You can do it two ways: 1) call Dell and order a recovery CD--their contact info is on dell.com or 2) use a regular Windows CD and install the system using the product number affixed to the case. Then go to Dell at support.dell.com to download the needed drivers.
What are the problems using a JNC92 motherboard with a ADPE4S-PB daughterboard? I am connecting 4 x...
(More)
What are the problems using a JNC92 motherboard with a ADPE4S-PB daughterboard? I am connecting 4 x SATA 1TB disks in RAID 5. I can see the disks in the BIOS. I can see the disks when I look at the properties of another disk in the "Hardware" button, and am told they are working correctly. But cannot access them in Windows XXP Pro SP2. Can only see and access them as JBOD not RAID. Why? Hywel Davies
no sound no picture already ruled out hd converter as the problem . only 3 yers old. what are the...
(More)
no sound no picture already ruled out hd converter as the problem . only 3 yers old. what are the TERMS OF USE before I agree
Motherboard wire hook up I pulled the wires : Power LED, Power SW, H.D.D. LED off the motherboard,...
(More)
Motherboard wire hook up I pulled the wires : Power LED, Power SW, H.D.D. LED off the motherboard, don't know the pattern to put them back on.
recieve error message when trying to setup zune system to dimension 5100 0x8007063 what wrong is it...
(More)
recieve error message when trying to setup zune system to dimension 5100 0x8007063 what wrong is it something i need to add to pc
I CAN play MP3s and CDs and hear the music on my myspace page when it loads. I can hear music on...
(More)
I CAN play MP3s and CDs and hear the music on my myspace page when it loads. I can hear music on other people's myspace pages when it's imbedded into the page as an mp3; however I cannot hear the music on peoples Myspace Music Players. This started late yesterday afternoon and of course I presumed this to be a myspace problem and didn't give it much thought. When I turned on the computer today something visually went by fast (maybe a small gray java window) like it was installing something (maybe windows haha) but it may have said Windows Media Player. When it finally came up I opened Windows Media Player and tried to play an MP3 and it said I was missing a codec and provided a proper link. I clicked on the link and immediately got the codec and now the MP3s play. But still Myspace Music Players don't play. Here is the bad part that made me realize it wasn't a myspace problem. My midi files do not play nor do any of my webpages play the midi files on them. The only change I made was yesterday I deleted X-Vid codecs that I had downloaded months ago and did not use. I used add/remove programs and removed X-Vid. Anyway I did a full Nortons scan and was clean. Then I ran a full Ad Aware Scan, and ran CCleaner as well and nothing is very wrong with my system other than no sound with midis. I finally decided to do a full system restore to yesterday that failed as it said I had made no changes. Then I tried a system restore to last Sunday and it said there were no changes made and so no restore would be made. So it probably wasn't the X-Vid delete that caused the problem. In troubleshooting in Device Manager I tried to update ALL the audio drivers and it said I had the best (latest)version of all the drivers. I clicked on everything individually and then ran the troubleshooters which took forever. I have no yellow exclamation points and it says all things are working properly. except for one thing. when I click on Unimodem Half-Duplex Audio Device it says this device is working properly. When I click on properties and then again on the tab that says properties and then on the words Modem Wave Driver it says Status:Driver is enabled but not functioning properly. Yet previously (higher up) it said it was fine. (this is device 5.3.2600.2180) Also if I click on Control Panel, Sounds and audio devices,sounds tab.... and click on a sound.... it used to let you preview the sound but now the tab is gray. I don't know what to do next. If my sound card was unseated my mp3s wouldn't play. I have rebooted several times. I have tried reading Dell forums (I have a Dimension 5100) and I have read forums for Unimodem half-duplex audio device and forums for Sigma tel High definition audio codecs although that one says its working properly. Since it seems to only be Midis affected and it is called a Modem Wave Driver, could the dial up modem be unseated? could it be that simple?
