Question about Kenmore 63792 Microwave Oven
Keypad is inoperative - Kenmore 63792 Microwave Oven
  • Kenmore Master
  • 9,098 Answers
Is it possible that some spray cleaner got into the controls?
I always recommend that users instead spray cleaner on a soft cloth then wipe the control panel.
Also, I always recommend non-ammonia cleaners since ammonia can crack and damage plastic.
Otherwise, the spray can get into the controls and lock it up or make it act odd.
If it does not dry out over time, it may need to be manually dried or blown out.
The keypad may be damaged or worn out, or control unit may be damaged.
On some models, the membrane keypad is not available as a separate part, so you would have to order the control panel frame assembly which comes with a new keypad.
In this case, you simply move your circuit board into the new frame. That is a simple do-it-yourself job.
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
Then you unplug the keypad (as per the photo below) and move the circuit board into your frame.
Some connectors on the relays may have a lock:
You can find handy exploded views and get part numbers by entering your full model number at the Sears Parts Site.
A full Sears/Kenmore model number has 3 digits, a dot, then 8 more digits, such as ###.########
Once you have the Sears part number, you can usually get parts cheaper here.
If you might be interested in having us so the work for you, we charge $39.95.
Feel free to contact me directly.
William E. Miller
prototech@usa.net
http://www.microwavedisplay.com
Posted on Oct 10, 2009
Tappan 5030 microwave oven fuse is ok but no lights on keypad come on
see the causes and fix it. God bless you
Touchpad dead If you have a stuck key or non-responsive key, most of the time you will have to replace the keypad for this microwave oven repair. If your keypad is connected to your control board by a flat ribbon wire, try disconnecting it and clean the silver contacts with an ordinary pencil eraser. After cleaning, plug it back in and try it. If it doesn't fix it, replace the keypad unit. Some units actually have keypad tests to confirm your diagnosis of a bad key.If your keypad and control is the same unit, replace that unit. Another note, unlike stove/oven keypads and controls, most microwaves do not have error codes or tests to distinguish whether it is truely the keypad or control. Most of the time, it is the keypad that needs replacing, but a small percentage of the time it can be the control. Check the tech sheet if they can point you to the right part.
Oct 10, 2012 | Tappan TMS062E1 Microwave Oven
Nlkeypad numbers inoperative
The keypad control board will probably need to be replaced, keep in mind it is expensive part and it does not include labour.
Jun 30, 2012 | Sharp R-426H Convection Microwave Oven
Display and touch buttons inoperative on MMV4205BAW Microwave Oven. Only abt 2 yrs old...
The keypad controller has probably developed a short in the membrane of the keypad, it must be replaced in order to get it up and running, but I suggest a maytag repairman to address this.
Feb 21, 2011 | Maytag MMV4205 Microwave Oven
I have a Samsung Induction range and it has an SE error code on the rear left burner contro. I cannot get the code to clear so my whole range top is inoperative. How can I fix this.
"SE" error means you have a shorted membrane keypad.
There should be a "mini-manual" (tech sheet) hidden inside the unit behind the control panel or in the back cover, which is very helpful when troubleshooting, testing, and locating components.
You can find helpful exploded view diagrams and order parts by entering your full model number here.
Jan 27, 2011 | Samsung Microwave Ovens
Magic chef mcb780w
MCB780W - May 27, 2017
If and when an oven is coming on or doing anything by itself, this is very dangerous and can result in a fire.
So until it is repaired, please leave it unplugged or leave the door open.
You likely have a shorting membrane keypad. MCA's parts site is not showing keypads or controller parts as being available for this model, but they may be.
You can contact them here.
FixYa doesn't notify me when there's a response, so if you have other questions, please contact me directly.
- William E. Miller, AS-EET
pupista@gmail.com
http://www.microwavecontrol.com
Microwave Oven Control Panel Repair Nationwide
"Recycling by repairing since 1982"
May 22, 2017 | Microwave Ovens
GE microwave (jvm1740dm1bb) - Control panel inop
That model number is not quite right. I'm going to assume it's JVM1740DMBB01.
(If that's not right, please check the tag inside the oven & reply back)
The membrane keypad is not available as a separate part, so you would have to order the control panel frame which comes with a new keypad.
The part number you need is WB07X11040 and you can find helpful exploded view diagrams and order this part here for $107.00 (compared to $164.75 from GE!)
Feel free to contact me directly (and please remind me of your full model number from the tag on the unit) for more information & help.
prototech@usa.net
Jun 02, 2009 | GE JVM1790 1000 Watts Convection /...
Key pad inoperative
replace the keypad,and spray the terminal with wd40.
Mar 31, 2009 | Goldstar MA-1012 Microwave Oven
Microwave inoperative on rv generator power
Replaced with different microwave. Amanna microwave works fine on both circuits. Would not recommend Whirlpool for RV use.
Thanks
Dec 27, 2008 | Whirlpool 1.6 Cu. Ft. Over-the-Range...
Sylvania Microwave Oven P70D20AL-D5
I would say your keypad is shorting or there is corrosion, grease, or moisture on your control board.
If it's less than one year old, it should be fully covered under warranty. I'd suggest contacting the manufacturer to get it fixed free.
To download owner's manuals for Canadian models of Sylvania microwaves, visit
here.
For help with US models of Sylvania microwaves, contact Customer Service at 1-800-856-8977 (Mon-Fri 9:00-5:00 Pacific Time) or visit Galanz.
Nov 28, 2008 | Microwave Ovens
Microwave oven inoperative
check high voltage section, check magneatron, diodes, etc.
Nov 02, 2007 | Sharp R-1480 Microwave Oven
Kenmore 63792 Microwave Oven Logo
111 people viewed this question
Top Kenmore Microwave Ovens Experts
William Miller
William Miller
Chuck
Are you a Kenmore Microwave Oven Expert? Answer questions, earn points and help others
