Question about RCA P52926 52" Rear Projection Television
RCA MODEL D61134
How do you remove the front frame to clean the inside of the TV?
  • Anonymous Feb 01, 2008
    How do you just pop it off?
    President:
  • 4,402 Answers
Bottom frame should just pop off
Posted on Jan 09, 2008
Screen came out of 55'' RCA Projection TV and dont know how to put it back in...
Most go in from the rear--careful as very easy to destroy them--if front frame that holds the screens can be removed you remove it and install from rear---screens have a front and back side.......
Nov 04, 2012 | RCA Televison & Video
MY RCA D52W20 TV NEEDED A REPLACMENT PLUG. I REMOVED THE WHOLE PLUG OUT OF THE BACK OF THE TV. I CAN'T FIND WHERE THE PLUG ATTACHES INSIDE OF THE TV?
the rca model itc222 chasis cord or plug runs to the front mains doubler board. this small narrow board is located in front of the large main green board. this board is a small narrow circit board behind that main board... on the right of that board there is the main fuse. next to this is the plug that the main cord plugs into
Apr 10, 2011 | RCA D52W20 52" Rear Projection HDTV-Ready...
I removed the range door to clean oven. Now I
NOTE: The door removal pins you inserted must still
be in both sides of the door.
1.
Grasp the door on the sides with your fingers on
the front of the door and your thumbs on the
inside surface.
2.
Rest the hinge hanger so that it is flat (at the
bottom of the hinge hanger on the bottom of the
front frame slot).
3.
Position the door with the hinge hanger slots
almost parallel to the front frame.
4.
Push up and in until the hinge hanger slots
become fastened to the range. Lower the door
and rotate it slightly from the front to the back
until the slots are fully fastened. The hinge
hanger will be close to the bottom of the front
frame slot.
5.
Pull door open about halfway and remove the
door removal pins. Save door removal pins for
future use.
6.
Close the door.
Dec 25, 2009 | Whirlpool 30" Self-Cleaning Freestanding...
How do i take of the front cover of my 52 inch RCA hdtv? i need to clean out the inside of the tv because spiders somehow got behind the picture...
You will have to remove all the screws on back of TV Front Bottom panel first then you will have more screws that hold Top on in back and under front screen its not as bad as it sounds it just takes awhile to do while your in their clean your mirror and all 3 top lenses to Tubes.
Dec 03, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
There is a spider running around the insider of my TV!
Well you can allways wait until she drops dead but otherwise youll have to take the front lenses off.Remove the screws along the edge a the top and sides at the rear you may also have to pull the front cover (usually plugged in) this is best done with two persons ,one to unscrew and the other to hold the lenses.once the screws are remove you may have to slide up the ***`y.you may want to clean the lenses and miror while your at it. have fun
Nov 01, 2009 | Televison & Video
Need to clean inside of toshiba 50a60 model screen. how does screen come off frame?
TAKE THE SPEAKER GRILLE OFF FROM THE FRONT REMOVE 3 SCREWS LIFT UP ON THE SCREEN AND REMOVE IT TO CLEAN
Aug 24, 2009 | Televison & Video
How to clean inside of screen?
Your tv has two screens on it. The outter screen and the inner screen. The outter screen has a frame around it held on by clips. You can remove this outter screen by gently prying it from the tv. There is a small gape between the outter screen and the tv casing. When prying the outter screen be carefull not to dsanage the tv case or the outter screen frame. Take note of the location of each clips because you will need thses to put the outter screen back on. Clean with a good gentle screen cleaner, (Do Not Use Windex). Philips screen cleaning gel for plasma & LCD works very good. Install the outter screen back on the tv by making sure the clips line up and use light pressure to snap it back in place. Do Not Hit Outter Screen To Force Clips Into Place.. I do this on my tv about once every 6 months or so.
Jan 04, 2009 | RCA P61960 61" Rear Projection Television
RCA P52937 52 in. Rear Projection Television
remove the speaker grille. then there should be a few screws running along the bottom of the screen frame. after removing those screws slide the entire fram up to release the hooks that hold the screen frame to the cabinet. Be careful and unhook the wire clip from the front control panel once the screen frame is loose before you stretch the wires.
Apr 13, 2008 | RCA P52937 52" Rear Projection Television
Screen removal
Screen Removal
There are two types of screens used on this chassis.
Model 1 - with one piece frame around screen.
1. Remove the front grill cloth assembly and remove four
(4) screws along the bottom of the screen frame.
2. Pull out slightly on the bottom of the screen frame and lift
up and out on the top of the screen frame (and screen) to
remove.
Model 2 - with wood piece securing top of screen.
1. Remove the screw access cover plug from each side (near
top) of the TV and remove one screw from each side.
2. Pull up on the wooden strip and remove.
3. The screen can now be lifted out of the tracks and
removed.
Jan 21, 2008 | Televison & Video
Need to disassemble Mitsubishi VS-6041 60 in Rear Projection
Wow, You are asking for a complete disasemmbly. If this is necessary, you have to remove any screws you can find that are connected to the front panel. Usually they are in the top of the set ( you'll find them after removing the mirror panel and mirror ). I wouldn't remove any tubes as the tube convergence would have to be all reset and that would require a cross hair generator. I do hope this has helped in some way, but all I can do is send you my best wishes as I certainaly don't suggest disassembly if there is any other way. Good luck
Ed
NC Electronic
Mills, Wyoming
Nov 24, 2007 | Mitsubishi VS-6041 60" Rear Projection...
RCA P52926 52" Rear Projection Television Logo
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
