Question about Ovens
My Tappan gas stove will not heat up. The burners
My Tappan gas stove (fairly old) will not heat up. The burners work and lite just fine. The orange glow comes on in the oven but does not heat up past room temp. What needs to be replaced?
  • 715 Answers
Thermo couple
Posted on Oct 08, 2009
My tappan oven won't work. stove and broiler work fine. ignighter glows but it seems like there is no gas.
I would check with your manufacturer and see if a professional can diagnose the regulator and even the gas valve itself.
Jul 17, 2012 | Tappan Ovens
My oven is not working. At the bottom of the stove the ignitor light comes on, but gas doesn't come on. I would like to fix the problem, can you instruct me on how to fix my oven. I want to bake...
The ignitor is probably weak. You have a good circuit because the oven control is trying to light burner. The gas valve is alo fine because it is allowing current to flow. The ignitor with age does not draw enough current to light off the stove.
Aug 23, 2011 | Tappan Ovens
The inside oven is not heating. The top burners are working fine.
If this is an electric oven, most likely the oven bake element has burnt out.
the model and serial number should be behind the bottom drawer,
most elements are held in with (2) 1/4 inch socket hex head screws.
Remember to unplug stove or shut off breaker before servicing.
The element can be slid out usually, then unplugged or remove
the back cover behind stove and unplug it from the wiring harness.
I hope this is useful
Aug 02, 2011 | Tappan Ovens
KENMORE GAS STOVE OVEN LOWER BURNER WON'T WORK
Most likely a hot-surface ignitor has failed. If it doesn't consume enough current, the gas valve won't open. It's usually a fairly easy fix, once you gain access to the ignitor and have a new one to replace it with. Make sure you unplug the range...
Apr 25, 2009 | Ovens
Natural gas to LPG conversion kit for old new world gas stove
Silver solder up all burner jets and redrill to .6 mm then reset adjusters so you get a nice blue flame with small orange tips.and oven burner to .8mm i have just done a new world 75 last week.Works perfect
Apr 14, 2009 | Ovens
Gas oven will not heat.
The main thing that goes out is the ignitor on these stoves. If it appears to be glowing it does not mean a thing. The ignitor gets weak. It should be very bright. if it is a dim orange it is bad.
Apr 12, 2009 | Magic Chef 9122 Gas Single Oven
Oven will not lite
Unplug the unit, change the igniter maybe it does not draw enough ampage.
or check the gas control knob if somebody mistakenly turned it to off position. the ON position should be inline with the gas pipe.
Dec 18, 2008 | Frigidaire FGB24S5A Gas Single Oven
Burners and oven will not heat
Something is stopping the gas flow. Turn off gas. Disconnect line from the stove have someone turn on and off the the gas just for a second.(make sure no flame in room). See if gas is available.If not it is the gas line leading into the house somewhere,not the stove.  Follow the piping to the first thng it comes to. Disconnect that line and see if it is open from there back to the connection. If you finally get to the valve,which I dont think you will . You will have to disassemble  or replace it.
Dec 10, 2008 | Tappan 30IN ELEC IGNa Oven
Maytag gas Oven GA347BXUWX
hi there,
if it's just the stove, it's not the control board because the rest of your stove work. if it's just the oven, it most likely the thermostat, blower or the heat probe. go to www.reliableparts.com to get parts for it.
Aug 07, 2008 | Maytag CWG3100A Gas Single Oven
Gas stove works, but oven does not
you most likely have a bad oven ignitor...if you see an orange glow under the oven panel that is your ignitor trying to come on....but if it is weak it will not open the gas valve.....acess the ignitor and replace it
Jul 30, 2008 | Frigidaire FGB24S5A Gas Single Oven
Ovens Logo
243 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
