Linksys WRH54G Wireless Router Logo
Posted on Oct 08, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My router is set up and working great for our 2 laptops and 2 desktops how do I secure network?
Anonymous
Level 2:
Scholar:
  • Expert 150 Answers
  • Posted on Oct 08, 2009
Anonymous
Expert
Level 2:
Scholar:
Answers
150
Questions
0
Helped
71515
Points
459
Hi Jodiee,
You may try the following links;
1. http://www.microsoft.com/athome/moredone/wirelesssetup.mspx
2. http://www.wikihow.com/Create-a-Wireless-Network
Hope it works for you.
Warm regards,
Anirban Mazumdar
Anonymous
Level 1:
Problem Solver:
  • Contributor 11 Answers
Anonymous
Contributor
Level 1:
Problem Solver:
Answers
11
Questions
0
Helped
7358
Points
34
Or u can login into ur router home page by typin in 192.168.0.1 in your browser address page (i think thats the default ip for your router) then u might have to use a user name default might be set to admin for user name and password for ur password once logged into ur router u can set ur secruity up and change ur ssid (router name) as well hope this helps also u can try here for info on how u can do this
www.portforward.com
  • Anonymous Oct 08, 2009
    http://www.portforward.com/english/route...
    try this aswell this will tell you how to get to you router homepage from there just look around u will find where to set sucruity up
2answers
Where is the network security key
goto settings security ,now here enter the WEP key.
Hi I have just installed a brand new Belkin wireless router and it works great with all computers and laptops in the family (including Apple products) apart from my daughters laptop...she has a toshiba...
Check the main computer you set up the network router with...you may need to go to the network status and tasks in control panel...click on this...then you will see a map of all the network devices connected...find the belkin router and click on it...in this window there should be a tab called wireless properties..click this...the wireless properties first page should have the wireless SSID name listed here...and if you click the security tab then the security type and network key are displayed here..You need to write down the SSID, security type, and network key and make sdure the toshiba laptop setting for the wireless network are exactly the same. There may be a link on the first page of the wireless securities saying copy to usb drive..you can use this to copy all network settings to and then transfer these settings in to the toshiba by using the network setup wizard.
One of my computer will not connect to the internet when hard-wired through this router. Others do work and the wireless works flawlessly. The computer in question runs XP and can communicate with the...
1. There may be 3 issues here to consider 1st :
a. the network card \
b. the Ethernet cable
c. the Ethernet port on the router defective.
2.Here is a instruction set to follow to see if your router is connected properly with the said pc :
1.Log into router. Using either 192.168.0.1 to 192.168.1.1 in a browser window that is ( internet Explorer or firefox) on the computer that doesn't connect.
2. Verify wireless router name( on the computer) >>> ( on/off) ( router status window)
3.Note router name you are connecting to.
4.. Check the laptop do ipconfig /all to see current IP addresses.
5. Set the laptop/desktop up in the router by WEP KEY or MAC address. This set up in the "security tab" in the router. using 192.168.0.1 or 192.168.1.1 to access through a browser.
6.Note router name you are connecting to.
7. use a straight through Ethernet cord ( a know good one )\
8. verify that the network card is working by using a loop back ( that is ping the NIC card ( done by using dos command prompt>> loopback address is 127.0.0.1 this should yield 4 hops complete if the NIC card is working ( NIC = Network Interface Card)
I hope this helps. Have a great day!
This is for all routers to set up wirelessly.
Can't connect DSi with same security as comps
hello, yes i had the same problem, but i had it with many other computers, the way i solved it was going into the router settings and click the "restore default settings" then turned the router off for 15 seconds (for a fresh reboot) then when i had to set everything up again i got all my computers on the router and im able to add more without running into that same problem once again, or for a simpler solution try disconnecting the wireless on the computers and replugging them in.... that works sometimes as well
Belkin Wireless Router/HP Laptop - wireless security problem
This is an unusual problem. It's interesting that you can connect without encryption. A few thoughts, which you may well have considered already:
1) Does this happen even when you deliberately disconnect from the network, and reconnect?
