Printer says it out of paper when paper is in photo tray
  • 448 Answers
If you have more than one tray, or the printer thinks that you have more than one tray, you have to tell the print which tray to use. That may not be the problem, but it should be worth going through your print procedure to check.
Hope this is helpful.
Posted on Oct 08, 2009
Invalid yellow toner
Hp c6180 won't print from 4x6 photo paper tray
If you put regular paper in the tray as it is asking does the printer use the regular paper to print the picture? If so, be sure the 4x6 photo paper tray (with photo paper) is pushed all the way in, and when you select print there should be an option (probably hidden in a submenu) to select the photo tray as the paper source. If you are printing from Adobe Acrobat, I have not found a reliable way to get the c6180 to use the photo paper tray. I hope this helps.
Jul 15, 2012 | HP Photosmart C6180 All-In-One InkJet...
How do I print color photos on glossy paper with Canon Pixma MP 6
printer supports it. just you have to goto printing preferences or printer properties and set rear tray to accept glossy paper. it will accept size of paper ur using. so give the actual size.
Apr 23, 2009 | Office Equipment & Supplies
OfficeJet Pro 8600 will not pick up glossy photo paper from the tray
I tried everything that was suggested on the HP forum but then tried something not reccommended there and it worked. Not only remove tray 2 from the printer properties but force the print to tray 2, when you this it sets the Quality from normal or Best to Custom. Once I done that it worked... Just disabling the tray 2 is not enough.
Mar 26, 2012 | HP OfficeJet Pro K8600 Printer
I can't get my hp photosmart printer to print photos from my hard drive onto the photo paper. It will print the photos from the paper tray.
You have to shift the paper tray. Click on start, click on printer/faxes right click click on your printer, click on printer preferences, select photo printing borderless. This shifts your paper tray to photo paper.
Dec 20, 2010 | Computers & Internet
My photosmart 7150 prints half a page(vertical half) ! It worked fine before this. Help! thanks
Ok, I was having this same problem and the solution for me appears to lay in the fact that the "photo tray" was pushed in, signaling to the printer that it should print to the size specifications of a photo (approximately half the width of a standard letter page). I should also mention that with my problem, the printer would hang at every single print job--presumably to wait for you to input your photo paper--and that executing this fix solved the problem.
To fix this, I followed these instructions: SOLUTION:Follow the steps below to correct the issue:
  1. Disconnect power to the printer.
  2. Remove all photo paper from the Photo Tray.
  3. Push the Photo Tray completely into the printer.
  4. Snap the Photo Tray out (towards you) sharply.
  5. Reconnect power to the printer.
  6. Print a self-test on 8.5 X 10 paper.
  7. Engage the Photo Tray.
  8. From the Printer Toolbox, select Calibrate the Photo Tray .
Sep 26, 2009 | HP PhotoSmart 7150 InkJet Printer
Printing from the photo tray
I have found that when you put the photo paper in to the photo tray you have to slide the photo paper in to the printer gently as far as it will go, then slide the side and rear guides to the photo paper. If you just put the photo paper in to photo tray without doing this, the printer will not take up the photo paper at all.
Nov 01, 2008 | HP PhotoSmart 7760 InkJet Printer
Printing Photos on Photo Paper
Ensure u are placing the paper in the photo tray..
if u r printing from the memory card which is inserted in the printer..ensure that the PHOTO BUTTON on the printer is on..
You can also try to reset the printer by going to the SETTINGS/TOOLS menu (RENCH SYMBOL) and then look for the Factory Restore (Might be under "Preferences")
Sep 28, 2008 | HP Photosmart C6180 All-In-One InkJet...
Kodak 5300 wont print on glossy side of photo paper
I just sussed this issue out. On the front of the printer tray there is another pull out tray, this opens up and must activate the photo printing for A4 because it stops the paper falling on the floor once printed (cos once printed on photo paper it may still be wet). As soon as I opened the tray (and it then opens again - you'll see what I mean) it printed A4 photo paper perfectly
Hope this helps others
Feb 23, 2008 | Kodak EASYSHARE 5500 All-In-One InkJet...
306 people viewed this question
jasbo
jasbo
