Question about KitchenAid Refrigerators
Side-by-side fridge: the extend fresh control system is beeping, and the display flashes on and off. I've tried resetting, and turning the power off/on. Any suggestions?
  • murphy_tonya Oct 08, 2009
    I held the door open long enough (looking for a button, which I didn't find), and it reset. Currently not beeping! Hopefully it will stay that way. Thanks for the help!
    An expert whose answer gotĀ voted for 100 times.
    Novelist:
  • 149 Answers
Ussually those beep to alert you that the door is open. look for a small button or switch on the fridge where the opens by the hinges and see if the button snapped off, if so you can glue something there that slightly sticks out to fix it.
Posted on Oct 08, 2009
Left door of F/P fridge part for a week. Now red light is flashing, beep stopped but fridge not cold enough.
Hello Jennifer;
My name is Peter. I am a retired field service refrigeration technician.
No. Your problem is not defrost.
The normal temperature setting for a freezer is -2 to +2 degrees F. or -18.8 to -16.7 degrees C. The fresh food section should be set at 35-40 Degrees F. or 1.6 to 4.4 degrees C.
Reset your temperature controls to the recommended settings.
Up plug your unit for 10 minute to power down. Plug your refrigerator in.
Jan 01, 2015 | Refrigerators
How can i get my fridge to stop beeping?
Good Afternoon Friend,
I understand you want to know how to make your Frigidaire refrigerator, model# FRS3R5EMB, stop beeping. Please try pressing the "On/Off" button on the Fresh Food Temp side of the control panel. If that does not work, I suggest resetting your appliance, by either unplugging it or shutting the power off at your home's circuit breaker, for 3-5 minutes. Restore power. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your appliances status has changed successfully. Hope this is helpful.
-Best Regards-
WP
Jul 05, 2014 | Frigidaire FRS3R5EMB Side by Side...
FRIGIDAIRE SIDE BY SIDE FRIDGE SIDE TOO WARM
adjust the temp on the freezer setting where it links up with the frig'...
Feb 03, 2013 | Refrigerators
My Frigidaire PHSC239DSB2 side by side's digital temperture display is flashing a 2 on the freezer side & the fresh food sides temperature went up to 47 degrees, but has no flash. What is goin
HI this is a difficult one without a visual but i would sugest u disconnect the power supply.re-connect everything again and re-start.reset temp if not pre set.and try before u call an engineer.good luck.Ali
Jun 18, 2012 | Frigidaire FRS26H5AS Side by Side...
Can you tell me what a flashing # 4 means on the fresh food display,when I try to set temp.the flashing # 4 keeps coming back. the fridge temp. is too cold and freezes everything.
Hello Bryce,
I found a manual, although I cannot be sure it is for your exact model, it is located HERE. This is what is stated under "Temperature Adjustment"
IF TEMPERATURE DISPLAYS FLASH... If ever you see both temperature displays continously flashing, it may indicate that the control system has detected a performance problem. Call your service representative, who can interpret the flashing message. To maintain temperatures, a fan circulates air in the refrigerator and freezer compartments. For good circulation, do not block cold air vents with food items.
This is located under "Turning the Cooling System On and Off"
TURNING THE COOLING SYSTEM ON AND OFF You can disable the cooling system in your refrigerator by pressing the On/Off button located on the left side of the temperature control panel. To ensure that you do not accidentally turn off the cooling system, the button does not work unless you press and hold it for three seconds. Once you disable the cooling system, all refrigeration to the freezer and fresh food compartments stops. To turn the cooling system back on, you must again press and hold the On/Off button for three more seconds.
If the manual I selected is not the one for your particular machine, there are others located HERE. There are various ones only differing by a "upgrade" letter on the end, perhaps for different models of different manufacturers, produced by the same company.
I hope this is of some help
Joe
Sep 20, 2011 | Frigidaire FRS3R5EMB Side by Side...
Temp display (fresh food temp) has flashing # 4. Any idea's? Mod# GLHS36EFSB1 - side by side fridge
my Frigidaire showed the number 4 on the display after power outrage. And the temp is really warm inside. I unplug the power and plug it back 1 minute after. now I can set the temperature and it's working fine.
Mar 26, 2010 | Frigidaire GLHS36EESB Side by Side...
The temperature display keeps on flashing and will not stop. It is on both the freezer side and the fridge side.
Either the fridge's controller is trying to indicate a failure, or a temporary power failure has reset the fridge and it's demo mode. Demo mode is the mode used in stores where the lights and stuff will work but the motor doesn't run. Exiting demo mode may be as simple as unplugging it again for a few minutes, but you should look in the troubleshooting section of your manual to find out for you specific model.
Feb 27, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
FrigidLights on in freezer, off in fridge. Compreaire FSC23F7DSB8
did you clean the compressor compartment while you had it pulled out? its possible you pulled a wiring harness loose removing power from the fresh food side of the refrig and from the comp.
Jan 22, 2009 | Refrigerators
Frigidaire refrigerator making beeping sound
Unplug your refrigerator from the ac outlet, and 0open theref door for approx. 5 minutes. Then plug it again, after you hear the beeping close the door. wallah it's fixed.
Dec 21, 2008 | Frigidaire FRS3R5EMB Side by Side...
Beeping sound
ok the only other option the latch located in the fridge has a loose wire which need to repaired by a fridge tec but also if the fridge seems like its not getting cold the thermostack that make the fridge cold may be malfunction
any how it needs repair
Jul 07, 2008 | GE Profile¿ Arctica® Energy...
Refrigerators Logo
55 people viewed this question
Top KitchenAid Refrigerators Experts
John Tripp
John Tripp
vince
geob91
Are you a KitchenAid Refrigerator Expert? Answer questions, earn points and help others
