Question about Rangemaster Kitchen Hood
How easy is installation of a Rangemaster chimney hood?
I am going to buy a Rangemaster chminey hood for my oven. How easy is this to install? Is this something my electrician can do without too much fuss? Also the extraction route will need to be through a disused chimney breast, again, do you think this will be a problem? Thanks.
  • 72 Answers
There is a template supplied for drilling holes in the appropriate places. If it is a large hood over 900mm best to have a friend help you. Most important is to check that the bottom of the hood is at least 750mm above the gas burners. Definately use a qualified eletrician to wire this for you.
Posted on Dec 28, 2009
Fl3 code. heater working fine when i closed last year. will not start this year. showing fl 3- does not ignite , does not do anything ..help please
3.
Spillage at A.Cold chimney A.Allow heater to operate 5 minutes to create draft action.
draft hood B. Vent pipe pitches down to chimney B. Reinstall vent pipe to pitch up from heater to chimney.
C. Blocked chimney C. Remove blockage.
D. Draft hood altered D. Install factory-provided draft hood.
E. Prefabricated chimney with incorrect cap E. Install a Nationally Recognized Testing Lab (NRTL) listed vent
http://www.jandy-downloads.com/pdfs/Lite2_LJ_IO_H0248900F.pdf
I tried to copy the FL3 write up from the chart but it screwed it up a little. Look at Page 35 of the manual for a clear copy
Jun 10, 2011 | Jandy Lite 2 Natural Gas Pilot Light...
My rangemaster cooker hoos has just stopped working.. no fan working and no light coming on ??
The same happened to me. I found a 3-amp fuse which I changed, and now it's ok.
I removed the chimney casing and located the electrical connection into the wall. You'll find a fuse unit within the switch which swings out.
Hope this helps.
Dec 20, 2010 | Rangemaster Kitchen Hood
A bulb blew in my tecnik cooker hood and neither the lights of the fan will work? is there a fuse somewhere that I need to change?
In case you are still looking for an answer. The same happened to me.
Hope this helps.
Dec 08, 2010 | Rangemaster Kitchen Hood
Install the chimney cover
there should be 2 or 3 peices of alum off the hood predrill hole's then rivet or steel screws
Feb 12, 2009 | Bosch DKE 9365 Stainless Steel Kitchen...
Broan kitchen hood - frenetic chimney
It can be 2 things.
1. The motor that elevates the fan is turning a tad to much. Just by stepping on the floor near it could cause it to go up/down constantly.
2.Or what i had seen was the wires that go to the switch dont have enough slack, and are just making contact to the switch causing it to think somone is pushing the button constantly.
There is way too many steps involved to type out.
Dec 01, 2008 | Broan-NuTone Rangemaster RMDD3004...
Rangemaster cooker hood. model no.LEIHDC120SC/
hood should be connected to a fused spur outlet which you havent found. try removing the chimney and you may find it there. chimney only held by 2 screws at top usually.the fuse in the outlet sometimes goes when bulbs blow
May 31, 2007 | Rangemaster Broan 614804 BALLISTA 48IN...
Rangemaster Kitchen Hood Logo
284 people viewed this question
Top Rangemaster Kitchen Ranges Experts
Ismael Rodriguez...
Mike Carew
paulcarew
Are you a Rangemaster Kitchen Range Expert? Answer questions, earn points and help others
