Question about Asko T700 Electric Commercial Dryer
Replacement part for Asko Dryer T700
The plastic cap with the model name and number on it fell off my dryer and broke. What is the replacement part number and how much does it cost? My dryer is an Asko
  • 126 Answers
Call Asko and order it there. Cant imagine that it is a expencive part. I only have the Norwegian partnumber.
Posted on Jan 22, 2008
I have an Asko T700 dryer which is working fine except tripping after half or less of drying time. I can reset and it dries for a while longer, usually tripping again. I have cleaned out the lint and...
Well, if the vents are perfectly clean and unobstructed the only thing I can think of is that the thermal switch designed to turn off unit when overheating is opening prematurely.
Might have to be replaced.
Sep 06, 2017 | Asko T700 Electric Commercial Dryer
The loud banging noise in the spin part of the cycle is usually caused by bad drum bearings. The repair is carried replacing the bearing at the back of the drum. Such kind of replacement is carried disassembling most of the appliance to reach the back of the tub. If you have not done similar repairs before it may be better to call a technician ringing the Asko support number listed on the owners manual.
Sep 09, 2011 | Dryers
I have an ASKO T700 and it heats up but does not tumble.
belt around the drum fell or broke off
Oct 29, 2010 | Asko Dryers
Trying to replace drive belt. How do I get the new belt around the drum?
hey to get the belt on the asko dryer you need to take all the screws out of the back of the dryer back plated dont worry you can do this take the top plate off 2 then remove the cap from the optional side vent pipe if applicable lay dryer on to the front side down position lift the back plat a littlew say 5 inches reach in and take the vent plastic manifiold out by pulling it right an inch or so then pull it toward you (back ) when you get it out you can see the motor wih the belt idler pintle (axle) if your belt idler has fallen loose locate it and or remove it temporarily figger out hay the idler fits to the belt onto the motor houseing (unit) pull belt off the drum towards you remove between the space between the back plate and dryer drum to preplace instale in reverse order note 1 wire you will need to reach into the bak at top to reatrtache the plastic clip so you can screw it up to keep it from rubbing ect and good luck
Oct 18, 2010 | Asko T700 Electric Commercial Dryer
How do I replace the belt on my Asko T761 dryer? Do I go in thru the front, the back? Are there instructions on-line for belt replacement?
How to install a belt on ASKO dryer
Belt Type: Flat belt with ribs
Installation Notes: Ribs go against drum
You could Refer to :-
It would be a Generic one but would help you.
Let me know, if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Mar 11, 2010 | Asko T761 Electric Dryer
Asko T700 dryer does not heat up, and start button does not work unless held down.
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair - The
Dryer is not Turning
Dryer Repair - The
Dec 07, 2009 | Asko T700 Electric Commercial Dryer
Asko T700 dryer
Seems like you need new drum rollers. If one(or both) is bad, the drum will rub in the plastic.
Dec 10, 2007 | Asko T700 Electric Commercial Dryer
Asko T700 Electric Commercial Dryer Logo
219 people viewed this question
Top Asko Dryers Experts
Tim Whalen
Dan Webster
Dan Webster
Are you an Asko Dryer Expert? Answer questions, earn points and help others
