Question about Sony KDS-R60XBR1 60" Projection HDTV
REPLACING DIFFUSION PLATE/PICTURE SCREEN
I HAVE THE SONY (KDSR60XBR2) MODEL WHICH LOOKS LIKE THE KDSR60XBR1 MODEL. THE VACUUM HANDLE FELL AND PUT A HOLE THRU THE PICTURE SCREEN. THERE IS TWO SCREENS A DARK IN FRONT AND A CLEAR CLOSE BEHIND THE DARK WHICH SONY CALLS A DIFFUSION PLATE. HOW DO I REPLACE THE PICTURE SCREEN/DIFFUSSION PLATES WITH THE NEW ONES I PURCHASED?
I need help to replace front diffussion plate and clear screen
Posted on Feb 07, 2010
My LG Television have 6 lights in the picture?????
If you have a LED back light LG TV, the problem is the LIGHT DIFFUSION PLATE on top of each LED diode dropped off, you may use supper glue to glue it back, but be aware that the diffusion plate has polarity, if you put it in a wrong position, it will not distribute the LED lights evenly, usually the plate has a small tab on the out-circuit edge, you may look at the other none-drop-off plate to glue it back. please do not put any glue in between the plate & the LED diode, only little glue to cover the three original glue spots.
Apr 22, 2017 | LG Televison & Video
Sony kdsr60xbr1 problems
Hi, since 2006, you have replaced many parts, why don't you try replacing your TV with new advanced model. Your all problems will automatically fixed
Dec 30, 2013 | Televison & Video
Kenmore cluch handle model 1227 I loosened the clutch handle to wind a bobbin and it fell off. I do not know how the plate and washer go back on so I can tighten it.
It probably can only go back one way. Try the plate first, then washer, then the clutch handle itself. There should be a screw in the face of the clutch knob. Tighten the clutch knob or disc all the way, then tighten the screw down. The screw limits how far the clutch can be loosened.
Aug 18, 2011 | Vacuums
The TechDrive Pedal on my Kirby G6 fell out of the back of my vacuum cleaner. I removed the screws from the metal plate one the bottom to try to see if something had come a loose. Can you send me a diagram...
This requires removal of the transmission assembly and replacement of the pedal assembly - it cannot be repaired. The handle and upper motor shell must be remove to access the transmission assemby. There are two screws in front, and two under the plastic switch plate.
Jan 18, 2011 | Kirby G6 Bagged Upright Vacuum
I recently moved and the movers broke the front screen of our Sony KDF46E3000 rear projection TV. Is that surface screen available for replacement? Can I do it?
There are two layers in front screen, check both layers are damaged or not.
Part numbers are as follows:
321007211 ... PLATE (E46L), DIFFUSION (KDF-46E3000 ONLY) [front layer] price is $148
321007311 ... PLATE (E46F), DIFFUSION (KDF-46E3000 ONLY) price is $128
Available in Sony Part Store, put part number in search box, hit enter to get result.
Yes, average handy person can replace it, need to take off front screen frame by removing screws at rear sides of tv.
Hope these info will help you.
Thanks.
Jan 03, 2011 | Sony KDF46E3000 46" Television
Sony wega kdsr60xbr1 Its picture is a greenish
If this is the model I am thinking of, don't bother fixing it. Call up sony and they will should offer you an new sony bravia lcd tv. You can either get the free one or upgrade from the free one to a bigger one. I guess that there is some recall with the light engine and sony is giving out this offer. This happened to my grandma to her 42" grand wega. The ending result was that she got a 46" 120hz sony bravia tv for, if I remember right, $250. I hope that this helps. Good luck and happy new years!!!
Jan 02, 2010 | Sony Grand WEGA KDF-60WF655 60" Rear...
My screen accidentally got broken but TV was working fine...is there a way to get a replacement screen? can I buy the materials to do it myself?
Sony KP-57WS510 has 3 layers front screen and I do not know what layer is broken. Part number of all 3 screens are as follows.. count it as front, middle and rear screen layers..
4-090-881-11 SCREEN (57), CONTRAST (KP-57WS510 ONLY)
4-095-924-11 PLATE (57WL), DIFFUSION (KP-57WS510 ONLY)
4-081-950-11 PLATE (57WFV), DIFFUSION (KP-57WS510 ONLY)
Also check HERE for your TV screen.
Aug 04, 2009 | Sony KP-65WS510 65" Rear Projection...
I need to replac the screen (diffusion plate) on sony kdf60wf655
For one, a ton of money.  The screen is usually 2/3rd of the cost of the TV.  Second, I believe you will have to either ship or drive the TV to Sony as I don't believe they have in-home service.  You should start by calling Sony or visiting their website.
Mar 24, 2009 | Sony Grand WEGA KDF-60WF655 60" Rear...
Broken the plate( F and L )difussion
Here are part numbers of plate diffusion of Sony KP-48S75 TV
4-070-280-11 PLATE (L), DIFFUSION
4-058-455-11 PLATE (F), DIFFUSION
Oct 24, 2008 | Sony KP-48S75 48" Rear Projection...
Blue discoloration
I have replaced alot of these light engines for this problem. Yesterday I received a letter from Sony saying they are going to give an additional warranty to have the optics replaced. I just checked, your model is one of them and Sony is replacing the optic block under an extended warranty, regardless of the purchase date, until the end of October 2008. Contact Sony for an Authorized Service Center in your area or go to this site to read about it: http://esupport.sony.com/perl/news-item.pl?news_id=185&mdl=KDSR60XBR1 Have this repair done on your set and it should save you about $1300.00 to $1500.00 on the repair. Hope this helps.
Mar 28, 2007 | Sony KDS-R60XBR1 60" Projection HDTV
Sony KDS-R60XBR1 60" Projection HDTV Logo
351 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
