Open run type cmd type chkdsk c:
Chkdsk is a common program that you should already have on your machine. It checks your hard drive for errors. You can use your command prompt program (start menu/programs/accessories) to tell it to chkdsk c:/f to fix any errors that may be on your hard drive. If you run it with the f , the program will probably ask you if you want to run it the next time you boot the machine (since it can't do a fix while the hard drive is being used). Say yes and reboot. If you run it without the f , it will simply indicate errors, but will not fix them. Hope this helps.
Let us try either of the following links;
1. http://www.computerhope.com/chkdskh.htm
2. http://www.updatexp.com/windows-xp-chkdsk.html
3. http://support.microsoft.com/kb/315265
4. http://help.lockergnome.com/general/Windowsxp-Chkdsk-exe-Comm--ftopict37029.html
Warm regards,
Anirban Mazumdar
SOURCE: chrome.exe - corrupt disk the file
Click Start
Click Run
Type CMD
Press Enter
Type CHKDSK C: /F
Press Enter
When you're prompted to allow the CHKDSK utility to run the next time that Windows starts, select OK.
Type SHUTDOWN -R -T 10
Press Enter
Windows will shutdown in 10 seconds, and will restart.
CHKDSK will run.
When CHKDSK finishes, Windows will restart, again.
