Question about Cycling
HAVING PROBLEMS REMOVING SIDEPLATES FROM PROFORM XP 185U.I REMOVED ALL SCREWS BUT SOMETHING IS STILL HOLDING IT TOGETHER.
  • 715 Answers
Look for rivets
Posted on Oct 08, 2009
Proform xp 580 - Does anyone know how to remove the control panel cover? Is there a diagram somewhere of all screws?
Look up your model on IconService.com, they have the user manual, and also the schematics that I use as a Tech. Note that even as a repair tech, I rarely ever get into the console.
Technical note - on treadmills, the top electronic board is actually called a "console". The "controller" is the circuit board that sits next to the drive motor in the bottom housing in front of the drive roller.
Jan 05, 2013 | Proform XP 580 Trainer Treadmill
Proform 730 treadmill,rusted screws won't remove to replace walking belt
Use WD40. Or go to a nearby hardware store an purchase a rust remover. Aply either one and wait for a bit. Then remove screws.
May 06, 2012 | Proform Exercise & Fitness
My Pro-Form 490 LE has a resistance problem--it won't adjust and it seems to be set on a difficult resistance, I can't really pedal it. how do I fix this? I tried switching the levels, but it doesn't...
Open the rear part where the "guts" are. The magnet will be stuck against the wheel that turns when you pedal because the cable that the resistance motor pulls to remove the tension will have too much slack in it. The cable probably came off of the pulley wheel that is used to providing the necessary tension to pull the magnet off of the wheel.
To get the case off, simply unhook the right side pedal, remove the 4 bolts holding on the crank thing to remove it, then using a philips head screwdriver, remove the screws in the screw holes on the case cover. Be sure to remove the one screw on the other side near the front in order to allow the front part to "unsnap".
Jan 16, 2011 | Proform PFTL79807 - 850 W/ Gamefit...
Proform XP 185U Upright Bike I just bought this bike yesterday, and the display works, but the backlight on the display doesn't work, it is really hard to see. Is it supposed to light up the whole screen....
No light on the back, call the number for warranty support with your model number and serial number. They will mail out a card for you.
Dec 31, 2010 | Cycling
My proform 860 has belt slippage and sometimes stops after a few minutes
I had the same problem and was about to change the walking belt. Instead I removed the 5 screws holding on the hood and adjusted the Reed Switch and took a walk. Whenever I stomped on the belt hard it would stop. I Could now see (because I removed the hood) that the motor continued to spin and the Motor Drive Belt was slipping and was the culprit. Something that I had noticed before was all this fine rubber dust coming out near the left front corner where this belt is. If you see that it's a good indicator the motor belt is slipping and needs to be replaced.
Dec 09, 2009 | Proform 860 Competitor Treadmill
How do I open it to look inside?
First, lay the tv/monitor on its screen on something level and soft as not to damage the screen. Remove any visible screws that seem to attach the base to the unit. Some models you have to look under the base for pins orso to push together to slide the base from the stand, only then you could reach the 1 screw holding the monitor to the stand....Once stand removed, remove any screws you see holding the monitor casing together, usually only a few screws since they are mostly held together by plastic "clips"...Once screws are removed, then gently insert a flat(screwdriver orso) inbetween the case?housing, repeat this all the way around the case/housing till completely loose....You will prob have a few wires or maybe a ground wire that you would have to remove before completely being able to seperate both sides(front case, back case)..Sometimes you might have to unscrew and remove the skinny washer/nut around the cable input orso..
Nov 18, 2009 | X2Gen MG19MY 19" LCD Monitor
Sportsman 500 HO, stuck in reverse
Solution#1 worked perfectly. It only took about 15 minutes all together.
the side panel removes easily. It just slides out of the other panel. Once you have removed the handle (Shifter) and the other two bracket bolts, just place it back into the shifter housing and move it around. I was amazed at how easy this was to repair. I also turned the ignition to the on position to see if it was changing gears and it was.
Solution #1 repost originally posted by Jpach
I tried this today and it worked. Pull the sideplate from the ATV so that you have access to the gear shifter assembly. Unbolt the gearshift assembly from the mounting bracket. There are two bolts at the rear near the two rods that exit the assembly and three on the bottom. When the bolts are out, remove the assembly from the mounting bracket. Hold it in your hand and move the shift lever through all of the positions. This won't actually shift the transmission, but it should free up the rods in the assembly. Remount the assembly with the five bolts and it should now be able to shift out of reverse.
Apr 29, 2009 | Polaris ATV
Fellows ps60c-2
I have the exact same problem. Please share what you find I would be very grateful. Thank you, jmlaatsch@gmail.com
Mar 31, 2008 | Office Equipment & Supplies
Cycling Logo
134 people viewed this question
Top Cycling Experts
Michial Gueffroy
Andrew Taylor
Andrew Taylor
Are you a Cycling Expert? Answer questions, earn points and help others
