This problem should be removed because:
Problem with Goodman CLQ36AR49 Air Conditioner
Goodman Condenser - Heat - Buzzing Noise every 60 seconds
I have a Goodman Condenser unit on my heat pump thats about 5 years old. Recently I noticed an intermittent buzzing noise coming from my fuse panel and I was able to correlate it to my Heat pump turning on and running. When it first turns on for heating and thereafter at an interval of every 60 seconds it makes an electrical buzzing noise at the condenser unit, this causes a similar noise at my fuse panel. It sounds like an electrical short, but the breaker (40 Amp) never cuts off. I've turned the unit off since it's only used to heat the basement.
What would be causing this? Seems to be very specific to a 60 second timer in the condenser unit.
Any help or advise is appreciated.
Dave B.
Solutions (2)
Best Solution
It could be your compressor trying to start but not being able to do so. It shouldnt happen that often but in cold temp the overload protector may cycle that quickly. I reccomemnd to have it checked to salvage the expensive compressor.
You stated capasitor was checked . if cap. is ok sometimes start terminal wire will burn into at compressor or you may have a loose connection causing a voltage drop (more than 10%).If both check ok try a hard start kit. Who knows it might start. good luck
condensing unit continues to run
condensing unit continues to run after air handler is stopped. Problem is intermittent. Thermostat replaced. Suspect air handler relay....
i have a cple18-1c at my home. it is making a
i have a cple18-1c goodman unit at my home. it is making a steady buzzing noise when the unit is on. I took the fuse out and when the cycle...
buzzing sound fan not running
the fan is not turning and no cold air blowing constant buzzing sound like something locked up but fan spins by hand.
where would the reset switch
where would the reset switch be located on a goodman ac unit
Add Your Solution
The oil can sized piece just of the unit outside...
The oil can sized piece just of the unit outside looks like a snowball and the line 20 feet inside our house has heavy...
Hi I have a JVL mobile air conditioner with E2...
Hi I have a JVL mobile air conditioner with E2 error, starts ok works for awhile then E2 have tried suggestionso far no...
NEED SERVICE MANUAL FOR GOODMAN PHK036-1 PACKAGED
NEED SERVICE MANUAL FOR GOODMAN PHK036-1 PACKAGED HEAT PUMP A/C UNIT
Fix-O-Meter
1,124
1,124 people viewed this problem
- 0 people are following this problem. Be the first!
Top Goodman Air Conditioner Experts
Verification:
Please enter the characters below to complete your post
Can't read it? Try a different one
To answer your question yes $1200 is a good estimate to replace the compressor correctly and by correctly i mean that when a compressor fails there is usually some reason why (occasionally they do fail when all has ben ok but here are some things to make sure the company has checked). First killer of compressors is extremely cold liquid freon being drawn back from the indoor coil due to low air flow, or any number of reasons. This is called liquid slugging a compressor and its very bad for them. Usually the indoor coil has become clogged with mold and debris. Also the next thing that can and will kill a compressor is contamination in the freon system. Any moisture turns to corrosive acid and eats away at the internal electrical windings of the compressor. Also when a compressor fails it can further contaminate the system with acid due to electrical arcing inside the freon system. So when i say correctly installing a new compressor it means to install a liquid and suction line filter dryer (these act as a filter for moisture,debris,and helps neutralize acid) also a new contactor and a new run capacitor. Also there is a product called acid away, it is a oil additive to further neitralize acid in the new compressor. (this product is only needed if an acid test indicates high acid content). So i believe $1200 a good estimate if he is going to do everything i would (as would any good refrigeration mechanic). Also you guys may want to just replace the entire outdoor unit. Usually i recommend that to my customers who have an older unit that has a bad compressor. It should be only like $1800-$2000 for the whole new outdoor section. You will also have better warranty with a whole new outdoor section. Amana units (which are now made by goodman) have a 10yr all parts warranty. You cant beat that. Also in 2010 no new units will be built that use R22 (the kind of freon that your unit has) so your entire system will have to be retrofit to R410a (the replacement freon). Also even with a new outdoor unit a acid test is recomended and definately have the indoor coil inspected for any air flow problems. It would make sense to me to replace the indoor coil as well now so you wont have to worry about this system for many years. Hope this helps.....
