Question about GE Nautilus 24" Built-in Dishwasher
No water getting into unit
We have a multi-family home which has 3 new Nautilus GE dishwashers. The tenants in one of the units is complaining that water is not getting into the dishwasher. We have tried adjusting nobs to the unit but have been unsuccessful in determining what the issue might be. Can you suggest anything we can do?
  • 715 Answers
Water control valve
Posted on Oct 08, 2009
How does my ge dishwasher heat the water
Suggest:
1)check if the hose was mistakenly attached to the cold water line instead of the hot water
2)if you mean the water is not being heated for the "sanitizing cycle"....then the heater element may be burned out or have a bad connection....or you have not programmed/selected the "sanitize" cycle.
3)if your unit was working OK and this problem just started....then I expect the problem is 2)
good luck
May 28, 2014 | GE Nautilus 24" Built-in Dishwasher
Coroding on the racks inside the dishwasher
poor quality, nothing to do about that, you can buy some paint that is water and heat resistant, sand down the rust and prime then paint it again, or complain if it is a new or new-ish washer (no more than 2-3 years)
Nov 12, 2009 | GE Nautilus 24" Built-in Dishwasher
We have a multi-family home and all units have new Nautilus GE dishwashers. Our second floor tenant is complaining of water not getting into the unit. We have tried unsuccessfully to figure out the...
There are two reasons that may cause the water not to enter the unit.
  1. Water-inlet valve. It lets water enter the machine. If this valve is defective, you need to completely replace it. It's usually located behind the lower access panel on the left or right side. It's the device with the main water line (usually copper) from the house, a rubber tube to the dishwasher, and two wires attached to it.
  2. Float switch.It is a small electrical switch located right below the dishwasher "floor." Above the switch, on the inside of the dishwasher, is a plastic cylinder that floats up as water fills the dishwasher. If this switch is defective, or if the plastic float gets caught or trapped in the raised position, the water can't enter the dishwasher. If the float switch is defective, you need to replace it.
Oct 08, 2009 | GE Dishwashers
The start timer control cycles but nothing happens. The motor seems to gurgle while attempting to fill with water - but no water comes through. We have had this problem before and the repair person...
I bought a new one and installed it myself. hardest part of installing was taking the old unit out. I compared the cost of a second repair of a 10 year old dishwasher vs. purchasing a new one. We also checked the pump and solenoid to find problems that caused the water not to enter the unit. The new one we purchased is much better, quieter, and Energy Star.
Aug 27, 2009 | GE Nautilus 24" Built-in Dishwasher
Soap and water coming out the front of the dishwasher
I would think that the gasket is not doing the job, can you pull the gasket together to decrease the gap. If not then try another gasket if it's not on warrentee
Apr 18, 2009 | GE Nautilus 24" Built-in Dishwasher
GE NAUTILUS DISHWASHER
sounds like the water outlet has a leak - probably a simple 'o'ring problem - these can wear.
Aug 17, 2008 | GE 24-7/8" Convertible Portable Dishwasher...
Water
reach inside your d/w and jiggle the mushroom shaped float switch located on floor of d/w. should move freely up and down if its stuck up(or something lodged under it your unit wont fill with water
Mar 30, 2008 | GE 25 in. Nautilus GSC3400J Free-standing...
GE Nautilus 4800 Dishwasher/Shuts off/ No water draining out
It may be the motor start capacitor or the motor or the wiring to it. Some units have a built-in switch that shuts the unit off if the motor doesn't start turning after a short interval. However, if it drains it usually means the motor runs enough to pump it out. These units usually stop draining when the fill switch opens at the lower level.
Nov 29, 2007 | GE Nautilus 24" Built-in Dishwasher
Ge nautilus dishwasher
Check inlet valves as if you have 2, it may fill using 2 inlets (hot & cold) but only rinse on using 1 ((cold only). So if the cold inlet is faulty, then you will only notice on the rinse. If thats not it then chances are it is the controller unit. regards
Jul 22, 2007 | GE 25 in. Nautilus GSC3400J Free-standing...
GE Nautilus 24" Built-in Dishwasher Logo
151 people viewed this question
Top GE Dishwashers Experts
Mike
jdthefixer
Dan Webster
Dan Webster
Are you a GE Dishwasher Expert? Answer questions, earn points and help others
