Question about Hawking (HMPS1U) Print Server
HMPS1U print server doesn't work for the Cannon
I have been able to get the HMPS1U print server to work on another printer, but I would like to have it work for the Cannon Imageclass D780.
The Cannon is a multi-function USB printer/copier. Unfortunately the Cannon printer requires that Bidirectional Support be enabled in order to print.
If I enable Bi-directional Support and connect the Cannon printer to the HMPS1U, the Cannon's status window gives me this error:
"Incorrect Port: The Device is connected to a port which is not supported. Check the port."
On the printer that works with HMPS1U, if I enable Bi-directional Support, I can still print through the print server. The first document printed prints immediately, but then the print queue gets clogged with other items (that disappear after several minutes). If I DISABLE bi-directional support, I can print through the print server perfectly on that printer.
After talking with the Hawking tech support, I have set up the printer port manually to these settings as per tech support's instructions:
Port name: USB1_LPR
IP Address: (the one that shows when the Hawking software utility is used)
Protocol: LPR
Queue Name: USB1_LQ
In the printer properties it is set to "use printer online"
I am using Windows XP professional.
thanks
Factory reset
Chapter15 The Init Button
The Init button is used for maintenance: Simultaneously press Init button and turn on (by plugging
in the power adaptor) the Server until USB1 LED indicator simultaneously blinks. After that, the
Server will do the following tasks:
A. Perform a Factory Default of the MFP server, which will restore most of the parameters and
settings to factory default values,
B. Perform a TFTP server. You can upgrade new firmware using any TFTP client tool.
Note: After performing the tasks mentioned above, you have to unplug the power adaptor and then
plug in the power adaptor to restart the Server.
HMPS1U Print Server for Multifunction Printers
Mar 10, 2014 | Hawking (HMPS1U) (DHHMPS1U) Print Server
Cannon mx860 fails to print in black ink. loaded new cartridge, still doesn't print in black. will print in color..
With the Canon MX860 you can removed the print head assembly quite easily and clean it with water. I have posted a youtube video for your reference.
Mar 06, 2013 | Canon PIXMA MX860 OFFICE AIO-2.5IN LCD...
I have a cannon ir3300i printer is not taken print..computer says out of paper printing..but paper is available in printing..how to resolve this query mail id internetstation2012@gmail.com
try turning off both devices - start you computer first, then start your printer and see if that fixes your issue. if not try again this time leaving out the plug that connects the computer to the printer and then when the computer is turned on turn on the printer then plug it into the computer
Aug 08, 2012 | Canon (6981A002AA) for imagerunner 2200,...
Keyspan's drivers won't work on Win7 . . . Install MS's Virtual PC. Add usbd.sys to windows/system32/drivers (virtual box doesn't think it needs to load the virtual usb drivers, so i
1. instal server utility on Windows 7
2. right click icon choose properties
3. select compatibility tab choose vista sp2
now run it and presto......
regards, dean
Jul 06, 2012 | Keyspan USB Server US-4A (d47710) Print...
I've configured my desktop Brother HL2040 to share but I can't print from my laptop.
Make sure you've got the firewall set to allow printing on the computer working as a print server.
Another simple solution is to pick up an ethernet or wireless print server unit. It's going to cost more, but it's typically very reliable, and doesn't depend on another computer for printing.
Jun 25, 2011 | Brother HL-2040 Laser Printer
I need a hard disk drive for a cannon 2200 imagerunner the copier keeps showing a error message
If you have a Service Contract with the local CANON office, call them, and get them to make a service-call to fix your printer.
Jul 17, 2010 | Canon (6981A002AA) for imagerunner 2200,...
Xp pro pc cannon ip2600 printer and sony vaio laptop how do i get printer to work for both laptop has window vista
Put The drivers on both of your laptops Just put Cd in laptop and way you go follow and plug and play Set up thanks
Oct 03, 2009 | Computers & Internet
TrendNet PrintServer TE100-P1P does not print
I get the same error connecting to an OfficeJet K60. Have been successful with my Macs, but not with XP.
Jul 08, 2009 | Parallel TRENDnet TE100-P1P 1 Port Print...
Netgear wireless ps121 won't connect to cannon MFP 4100
Try to disable Zone Alarm temporarily and print.
Also, can you login in to your wireless router and see if print server is on the IP list?
Apr 03, 2009 | Computers & Internet
Cannon MP 160 Printer
you need a bluetooth print server to plug into the printer
Feb 20, 2008 | Canon PIXMA MP160 All-In-One InkJet...
Computers & Internet Logo
212 people viewed this question
Top Hawking Computers & Internet Experts
Steve
Mike
Are you a Hawking Computer and Internet Expert? Answer questions, earn points and help others
