Question about Welding Tools
LINCOLN 225 WELDER OLDER MODEL ABOUT 1985. 16HPENGINE. AFTER GETTING GOOD AND WARMED UP IT STARTS MISSING SOMETIMES BACK FIRES EVENTUALLY DIES. REPLACED COIL REBUILT CARB ,NEW FUEL FILTER AND LINES. CLEANED TANK. RUNES REALLY GOOD UNTIL IT GETS WARMED UP. STARTS GOOD .STARTS RIGHT BACK UP AFTER IT QUITS BUT WILL DIE AGAIN SHORTLY
  • thomasgcurra Oct 08, 2009
    COMPRESSION IS GOOD REPLACED ALL WIRES
  • 708 Answers
Check plug and wire. you will want to do a compression test while you have the spark plug out and make sure you have no blow-by that will cause it to miss.
Posted on Oct 08, 2009
  • Chris Yelton Oct 08, 2009
    did you check the timing?
Lincoln ac/dc 125/225 stray voltage question.We changed the aluminum transformer out for an older copper one because it was weak and the ground would bite you.
The shock can be caused by numerous issues such as high humidity, bad ground connection at the case, etc... the suppressor board is just another name for a surge protector, if it is bad, it could bleed current through the ground clamp
Oct 07, 2014 | Welding Tools
My AC 225-S welder is missing the wiring diagram. The cooling fan wires are pulled apart. Need to know if the fan is 110 or 220 and where to put the wires back. Billy Lynch
Fan Motor MOTOR
2910.0
230.0 AC
Here is a Picture of the wiring Diagram that should be on the inside of the rear cover If this is hard to read Here is a link to the original
Jun 27, 2011 | Lincoln Electric K1297 AC/DC 225/125 Stick...
Lincoln electric ac/dc arc welder model ac/dc
my welder doesn't weld but my electric meeter goes wild.
Jul 25, 2010 | Lincoln Electric K1297 AC/DC 225/125 Stick...
16 hp briggs on 225 welder. older 1 lunger. when it gets heated up it starts missing sometimes back fires then dies. runs perfect until then. replaced or rebuilt most everythingincluding coil. whats the...
Have you checked the compression both cold and hot if not do so... I think what you are going to find is you have very low compression when the engine is warmed up. what is causing this is the intake and exhaust valves grow from engine heat reducing valve clearance which is causing your intake valve to be slight open or no spring pressure allowing compression pressure to open the valve and blow back throughthe intake. Good luck
Oct 08, 2009 | Lincoln Welding Tools
Welder doesnt turn on...
Have you connected the feed from your breaker box to ADJACENT lugs on a dual pole breaker? By code you must use a ganged breaker.
You should use a voltmeter to verify the plug is getting power on teh desired pins.
Sep 25, 2009 | Lincoln Electric K1297 AC/DC 225/125 Stick...
ARC 225 - Can't hear fan.
sounds like you lost one leg of power to the unit,check power source and the the plug on the welder.
Jul 30, 2009 | Lincoln Electric K1297 AC/DC 225/125 Stick...
Cooling fan/ lincoln 225 arc welder
the fan should be pulling air from the front of unit and out the back.
Jun 10, 2009 | Lincoln Electric K1297 AC/DC 225/125 Stick...
Welding Tools Logo
120 people viewed this question
Top Welding Tools Experts
Bill Boyd
Are you a Welding Tool Expert? Answer questions, earn points and help others
