Question about Sony FD Trinitron WEGA KV-32FS100 32" TV
Lines and double screen
Horizontal lines and mirrored double screen,
It ended up being my cable company's problem and I rebooted my cable box & all was well
Posted on Oct 09, 2009
Lcd vertical yellow line and Black Horizontal Line with Double Image Below
Sounds like you pulled the TV apart, good luck. Hope you earthed yourself. You could try a replacement t-con board. if that was the problem. http://electronicshelponline.blogspot.com.au/2012/06/how-to-replace-faulty-tcon-board.html
Apr 08, 2014 | Vizio Televison & Video
How to hang a mirror without nails
Instructions
    • 1
      Select a location to hang your mirror by holding it up on different areas of the wall. If possible, ask another person to hold the mirror while you stand on the other side of the room to judge the best spot for displaying it. Once you've decided on a spot, mark the wall lightly with a pencil along the top and bottom edges and/or corners of the mirror.
    • 2
      Place a level against the wall horizontally at the top pencil marks and tilt it up and down slightly until the bubble centers inside the glass tube in the level.
    • 3
      Draw a line lightly with your pencil along the edge of the level.
    • 4
      Lay a thick towel or blanket on a flat work surface and place the mirror on top of it, reflective side down.
    • 5
      Wipe the back of the mirror with a damp cloth to remove any dirt or debris sticking to the surface and wait 15 to 20 minutes for it to dry. In addition, wipe the wall down and wipe or air-dry it. If either surface has greasy or oily stains or other marks, wash the surfaces with mild detergent, rinse thoroughly with a damp cloth to remove any residue, then wipe or air-dry.
    • 6
      Affix strips of heavy-duty, double-sided, mirror-mounting tape to the back of the mirror along the sides, top and bottom.
    • 7
      Remove the paper backing from the double-sided tape strips, align the top of your mirror with the pencil line on the wall and press the mirror firmly against the wall.
    • 8
      Erase any visible pencil marks.
Tips & Warnings
  • If you need to mount a heavy mirror without putting a hole in a wall, hire a professional mirror installer.
  • Never touch the adhesive surface with your fingers because you can transfer oil to the adhesive that can reduce its ability to bond to surfaces.
Related SearchesReferences
Mar 29, 2013 | YouTube Videos
60 inch Akai DLP TV, PT61DL34 horizontal lines on the screen.
Its a DLP and the optical unit has thousands of tiny micro mirrors that cannot be adjusted.
Apr 29, 2012 | Televison & Video
I have horizontal lines on my LG ED 500 laptop
I just want to double check, the horizontal line that you have on your screen, is it big as hair line or almost?
Please let me know once you read this.
Jun 15, 2011 | LG E500 Express Dual Series Notebook PC
I have flickering horizontal lines...Is it the bulb? I have not replaced it in 3 years.
flickering horizontal lines are cause sometimes by the mirrors or the DLP chip then you might have to replace the mirrors because they might be dead hope this helps
Jan 02, 2011 | Toshiba 62HMX84 62" Rear Projection HDTV
Horizontal Lines in Picture, Picture Possibly Dimmer
The dimming is usually caused by the mirror needing polishing. The lines floating across the screen is usually caused by failed caps on the FMT board you can get the V26 FMT repair kit from
http://servicemanuals.vstore.ca/product_info.php/pName/v26-dlp-fmt-pwb-repair-kit/cName/repair-kits
Jul 07, 2010 | Mitsubishi WD-52525 52" Rear Projection...
I have a 2006 RCA model R52WH73. The horazonal lines suddenly went to being concave lines and now you see a double image.
horizontal circuit problem .. vertical double image or horizontal.. check screen voltage and focus setting on board. CAUTION: EXTREME HIGH VOLTAGE. QUALIFIED SERVICE PERSONELL ONLY .. serioius high voltage..
Dec 15, 2009 | RCA Televison & Video
Toshiba TV -- horizontal line
sounds like you have feild colapse.take off the back and on the ciruit look for the horizontal and when you get it sue a screw driver and a mirror. put the mirror in front of the tv once you locate the horizontal plug the tv back on and look at the mirror and as soon as you turn the horizontal you will see the picture come back up to the correct size, if no good???? take it out and get a new one if you look on the side off the component you must get tthe same for safety, solder the new component in and try again
Apr 20, 2009 | Toshiba Televison & Video
Lines on tv
Set starts, horizontal and vertical deflection work, HT ok, crt heaters ok, but no sound or picture
I turned the G2 voltage up and noticed a white screen with flyback lines, frame ok. I detected two badly soldered double diode rectifiers in the secondary part of the power supply ! I checked all other joints, and everything was ok !! success
White horizontal line (no vertical deflection)
Check / replace R548, R549
Sound but no picture except for a couple of horizontal colour lines
Replaced the frame chip TDA8356, set now ok
Nov 23, 2007 | Mitsubishi WS-65511 65" Rear Projection...
Sony FD Trinitron WEGA KV-32FS100 32" TV Logo
56 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
