Wharfedale tu250dtr fails to record programmes that are set on the epg . fault code #0229 appears as a message after the programme doesn't record .
3 Suggested Answers
  • 212 Answers
SOURCE: My Thomson Top up TV box will not record. I go to
Sounds to me like your hard drive is full. Do you use the topup tv part of the box? If not, deselect all the topup tv channels. This will free up a significant amount of drive. Failing that, you'll have to delete some of your programs, sorry!
To deselect topup tv channels;
Go into the menu option, Customise Top Up TV Anytime, and de-activate all the selected channels
Posted on Jan 23, 2010
SOURCE: Sharp TU-TV322H failing to make planned recordings
I had this problem aswell! I tried everything but ended up phoneing the help line, when they asked for what frequancies they found out i was picking up different ones form two different stations. I took the ariel out of the back on the freeview box and run a scan for channels (of course it came up with none as the ariel is unpluged but it overwirites and clears the incorect frequencies). Then plug the areil back into the freeview box and run a scan for channels. After doing this i picked up the correct frequencines form the correct station and my recordings actually recorded! If you phone the help line (08444159159) they will tell you what frequencies you should be picking up. I hope this qorkes for you!
Posted on May 19, 2010
How do I access a programme that I have recorded via epg using the original remote control. How do I set the time on my tv.
You don't mention the make and model of the TV, so it's not possible to give a specific answer.
The EPG is normally detailing the TV guide. I wouldn't expect to find my recorded programs listed in the EPG. There'll be a different way of accessing timer recordings. Check your user manual. Same for setting the time. It will be listed in the user manual.
Sep 04, 2014 | Televison & Video
Sharp LC-32P70E TV: EPG suddenly not showing
hello, this sounds more like a cable or satelite problem. hame you tried reseting your cable or sat box? usually when you reset the box it will download the guide again...
Oct 16, 2007 | Televison & Video
I have a Benz c 180 with a error code 2929. I have no manual. any one with a solution?
Are you sure it's 2929? And not 0229? I scoured Benz fault codes and there's not a 2929... Of it is 0229 it's the TPS (Throttle Positioning Sensor) failure
Feb 28, 2011 | Mercedes-Benz C-Class Cars & Trucks
AFTER I HAVE RECORDED A PROGRAMME I AM UNABLE TO PLAY IT ON OTHER DVD PLAYERS ARE MY SETTINGS INCORRECT? THANKS
No,many small DVD players compannies makers used difference ending codes,that was patent by the big tv corporations,that also make DVD players.That why u couldn't play from one DVD player to the next DVD players.
Dec 06, 2010 | Wharfedale DVD-M3 DVD Player
Our Teac hdr2500t epg Guide stopped working showing only the programme times but not titles. This comes only a couple of days after it stopped allowing me to watch one programme while recording another...
Turn off the unit via the standby button on the remote and pick "passive standby". Next time you turn it on the epg will be back. The other option is to turn off the unit via the power switch at the rear of the unit.
Jun 29, 2010 | Televison & Video
I have purchased a Teac HDR2500T video recorder. I can set up to record television programme through EPG or PVR. I can see in LIST that the programme is recording, however when the programme is finshed,...
The part re the other channels having no signal....I had the same problem with mine and that was because the small loop cable in the back wasnt right. I could watch all channels, press record and still watch that channel but try to watch a diff channel while its recording and they were gone. As soon as I had the loop cable in properly it solved the problem. Hope this helps....
Sep 06, 2009 | Televison & Video
Hi I just bought a Wharfedale DTR250 twin tuner HDD. How can I connect it up to be able to record sky programmes? On my old VCR all I did was set the VCR to EL1 and the selected Sky programmes recorded OK....
My solution was to return item to Argos, got my money back and will now go ahead and order a Sky Plus Box. Apparently these type of Recorder will not record Sky programs!!
Jul 05, 2008 | Televison & Video
Wharfedale DVDR24HD250 DVD Recorder When set up will not find any programmes on Automatic Programme Search (APS)
Products such as this will use an internal tuner to tune channels, this tuner will not detect your televisions freeview stations, to record from your television, connect scart out from tv to the scart in on the recorder, then select the scart A/V channel, use the television to select the channel you want to record, you will not be able to record 1 freeview channel and watch another freeview chanel as you only have 1 digital tuner (in the television) the recorder does not have freeview built in.. hope that helps
Mar 24, 2008 | Televison & Video
Wharfedale dvdrhd400 problems
Change the Scart setting (in the setup menu) from the default setting (RGB) to the other available setting (CVSC?).
I have a problem with my box restting the clock on a random basis, making it impossible to set a timer to record anything - let us know if you get the same problem via this site!
Jan 03, 2008 | Wharfedale DVD-M3 DVD Player
Error code
I had the same problem - turn off at the wall and on again fixed it.
Dec 07, 2007 | Wharfedale DVD-M3 DVD Player
Televison & Video Logo
76 people viewed this question
Top Televison & Video Experts
Electro Med Services...
