Question about Rheem EcoSense by 7.4 GPM Outdoor Tankless Water Heater Natural Gas
The max temp in the control is 120F. How can I
The max temp in the control is 120F. How can I increase more to let's say 140F
    Champion:
  • 248 Answers
Gas pressure may be increased but most boilers are designed to a limited output 24 28 30 etc
Posted on Oct 11, 2009
Why does the pressure rise to over 3bar when the central heating is in operation ?
3 Bar = 43.5 PSI When you heat water it always expands increasing pressure.
In a closed vessel volume can increase by 2-3%. Either expansion tanks allow for this and PSI is maintain or without an expansion outlet the PSI will increase in proportion to heat supplied.
Is this a low temp hydronic boiler operating at or <140F, a hi temp hydronic boiler @ >180F or steam boiler?
Oct 18, 2014 | Water Heaters
Steady water coming out of drain line
Bad safety shut off valve turn off the power and drain the heater and replace the valve
Nov 02, 2012 | Water Heaters
How to change from ºF to ºC on the UMC-117?
According to the 2012 manual, 'the LED display only shows F.'
Bottom page 65. Yet the F temperatures are also shown as C in the manual.
http://waterheatertimer.org/pdf/How-to-set-Rheem-tankless-temperature.pdf
You probably have different model, or older model?.?
Older manual (page 15) shows same temperature range with both F and C, but typical of Rheem, the manual is totally vague about settings and say that qualified tech needed to adjust temps beyond factory default range (with no mention of display showing C) ... which is safeguard since the damg product cannot always heat water fast enough to reach higher set points above 120F.
http://waterheatertimer.org/pdf/TanklessOutdoor_95_84_64X_UC_AP15318.pdf
Call Rheem 800-432-8373 and give your product serial number and model number located on side of unit, and ask them.
Don't forget to keep the product maintained to avoid common error codes.
http://waterheatertimer.org/pdf/Rheem-CondensingTankless-maintenance-2012.pdf
Aug 28, 2012 | Rheem Tankless Water Heater Main Remote...
Is it possible to lower the top temperature on the thermostate. I can change the lower temp but not the max which I wish to set below the 180 level. Thanks
there is a high and a low limit on these units, the two control knobs are actually the reverse of what you are trying to accomblish,first lower the bottom or low cut off temp first then the high temp ,it must cycle a couple times for it to adjust
Jun 06, 2011 | Honeywell L4103A1019 combination aquastat....
How to reinstall heating elements. not sure about the wiring.
The electrical specifications are based on 220 volts. It should be noted that higher voltage will increase power, just as lower voltage will have the reverse effect. The (POWER MODE CONTROL) can be adjusted to compensate allowing the user to increase or decrease water temperature. For best performance adjust temperature at MEDIUM FLOW (approximately 1 GPM) this is the average water flow at any faucet with an aerator.
Remember, that any adjustments made on your unit will take seconds to reach point of use. DO NOT OVER HEAT WATER. Water temperature from 105F to 120F is adequate for all practical purposes
MODELS Model Max KW at 220V Volts Max Amps at 220V N-120 11.8KW 220V 54 N-100 10.8KW 220V 49 N-85 8.5KW 220V 38 N-75 7.5KW 220V 34 N-64 6.4KW 220V 29 N-42 4.2KW 220V 19 N-10 3.2KW 110V 29*
Nov 13, 2010 | TitanNet TITANTANKLESS. COM PRESENTS THE...
Rheem hot water system- Not getting hot enough.
sound like the mixing valve is damage.. even though the valve is mandatory rheem tankless system don't really need one due to the fact you can set the temp to avoid scalding..these unit will only go up to 120F (48C) The only reason you wll need a mixing valve is when you store water because you have to mantain a temp to kill bacteria and since there is no storage on the tankless it just does not make sense to have one. also you can turn down the temp on the control at anytime to any desire temp..this is a plumbing regulation in many part of the world that need to be look at a little more carefully..not only where you live.
Jul 03, 2010 | Rheem Water Heaters
Rheem tankless heaters, unlock 140f limit
THIS MAY NOT BE SAFE TO DO YOU CAN CALL THE MAKER
Jan 07, 2010 | Rheem Tankless Water Heater Main Remote...
Adjusting water temp
Behind the handle there is usually a scald gaurd on the newer faucets. You can adjust it from there. If your not sure, follow this link and download the installation instructions to your faucet. There you will find how to adjust it step by step. http://www.hansgrohe-usa.com/us_en
Mar 05, 2009 | Hansgrohe Thermo II Rough-In Valve Chrome...
Hot water out of taps is not very hot.
What is hot? Above 122F causes scald within 30 seconds. Get a temperature reading at tap. Use a candy thermometer if need be. If you want 140F water then your gas valve needs replacing.
In most code areas it is now illegal to deliver tap water over 125F to a consumer faucet.
You may love 140F but you jeopardize kids and Seniors.
Mar 03, 2009 | Honeywell Water Heaters
Rheem EcoSense by  7.4 GPM Outdoor Tankless Water Heater Natural Gas Logo
165 people viewed this question
Top Rheem Water Heaters Experts
Donni Steen
gizmonix
Level 1 Expert
Jim Goldsmith
Jim Goldsmith
Are you a Rheem Water Heater Expert? Answer questions, earn points and help others
