Question about Whirlpool Ovens
F2 error - Whirlpool Ovens
  • 6,784 Answers
HI, the oven control has sensed a very high oven temperature during baking or cleaning.
SOLUTION
1. Look for welded relay contacts on bake or broil relays. If this happens, replace oven control (also called clock or ERC).
2. For SELF CLEAN models: check door lock operation.
3. Look for a high resistance connection or any other cause of high resistance in the oven temperature sensor circuit. Check sensor, sensor harness and sensor harness connection at sensor and oven control. Replace sensor if found defective.
Remember: Oven control (ERC) measures resistance of sensor circuit, not actual oven temperature.
Posted on Oct 08, 2009
I replaced circuit board in whirlpool combo microwave / oven, shows fault code F2, error code E1.
Did you get the circuit board from a trustworthy place?
It is a circuit board error. Did you install it correctly - right wires to right connections?
Control displaying F2 E1:
There may be a problem with the User Interface (Touchpad), or the associated wire connectors.
Power unit down by turning off the circuit breaker(s) for one (1) minute.
Power unit up by turning on the circuit breaker(s).
Monitor the oven for one (1) minute to ensure the error code does not display again.
Verify oven operation
Have to go the long way to bring up the link by first:
e1 f2 whirlpool oven Google Search
and then click on https://www.google.com/url?sa=t&rct=j&q=&esrc=s&source=web&cd=1&cad=rja&uact=8&ved=0ahUKEwjprvf2_7nJAhXKVRoKHe7zAmMQFggdMAA&url=http%3A%2F%2Fwww.whirlpool.com%2Fproduct-help%2Ferror-code-oven-f2-error-code-f2-e1%2FPH7389%2F&usg=AFQjCNFoDK8E-zgNHF3Kp4EoihGu1tbyEw
Dec 01, 2015 | Whirlpool Ovens
E1 F2 error code
Check the ribbon cable for connection
Mar 27, 2013 | Whirlpool RBS245PDS Electric Single Oven
I keep getting the following error message: E6 F2 - what does this mean?
If you have a Whirlpool oven, the F2 E6 error means that the Cancel key line is open. You will need to replace the keypad or the keypad and controller board (if a single assembly) if the keypad doesn't respond to a press of the Cancel Key.
I hope this helps.
Dec 12, 2011 | Whirlpool Ovens
I self cleaned the oven and over 12 hours later am getting a f2 error. How do I fix it?
The F2 error code means that the oven over heated by at least 100 degrees and the oven temp.sensor needs to be replaced.
On the self clean cycle the oven temp can easily reach over 600 dergees and therefore the sensor thinks it got too hot. If you have not already done so the F2 can be cleared by pushing the CLEAR/OFF button on the control...if the F2 error code reappears the sensor has became defective and it would need to be replaced.
GENE
Sep 05, 2011 | Jenn-Air WW30430P Stainless Steel Electric...
F2 error code
F2 E6 says this:
1. Check keypad connector for firm connection.
2. Press CANCEL. If error code returns after 60 sec., replace keypad.
3. Replace control
Nov 10, 2009 | Whirlpool GBD277PD Electric Double Oven
F2 & f3 alert
thank you for the info. you need to replace the oven sensor. an F2 error is oven is to hot. an F3 error is a shorted or open oven sensor. the oven sensor is easy to change, and not very expensive. if you have further questions, let me know. shane
Aug 24, 2009 | Ovens
F2 error
F2 is a bad temp sensor, needs to be replaced.
Jun 23, 2009 | GE JKS06BFBB Electric Single Oven
Kebc207 oven error code E1 F2
This is information from the Tech Sheet.
Fault Code F2 - Error Code E1: Code Explanation: Keypad keytail not connected. Recommended Repair Procedure: 1. Check keypad connector for firm connection. 2. Press CANCEL. If error code returns after 60 seconds, replace keypad. 3. Replace control.
Jul 15, 2008 | KitchenAid KEBC207 Electric Double Oven
F2 error message
Hvace, F2 is a shorted temperature sensor. Probably took it out with the self clean...Catriver..post back.
Aug 31, 2006 | Whirlpool GBS307PD Electric Single Oven
Ovens Logo
121 people viewed this question
Top Whirlpool Ovens Experts
Dan Webster
Dan Webster
ashburton
Sal De
Are you a Whirlpool Oven Expert? Answer questions, earn points and help others
