Question about Panasonic Panafax UF-885 Plain Paper Laser Fax
Fax is not receiving incoming faxes only 1st page print out. on the sender side it shows NG where it tell you if it was submitted okay.
    President:
  • 3,085 Answers
Either you or the sender has a Digital phone line. All fax machines are Analog devices
Posted on Oct 08, 2009
My brother fax 837mcs won't receive faxes
check setings and conection to phone tray other phone in the same out
out let to see if you have signal on it.
May 31, 2012 | Brother Office Equipment & Supplies
How can I cancel incoming fax on lexmar x646e
If the printer is connected to a network, get the IP address of the printer and access printers web interface. You may print a network settings page to get the IP address of your printer. Open a web browser and type the IP address on the address bar.
On the left side, click on the configuration menu and click on fax settings and select fax setup. Under fax receive settings, please uncheck enable fax receive.
You may also do this using the printer's operator panel. Just press on Menu button and select settings. Select fax settings and analog fax set up. Select fax receive settings and turn off enable fax receive then press submit.
Jun 20, 2011 | Lexmark X646e All-In-One Laser Printer
Hp officejet 6500 instructions for receiving a fax? Thanks
You can receive faxes automatically or manually. If you turn off the Auto Answer option, you must receive faxes manually. If you turn on the Auto Answer option (the default setting), the device automatically answers incoming calls and receives faxes after the number of rings that are specified by the Rings to Answer setting. (The default Rings to Answer setting is five rings.)
If you receive a legal-size fax and the device is not currently set to use legal-size paper, the device reduces the fax so that it fits on the paper that is loaded. If you have disabled the Automatic Reduction feature, the device prints the fax on two pages.
NOTE: If you are copying a document when a fax arrives, the fax is stored in the
device memory until the copying finishes. This can reduce the number of fax pages stored in memory.
This section contains the following topics:
• Receive a fax manually
• Set up backup fax reception
• Reprint received faxes from memory
• Poll to receive a fax
• Forward faxes to another number
• Set the paper size for received faxes
• Set automatic reduction for incoming faxes
• Block junk fax numbers
• Receive faxes to your computer (Fax to PC and Fax to Mac)
When you are on the phone, the person you are speaking with can send you a fax while you are still connected. This is referred to as manual faxing. Use the instructions in this section to receive a manual fax.
NOTE: You can pick up the handset to talk or listen for fax tones.
You can receive faxes manually from a phone that is:
• Directly connected to the device (on the 2-EXT port)
• On the same phone line, but not directly connected to the device
NOTE: The automatic document feeder must be empty to receive a fax. If there are documents in the ADF, then the device will not be able to receive incoming faxes.
To receive a fax manually
1. Make sure the device is turned on and you have paper loaded in the input tray.
2. Remove any originals from the document feeder tray.
are documents in the document feeder, then receiving the fax will be
unsuccessful.
3. Do one of the following to answer a fax manually:
• Set the Rings to Answer setting to a high number to allow you to answer the
incoming call before the device answers.
• Turn off the Auto Answer setting so that the device does not automatically
answer incoming calls.
4. If you are currently on the phone with the sender, instruct the sender to press Start on their fax machine.
5. When you hear fax tones from a sending fax machine, do the following:
a. Press START FAX Black or START FAX Color on the device control panel.
b. When prompted, select Fax Receive.
NOTE: Depending on your country/region, the device might receive the fax
automatically when you hear fax tones from the sending fax machine.
6. After the device begins to receive the fax, you can hang up the phone or remain on the line. The phone line is silent during fax transmission.
Jan 30, 2011 | HP 1250 Plain Paper Thermal Inkjet Fax
Why are all my incoming faxes all black pages?? Is it my fax or the senders? Very hard on the ink cartridge
hard to determine the problem without any make/model of your fax machine. However I would begin by looking at the fax contrast and darkness settings, they are likely cranked to the dark side. If you cannot find these settings or this doesnt help. post your make/model information. I don't believe this should affect sending faxes, its likely just a print / contrast setting for received faxes.
Aug 29, 2010 | Office Equipment & Supplies
Incoming Fax is blank
PRESS REPORTS IT WILL PRINT OUT A HELP PAGE LOOK AT THE SUB MENUE ON THE HELP PAGE MENUE SELCTION 3 FOLLOW THE PROMPT TO TURN ON THE RECEIVE OR IT MAY SAY EASY RECEIVE . GOOD LUCK BROTHER TECH / I HAVE THE SAME MACHINE AT HOME GOOD LUCK
Dec 04, 2008 | Brother IntelliFAX 4100 Laser Fax
Received faxes on brother fax 1360 incorrect order
you cannot control PAGINATION, have the sender reverse the order of sending.
Nov 14, 2008 | Brother Fax-1360 Plain Paper Inkjet Fax
HP 1010 fax - only receives first pages of a fax
Do you have DSL, or any other type of digital phone line.
Usually this is caused by a "noisy" phone line; some sort of interference.
Sep 23, 2008 | HP 1010 Plain Paper Inkjet Fax
Cannot Send or Receive Faxes
here you might find an answer:
http://welcome.solutions.brother.com/bsc/public/us/us/en/faq/faq_top.htm?reg=us&c=us&lang=en&prod=mfc240c_all
Mar 29, 2008 | Brother Multi-Function Center MFC-240C...
Panasonic Panafax UF-885 Plain Paper Laser Fax Logo
108 people viewed this question
Top Panasonic Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Mitch S
Mitch S
Level 1 Expert
HEMANT GROVER
Are you a Panasonic Office Equipment and Supply Expert? Answer questions, earn points and help others
