Question about Volkswagen Car Audio & Video
I jumped my car with jumper cables and now the radio does not work
  • 30 Answers
Is it a factory or aftermarket radio? In any case you'll want to check your radio fuses. On aftermarkets there is typically a ten amp fuse bhind the deck and your owners manual will tell you where your factory fuse box is.
Posted on Oct 09, 2009
I have a 98 isuzu rodeo and my friend hooked up the jumper cables wrong one day and now none of my dash lights or any of the switches on my dash work (4x4, cruise control, etc.) and it's stuck in 4x4
What can be damaged by hooking jumper cables up the wrong way ...
https://answers.yahoo.com/question/index?qid..
May 3, 2011 - My car battery was dead so we asked someone for a jump and when we tried starting the car, the negative jumper cable on my car started ... what happens when you hook up car battery cables wrong?
Apr 12, 2013
Hooked jumper cables up wrong and radio won't work, why?
May 26, 2010
Hooked up jumper cables backwards now my car wont start no ...
Apr 2, 2009
What happens if you hook up jumper cables backwards on a car ...
Oct 4, 2008
More results from answers.yahoo.com
Do not connect your jumper cables backwards or bad bad ...
https://www.reddit.com/.../do_not_connect_your_jumper_cables_...
RedditOct 25, 2012 - Do not connect your jumper cables backwards or bad bad things ...What I'm trying to say is, does this usually happen when you hook the cables upwrong? ... So basically there is only one way to find out for sure what going to .
Oct 16, 2015 | Isuzu Cars & Trucks
My radio on my 2000 ml320 won't power on after getting a jump start
More than likely, you jumped it without Grounding the Jumper Cables to the Chassis and burned out a fuse. Never Place both the Pos and NEG to the Battery, Always Ground to the Car with the Cables on newer cars. you can cause all sorts of problems if you don't.
Feb 28, 2014 | Mercedes-Benz Vehicle Parts & Accessories
Ford taurus 2000 ses won't start makes clicking sound when turning the ignition...all power on lights,radio
Hi, this is often caused by a low battery. Try a jump start. If that works, remove the jumper cables and check the voltage at the battery with the car still running. Voltage should be at least 14 volts DC. If not, remove the alternator and have it tested at your local parts chain. If the jump start doesn't work, please get back to me.
Apr 15, 2011 | Ford Taurus X Cars & Trucks
A freind went to jump my battery off he reversed his lead on the jumper cables when he went toput on his battery I changed my battery and now the radio won't work
Check your fuses to your radio... the reversed polarity may have been blown... Alot of aftermarket stereos have a fuse in the line to the power of the radio ..be sure to look there too.
Aug 28, 2010 | Ford Ranger Cars & Trucks
Jump start won't work on my 2004 Touareg V6
It all depends on several variables.
  • Were the connections clean? (battery cables and posts
  • Did you have a good connection with the jumper cables? (some battery posts are hard to get at and clamping a jumper cable can be difficult)
  • How long were the jumper cables left on? (weaker batteries will require leaving the jumpers on for a longer period of time (15-30 minutes)
  • Was the other car running? (jumping battery to battery will have the same effect as jumping alternator to battery)
  • Was the car with the dead battery warm or cold? (if the car you're trying to start was hot, it may not be the battery that's at fault
If the car you're trying to start is cold, ensure your battery connections are clean (manually cleaning is better but there are some very good sprays that work pretty well.  Leave the jumpers on for a longer period of time with the other car running.
I hope this solves your problem.  Best of luck.
Greg
Jun 19, 2009 | 2005 Volkswagen Touareg
2002 Stratus Car Battery and Radio
Could be the radio is drawing current. Get an auto electrician to take a look and find the fault.
Jun 18, 2017 | 2002 Dodge Stratus
Jumped dead battery; radio won't work
Sounds like they connected the cables backwards,there maybe a direct fuse on the back of the stereo that got burnt up.If there's not a fuse on the stereo than its probably damaged beyond repair.
Apr 10, 2009 | 2004 Ford F150
Car Audio & Video Logo
55 people viewed this question
Top Volkswagen Car Audio & Video Experts
xxxxxx xxx
Colin Stickland
Colin Stickland
David Payne
David Payne
Are you a Volkswagen Car Audio and Video Expert? Answer questions, earn points and help others
