vac use that. if not, you can bail it out with a cup, and soak the rest up with a sponge. remove the lower spray arm by pulling it up. remove the filter by pulling the handle in the direction of the arrow. lift the filter out of the way. get the rest of the water out of the sump. on the left side of the sump, you will see a silver wire bail holding the non return valve in. flip the bail towards the center of the sump. pull up and out on the non return valve. it has a rubber seal and a stainless steel ball inside. any debris between the seal and the ball will keep the valve from closing all the way, and allow the water to drain back. you can order a replacement if needed, directly from miele. 1800 842 7231.
Nov 19, 2010 | Miele G880 Dishwasher
Dishwasher filling with water when not in use.
you need to replace the fill valve located on the left side behind the kick plates located at the bottom of machine. But you can test this by turning off valve located under the sink.
However if the disposal is clogged its possible that water is back filling as it usaully drains through the disposal. Also make sure that the drain hose has'nt fallen below p-trap of sink.
Jul 12, 2010 | Whirlpool Gold 24 in. Built-In Dishwasher...
KitchenAid dishwasher allows water to drain while washing
Your dishwasher is siphoning the water out. The drain hose should turn upward, nearly to the bottom side of the counter top, before it attaches to the drain or disposal. If it has an independant drain it still needs the rise and also needs an air break to stop the siphoning.
Jul 17, 2009 | KitchenAid 24 in. KUDS01FLBL Built-in...
No clean dishes
Internal filtersEvery dishwasher has some type of filter to keep large food particles and foreign objects away from the pump assembly:
  • Most modern dishwashers have self-cleaning filters that don't need any routine cleaning.
  • Some have filters in the bottom of the dishwasher that you need to periodically clean. You don't need any tools to remove the filter, and cleaning it is easy. Consult your owner's manual to determine which type you have and its maintenance requirements.
If your filter is clogged, it may be causing the cleaning problem.
Drain valve
Some dishwashers have a valve (or gate) that should open only during draining. If debris lodges in the valve, it can't close properly, so water drains out during the wash cycle. Most dishwashers drain into the garbage disposer. If yours does that, listen for water flowing into the disposer during the wash cycle. If you can hear it then, the drain valve may be clogged.
Spray arms
There's a spray arm at the bottom of your dishwasher--it may have a tall spray tube mounted to the center of it. There may also be a spray arm located directly beneath the upper rack of dishes and/or above the upper rack.
If debris is blocking the holes in the spray arms where the water comes out, it could cause cleaning problems. Regularly inspect each of the spray arms and clean out the holes as necessary.
Detergent cups
Dishwashers don't perform their best if detergent is introduced only at the beginning of a cycle, so add detergent to both parts of the cup.
If the detergent cup isn't opening, see the "The detergent cup doesn't open" section, below.
Note: Dishwashers are usually wired directly to the home’s electrical system. To disconnect the power, switch off the circuit breaker or remove the fuse for the electrical circuit the dishwasher is attached to. Try to turn the unit on after disconnecting the power to be sure you were successful.
CAUTION: If you’re not sure you’ve shut off the power properly, DO NOT CONTINUE. Call a qualified appliance repair technician to complete the repair.
Sep 12, 2008 | Kenmore 16602 / 16604 / 16609 Built-in...
Dishwashers Logo
Top Dishwashers Experts