2) The network key/passphrase is case sensitive; it is very easy to make a small slip with this, or some other tiny detail, when entering the key;
3) Is there the slightest chance your router has the same SSID (name) as a neighbour's? ....Sorry if this seems a daft question, but it is something to consider...
1helpful
New HP laptop will not connect to wireless secure network
Problem solved. I disabled the security on my network. I connected the new laptop to the unsecure network. I saved the settings on the laptop for the unsecure network. I rebooted the laptop. I re-enabled security on the router. I tried to connect to the network. I got an error on the laptop saying the network saved settings did not match. I modified the settings to a secure network on the laptop and saved the 128 bit key. Rebooted everything. All works fine now.
2answers
Desktop works (direct to router), laptops cannot connect
first of all make sure that the wireless settings of the router match the settings of your wireless computer.
make sure also that there are no friewall or security programs running in your computer because they can interfere with the wireless connection as well.
No connection to desktop, but great connection to laptop???
Hi Lindsay,
The very first thing that you need to do is to personalize the wireless settings of your ultra range plus router. Since your laptop is wired directlty to the router and is working properly, you can access the router's GUI to personalize the wireless settings. Open internet explorer on the working computer and type http://192.168.1.1 on the address bar, you will be prompted to enter a username and password, by default there is no username and the password is "admin" if you have setup a password using the setup cd then use that one.
Now your inside the setup page of your wireless router, look for the tab the say's Wireless and below you will find four sub menu namely; Basic Wireless Settings, Wireless Security, Wireless Mac Address and Advance Wireless Settings.
Under Basic wireless settings change the Wireless Network Name(SSID) to something you prefer(this is a must).
For the Radio Band, set to Wide 40Mhz. Wide Channel(9), Standard Channel(11) now click on "Save Settings".
Now got to Wireless Security and for the Mode choose(WPA Personal/PSK Personal) Enter a 8 or more digit password under passphrase and click "Save Settings".
Now your done setting up your wireless router it's now time to connect your desktop wirelessly.
If your using a linksys wireless usb network adapter more or less you have also installed the WLAN Uiltility but personally I use the built in WLAN of XP and Vista.
Using the linksys WLAN Utility for to the Profiles tab and highlight default.
Click Edit and it will provide a list of available network(SSID) that your computer detects.
Select the name(SSID) that you provided the router earlier and click connect.
It will not prompt you to enter the WPA Key also known as passphrase(remember the 8 or more digit password) then click Connect to the Network.
You should now have a valid internet connection wirelessly on your desktop.
Oh and for your 2nd question the answer is No, since you already purchased and installed a wireless usb network adapter for the desktop computer you don't need to purchase a long ethernet cable or move the desktop to where the route is.
Hope this will help you get connected.
Regards
I have been using my Linksys router to connect my home PC's, its been working great, then I bought a laptop and tried connecting to my network but my network key (pass phrase)doesnt work, im sure it is...
Since you are confident that the key is correct, make sure your security and encryption types on your laptop match what is set up on the router. For instance, if you the router is set up for WPA with TKIP encryption, the laptop must be set up for the same.
I would connect it through ethernet cable to router and go into router settings in one window and the laptop's settings in another window just to make it easier to match the two up.
2answers
Cannot "ping" 192.168.1.1 (default gateway)
1) yes, referring to the router's IP address.
2) I determined the IP addresses of all my computers and tried to "ping" them but could not "ping" any of them. I can "ping" the IP address of the computer I am working from but I don't think that helps in TS this situation.
3) I'm wondering if my router is fully set up correctly. Do each of the computers have to be "saved" in the router's settings?
Top Linksys Computers & Internet Experts
ExpressFiX
ExpressFiX
Grand Canyon Tech
Grand Canyon Tech
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
