Apple a1121 speaskers not working. green light comes on then goes orange but no sound? anyone know whats the problem?
  • 11 Answers
SOURCE: no display
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Cause of power going off: There is a bad 1000uF, 16V cap on the power supply board.
Solution: Replace cap. Radio Shack sells a 1000uF, 35V cap for $2. This will work.
Why did the cap go bad? The cap is too close to a heat sink and over heated.
What does this cap do? This cap sends a signal to an IC which keeps the monitor 'on' after the power switch is pushed. When the cap is weak, AC ripple voltage is applied to the IC and it sends a signal to shut the monitor off.
Opening the Monitor: These monitors are difficult to open.
The two plastic pieces snap together and must be pried apart with a flat screw driver.
After removing the stand, you need to insert a flat screw driver at the bottom of the screen where two slots are located. Then work the screw driver around until the two plastic pieces are separated.
Remove the cover plate and unscrew the push button circuit board.
Unplug the monitor cords from the driver board and remove the screen.
Unscrew the mounting screws from the power supply board and remove.
You will need to pinch the plastic support in the middle of the board to remove.
Cap Replacement:
Cap is located near a copper heat sink and the value will be on the side of the cap. It will be bulged up on the top. You will see burn marks on the board surrounding the cap. Unsolder the cap.
Install the new cap and solder. Make sure you connect + of the cap to + marked on the board.
Be careful not to solder across joints.
Keep leads long so you can bend the cap as far away from the heat sink as possible.
Reassemble monitor and turn on.
This should solve the problem.
Posted on Jan 01, 2009
SOURCE: kdf-60xbr950 - red light blinks 3 times for a minute and tv turns off
same problem as others 3 blinking green lights then orangey colors then 3 red blinking lights afterwards shuts down fan runs for about 2 mins solution check your door cover for warpage or deformed just a bit under set screw there is a push in switch try and push it in with q tip while holding turn on tv if it works then that door is deformed and defective change it
thanks for solving my issue tv works again very helpfull thanks
Posted on Jan 07, 2009
SOURCE: APPLE iPod HiFi Speakers A1121
Forget other comments - the front is simply a glued-on black metal plate. No screws. No plugs. No obvious way in. If you use a screwdriver you can lever the 1mm thick black plate off the front of the unit to access the screws. Remove the middle speaker first & unclip from main housing. Take a good look & memorise the clip positions as there are lots and it's quite a job getting them all back again! Good luck. Great stereo.
Posted on Jan 31, 2009
javswr
  • 44 Answers
SOURCE: Blue light goes to Orange blinking no sound no picture Screen on
Hi!
Okay, if the screen is white! First, take apart and check the ribbon like cable that goes from your signal board (where you inputs are plugged in) to the lcd controller (under a small metal plate feed the lcd screen), see if loose and or reset! Secondly you either have a bad signal board or lcd controller!
Posted on Mar 04, 2009
  • 14 Answers
SOURCE: orange light on lamp icon on Optoma EP732H Projector
This same thing happened to me, I removed the bulb and put it back in, it reset something and I was able to use the projector again.
Posted on Jan 16, 2010
My ipod wont work it blinks like this (green,orenge,green,orenge,green,orenge) and i dont know what to do.
These are considered the "green and orange lights of death" and could very well mean your ipod is shot. However, I would take it into an Apple Store, and they will work something out for a replacement.
Mar 05, 2011 | Apple iPod shuffle MP3 Player
My ipod shuffle (second generation I think) won't charge when I plug it in it only blinks an orange light. When I try to listen to it it goes back and forth between green and orange lights?
shuffles have light codes to let you know what going on with them, apple should be able to tell you or the guide you got with it (if you got it new) can tell you
Jun 20, 2010 | Audio Players & Recorders
Hi, i have an apple i pod docking station Model A1121. It doe'snt want to play whenever an ipod is attached to it. The lights are all on and flash when pushing the volume button, buut no noise.
my mail id : ravi85_india@hotmail.com
May 20, 2010 | JBL On Time Docking Station for Apple iPod...
I have an Apple iPod accessory -- Model A1121-- that doesn't output any sound.
I can help you troubleshoot your A1121 iPOD docking station.
First of all, can you confirm that your iPOD is seating correctly and securely in the docking port?
For example, when the + or - buttons are pressed on the top, does the green light on the front blink, eventually going red after several pushes?
& Is there any indication that the unit is controlling your iPOD, but simply not outputting sound?
Apr 15, 2010 | Audio Players & Recorders
Doesnt seem to charge
Sounds like the battery is bad in the unit. If it's a first generation unit, Apple isn't supporting them anymore.
You could try hooking up one of these units:
http://www.google.com/products/catalog?q=battery+for+shuffle&cid=14549207473407394801#ps-sellers
Nov 22, 2008 | Apple iPod shuffle MP3 Player
Wont do anything but blink
Go to Did http://www.apple.com/support/ for the manual. It could be a variety of things. The songs could be in the wrong format. Did they come from iTunes?
Aug 31, 2008 | Apple iPod shuffle Second Gen. Silver (1...
Shuffle not working, blinking green-yellow led.
If the status light blinks orange when you press a button, the iPod shuffle buttons are
disabled. Press and hold Play/Pause (’) for about three seconds, until the status light
blinks green.
Jun 25, 2008 | Apple iPod shuffle Second Gen. Silver (1...
1998 ford el xr6, need stereo wiring harness colours
You did not specify if you wanted the wiring diagram for the Expedition or the Explorer, so I got you both. Good Luck
1998 Ford Expedition Stereo Wiring
Constant 12V+ White/Purple Switched 12V+ Black/Pink Ground Black/Green Illumination Blue/Black Dimmer n/a Amplifier Remote Blue Antenna Right Front Front Speakers 6" x 8" Doors Left Front (+) Light Blue/White Left Front (-) Orange/Light Green Right Front (+) Dark Green/Orange Right Front (-) White/Light Green Rear Speakers 6" x 8" Rear Doors Left Rear (+) Tan/Yellow Left Rear (-) Gray/Light Blue Right Rear (+) Brown/Pink Right Rear (-) Orange/Red
1998 Ford Explorer Stereo Wiring Constant 12V+ Light Green Switched 12V+ Yellow/Black Ground Black Illumination Light Blue/Red Dimmer n/a Antenna Trigger Orange/Blue Antenna Right Front Front Speakers 5" x 7" Doors Left Front (+) Orange/Light Green Left Front (-) Light Blue/White Right Front (+) Dark Green/Orange Right Front (-) White/Light Green Rear Speakers 5" x 7" Rear Door Left Rear (+) Gray/Light Blue Left Rear (-) Tan/Yellow Right Rear (+) Orange/Red Right Rear (-) Brown/Pink
Feb 22, 2008 | Car Audio & Video
453 people viewed this question
 Grubhead
Grubhead
