Question about Sony PlayStation 2 Slimline Console
The system won't read the disc right away. Also If I push on the disc tray cover The system stops reading the disc
    Problem Solver:
  • 5 Answers
It could be a dirty laser you might have to replace it, they cost between $50 and $79 dollars on ebay.
Posted on Oct 08, 2009
Xbox360 disc tray motor won't stop spinning
Hi Matt,
Here is the process for troubleshooting this specific issue:
  • First remove your disc from the tray. I assume you have already done this.
  • Ensure your faceplate (the front of your system) is on correctly. Sometimes these can become loose and off kilter. Press the two edges firmly with your hands and "push" it into place.
  • Push the eject button. Although it hasn't worked in the past, adjusting the faceplate may correct the issue.
  • If that doesn't work, move the disc tray drive gently from left to right when it is open. Again, be gentle-- what we're trying to do here is slightly adjust the disc tray in case it isn't entering your system properly.
Still not working? Time to send it to Microsoft for repair. You can find all of that information on their official support site. Click here for more details.
Hope that helps!
Feb 10, 2012 | Microsoft Xbox 360 Console
My dell 1645 disc drive won't open , I burnt a
There should ba a tiny hole on the front of the tray cover on the drive.
Switch off, get a paper clip or something about the same thickness and insert it carefully in to the hole, push it in until the tray opens.
Jan 08, 2012 | Dell Computers & Internet
Wont stop reading "no disc" on the display even
If it will play a CD but not a DVD then it could be the Laser is failing. If it won't play either then its more than likely that the Laser has failed.
First thing though is to try cleaning it with a Lens Cleaning DVD.
If after this it still won't recognized a DVD you need to remove the Main Cover followed by the DVD Tray cover. You can then clean the lens directly with some lens cleaner fluid and a QTip. Make sure you only use a little cleaner fluid and wipe off with a dry QTip. Do not touch the lens with your fingers.
After you've reassembled the unit if you still have the same fault then the Laser has failed and would require replacing, although this is not normally cost effective.
Please leave feedback
Cheers
Andy
Apr 27, 2011 | Philips HTS-3555 System
Panasonic dvd players error codes
I tried the WD-40 and it worked........thanks a million !!
Mar 28, 2010 | Panasonic DVD RV22K
Loose disc tray
well, when you opened the tray with a paperclip, it probably jacked up the reading system. The you pushed it in manually. This will totally ruin the system. Try contacting Microsoft.
Jan 16, 2010 | Microsoft Xbox 360 Halo 3 Special Edition...
My psp wont read umd discs
You have probably only 2 options on this one.
1. Try using compressed air. If there is anything keeping the disc from being read, i.e. dust on the lens or some other obstruction, you don't want to touch the laser. Open up the UMD tray and spray out the inside of the tray. This will remove anything that might be causing the system to stop reading discs.
2. If that doesn't work, then the only other option would be to call Sony. It won't be fun if you're out of warranty. The system does carry a 1 year limited warranty, but this should be covered. Oh, Sony can look up the date of purchase if you don't have your receipt, so don't 'fold' if they tell you that you need the receipt. Just tell them to look it up by the serial number.
Oct 03, 2008 | Sony PlayStation Portable (PSP) Console
PS2 Slim Won't Read Discs
theres a wrong in the mechanism in your PS try to push the cover while reading the disc, push it on the surface which the sensor was locate, "push Gently" not very hard!!
Aug 26, 2008 | Sony PlayStation 2 Slimline Console
Dvd do not loads
Our started doing the same thing about a week after the warranty ran out. It has to do with the alignment of the discs being loaded. here's a work-around that works for us:
Open the tray
Choose which disc you are going to watch and use the Change Disc button to push the selected disc to the back (ie, if you want to view Disc 1, discs 3 and 4 will be visible in the tray).
Look down the center holes of discs 3 and 4... manually move your tray left-or-right to align the holes with the tray.
Push the Direct Play button on the top right of the unit for your disc of choice (Disc 1 using the example above).
hope that helps... I've searched for a while and played around with the unit (with and without the cover on) trying to figure out a way to re-align the tray, but no luck.
--JeD
Aug 20, 2008 | Samsung HT-WP38 System
LG LHY-518
I had the same problem. Also, the disc tray had issues opening if there was no disc in there. The problem was two fold... I think.
1) It was kinda dusty inside the machine and needed a good air can dusting. Get around the tray but be careful not to turn the can upside down and freeze components. I also ran a lens cleaner disc several times.
2) The tray top (only visible with the system open) was starting to warp... likely because the build up of dust was creating too much heat, also causes issues in reading discs... I created a make shift cushion that I taped to the top of the plastic tray that was depressed when the top of the machine was placed back on. This required several tests as if too much pressure was applied, the tray wouldn't open at all and I got read issues in the middle of playing a disc (possibly an alignment issue of the lens caused from the pressure). I finally got a good system where I occasionally have push the top with my finger to open the tray only if it was empty so my padding (made from gauze and gauze tape) was barely getting pressure. Again, this took about 30 minutes of trial and error to get it right. The heat and the displacement due to the warped cover could have caused read issues.
I don't know if either or both of these were the cause of the problem but I can safely say that I have no issues now and yes, prior to this, I slowly went from 100% reading discs to almost 0%.
Sorry for the winded response but this saved me from buying a new system and may save you. Good Luck!
Dec 30, 2007 | LG LHY-518 System
CD malfunction
It sounds like you have put a disc in the tray that the system can not read, so it will just keep trying to read the disc over and over again. If you turn everything off by the plug and wait a few mins the whole system should stop. Put the plug back in and as soon as you turn your system on, try and press the disc open key before the lens gets a chance to start reading it again. If this does not work you may just have a disc jammed. So you will have to get someone to check it out for you if you do not understand what you will be doing, because you may do more harm than good to your system. Good luck.
Aug 29, 2006 | Sharp CDES600 5 CD, 240W, Silver, Mini...
Sony PlayStation 2 Slimline Console Logo
56 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
marley mcelhinney
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
