Question about Home
Kitchen tap just turns wont stop or start had to shut down with stop **** taps are plastic on top with red and blue think pre 1980
    Scholar:
  • 150 Answers
Sounds like the splines in the tops have worn out
Prize off top red/blue insert u should see a screw in the middle - tighten
If tops still loose remove screw and prize up the plastic top. Hefty spanner on what's left [the tap barrel ] To counter twisting underneath - hold tap with other spanner/ wrench remove barrels and replace with tap reviver kit from local merchants
Posted on Oct 22, 2009
How do I get to make it stop and work .Dishwasher is not shutting down it says E 15 Water tap flashing , and red Aqua stop light .
inlet valve is the aqua stop long hose to tap has a solenoid at tap end that is likely your fault
Sep 29, 2016 | Bosch Dishwashers
Samsung s3 phone wont turn on only red light stays on and a buzzing noise sounds and wont turn on need help
Shut it down by holding the power button until the screen goes black, don't tap the power off button, wait for the black screen. Then let your phone charge for a few hours (maybe over night) with power off and see if that helps.
Dec 12, 2014 | Samsung Galaxy S Iii S3 Gt-i9300 16gb...
Pilot wont stay lit
check flame height perhaps the tip needs cleaned or flame adjusted .
Sep 25, 2014 | Kitchen Appliances - Others
Will not turn on
Undo the black plastic caps, one on each side. You probably need new carbon brushes. Remove them carefully and note that the brushes will only fit one way there is a blocking stop on the inner edge of the brush holder, you can see it with a torch when brush is out. Line the chamfered off corner of the new carbon brush up with the blocking stop. On one side it is at the back at the top and the other at the back at the bottom ( I think )
Nov 21, 2013 | KitchenAid Kitchen Aid STAND MIXER 5qt...
Oven control valve wont shut off gas completely
This could be due to a build up of grease or tiny food particles behind the control tap handle;
1/ Gently prise off the handle ( it comes towards you )
2/ Wash handle in warm soapy/detergent water, till clean, then dry.
3/ Use a lint-free cloth or a sponge with warm soapy water to soak the tap control spindle and a plastic knife to clean off any stubborn bits.
4/ Wipe clean , replace handle part, try turning off.
Jaylo264
Jan 03, 2011 | Brown Stove Works TM210 Gas Kitchen Range
Sprayer will not stop pumping when switched to pump mode after primed it will not shut down it just keeps pumping. .
Paint sprayer.
Flip lever down to prime > paint comes out small plastic hose.
Flip lever up to put pressure on spray line.
Problem: prime keeps running and spray line never gets pressure.
Future solution:
You did not clean sprayer very well last time, or it is rusted. When cleaning, run full 5 gallons of cleaner through machine twice.
You should fill spray line and pump with kerosene if machine sits idle more than few days.
We all forget.
Good news: you have prime. If machine doesn't prime, you probably have to disassemble.
More good news: There are two steel balls inside pump. Tap top one with hammer to loosen. Keep machine running. Keep lever up. Start tapping top one. Tap a little harder... keep tapping ... sometimes it will not free up ... take apart pipe and see if you can nudge ball loose >> be careful not to scratch anything... the sprayer is high pressure and all parts have to fit
Oct 07, 2010 | Garden
No water is coming in the washer before the agitator starts
The above answer is copied from Washerhelp Please only use small quotes and link to the original source
Mar 29, 2009 | Whirlpool Washing Machines
While driving engine just shuts off
go down and have your alternator checked, it might be weak, causing a surge in power to the ecu, shutting the engine down, if was the battery the car wouldnt fire right back up, another thing might be the fuel filter/pump, these should be the first things to check.
Mar 26, 2009 | 2001 Ford Escort ZX2
Leaking Kitchen Tap
yes your right it's the seal inside and it can be replaced you should shut the water off after all why make a mess when you don't have to. however I'm not familiar with this typ of faucet. you more than likely be able to get help from your local area hardware store when you purchase your gasket for replacement.
Sep 02, 2008 | Plumbing
Nintendo ds
Setting the Time and Date
Changing the time
  1. Remove all games from the Nintendo DS.
  2. Turn the system on by pressing the POWER button.
  3. Tap the screen using the stylus when the "Touch the Touch Screen to continue" message appears.
  4. When the main menu appears, tap the stylus on the Settings Menu Panel at the bottom middle part of the screen. icon_settings.gif
  5. Tap the calendar/time icon (the blue icon, second from the left). icon_clockdate.gif
  7. Tap the up or down arrows above the hour and minute to change the time. When finished, tap the "Confirm" button in the lower right corner.
  8. Wait for the the confirmation message to disappear, then tap "Go Back," then "Quit," then "Yes" to exit. The unit will shut down automatically to save the settings.
Changing the date
  7. Tap the up or down arrows above the month, day, and year to change the values. When finished, tap the "Confirm" button in the lower right corner.
Dec 30, 2007 | Nintendo DS Console
Home Logo
179 people viewed this question
Top Home Experts
Donni Steen
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
