Question about Zebra LP 2844 Thermal Printer
Blank labels being fed
My printer will print a few labels fine but then the alignment gets off and will feed out blank labels and then the light turns red. I try to run the Dump by holding the button and turning on the printer, but all it does it feed blank labels. Any help?
    Scholar:
  • 185 Answers
Re-calibrate the printer by switching the printer off, press and hold the feed button whilst turning the power on. Release the button when the light flashes red. Once calibrated try again, if no joy then try a different driver
Posted on Nov 13, 2009
Easycoder C4 Printer wont print
See if this can help:
epsfiles.intermec.com/eps.../1-960572-01%20UG%20EC%20C4.pdf
May 26, 2014 | Intermec Easycoder C4 Therm Label Printer...
Printer TLP2824 thermal printer prints too many labels. Prints one and then spits two more out(blank).
Clean media sensors. The blank labels are a result of the printer trying to calibrate label length.
Aug 12, 2013 | Zebra TLP 2824 Printer
Prints lable every 5 labels the rest are blank
Troubleshoot to see if the problem is with the printer or the software. Turn the printer off and back on again for fresh start. After the POST (power on self test) press the FEED key and see if the printer feeds just 1 label. If it does then you know the optic sensor in the printer has a good read on label size. If it feeds more than one, then it needs to be recalibrated for label size.
If it feeds 1 label, then print a format. Now if it prints 1 label and then feeds blank labels, you know the problem is in the label software you're using or in the printer driver. The printer will only do what it's told to do.
At least this way you can narrow the problem down to the printer or the software.
Hope that helps....
Jun 19, 2011 | Zebra Stripe S600 Thermal Label Printer
The printer adds an extra line space at the end of every label I print, by the 4th label they aren't usable
You could fix this in the printer, but faster and easier to alter your program's printing function. Check that you are using the correct form template, and either delete one line from your data, The program may be issuing a line feed, or modify the form dimentions.
print on blank paper until you get it dialed in. Hold up to light and lay labels over or under it to see alignment
Oct 15, 2010 | OKI MICROLINE 390 Turbo Matrix Printer
Not printing all labels
Do a calibration, this should fix the issue. Also make sure that the label stopper (silver peg on label holder) is pressed firmly against the labels. This will stop the labels from sliding around during a print, throwing off the calibration. Also check to make sure the sensors are free of any dust.
Jun 17, 2010 | Zebra 105Se Thermal Printer
Zebra 2746e will skip leaving a blank label while printing.
You need to calibrate. Hold down the feed key while powering the printer on, then let go. The printer will calibrate, print a config label, then fo into dump mode. Press the fee key again to go out of dump. Of your issue persists, there could be a problem with yoru media, or with the commands that you are sending to the printer.
May 28, 2009 | Zebra 2746e Thermal Printer
Printing in page mode feeds extra blanc labels
Make sure,
you firmware is right one for that printer because in most of cases it happens due to wrong firmware and bad ADF kits. so check your ADF kids and if you find them fine the install updated firmware on in.
once you done with these all then turn your printer off and turn it back on.
post back if any thing changes and rate all answers.
Good luck
Feb 24, 2009 | Epson TM-L90
ZQL420+ is printeing an extra blank label with each good label.
Check if you have " send Form Feed after each file" is enabled (or yes) in your print queue
Nov 20, 2008 | Zebra QL420 Thermal Printer
Printer keeps printing blanks...
We have found a reset that we use.
We unplug the printer and then we hold down the feed button and we keep holding down the feed button while we plug back in.
It goes through some sort of a reset and this sometimes works.
Jan 23, 2008 | Dymo LabelWriter 400 Turbo Thermal Printer
Zebra lp 2844 thermal printer
It sounds like it needs to be re gapped. Try this:
1. Make sure that printer power is off.
2. Press and hold the feed button.
3. Turn printer power on.
4. When the status light blinks, release
the feed button.
5. The printer advances the media to
measure and verify the length of
individual labels or tags. The printer
then prints a status summary and
remains in diagnostic dump mode.
6. To begin normal operation, tap the
feed button. The printer prints "out of
DUMP" and advances a label.
Nov 30, 2007 | Zebra LP 2844 Thermal Printer
Zebra LP 2844 Thermal Printer Logo
292 people viewed this question
Top Zebra Office Equipment & Supplies Experts
Dave Busselle
Level 1 Expert
CheckitRight
CheckitRight
Are you a Zebra Office Equipment and Supply Expert? Answer questions, earn points and help others
