Question about Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+
My 1991 1/2 hp door opener is responding to other remotes in the area; I changed the pins three times--no help. Stumped
    President:
  • 3,197 Answers
It's time to get a new state of the art opener. Yours is very outdated.
Posted on Oct 08, 2009
I have an older LiftMaster opener (1/3 Hp - 1991 vintage). I have had two older replacement universal type remotes that worked fine. Lately one of the remotes stopped working with the opener. Changed...
Hmm tricky situation try unplugging it for atleast 2 hours and remember any device usually handles one code at a time so if your using two remotes together with different codes that will happen thats pretty much all i can think of at moment
Apr 26, 2017 | Chamberlain Televison & Video
Where do you connect diagnostic computer on a 1991 honda accord
can be a two or three pin plug ,,,,its on the left side over your feet above the panel,,,,,they hid it pretty well and changed the exact location in that area a few times,,,, but it is up there
Feb 11, 2012 | 1991 Honda Accord
I have a 96 ford conversion van with a 600 plus addon keyless system and need to program new keyless remots , need to know how to get system in program mode.
Hi.
To program ( or reprogram ) a keyless entry remote transmitter into the remote keyless entry module, perform the following steps:
1. Turn the key to ON or ACC and short the two terminals of the program connector, a two-pin connector located below the driver's side of the instrument panel at the base of the steering column. All doors should lock and then unlock.
2. Press any button on each keyless entry remote transmitter in turn. All doors should lock and then unlock. If the door locks do not respond, press the button again (up to three times maximum with the same keyless entry remote transmitter). If the door locks still fail to respond, go to Pinpoint Test A.
3. Repeat Step 2 to program additional keyless entry remote transmitters into the remote keyless entry module (up to four keyless entry remote transmitters maximum).
4. Turn key off.
5. Remove the short from the program connector. All doors should lock and then unlock.
6. Verify that the keyless entry remote transmitters have been successfully programmed by pressing the LOCK or UNLOCK button on each one, and observing that the system responds by locking and/or unlocking the doors.
I hope this helps you.
Thanks!
Nov 28, 2010 | 1996 Ford Econoline
Cannot get remote for garage door to work
push the green button on the opener then push your remote button
Jan 25, 2010 | Locks & Locksmithing
We are having intermittent problems with our 2 garage doors opening. All three remotes as well as the outside door mounted opener, are having a problem with opening the two different garage doors. This...
sounds like condensation in the receiver window of the garage unit rather than the remotes. Try running a hair dryer over the area where the signal is received to get rid of any moisture and try using the remote from across the road or at the drive entrance.to check your success
There have been a few complaints about this on some of the other forums and the seals arn;t all that good
Please rate our help++++Thanks for using FIXYA
Oct 14, 2009 | Sears Craftsman LiftMaster Chamberlain...
Programming multiple remote door openers I am trying to add a remote key pad to the exterior of the door. When that is programmed and working it knocks out the car remote. I have 2 of those. How do I get...
i think what is happening is the code in your open has a list of different codes it cycles through to keep someone from "capturing" it and opening the door when you gone.Try having someone help you and program the three units at the same time.
Sep 06, 2009 | Chamberlain Powerdrive PD422D 1/2 HP...
The remte control key is not responding with the car
Hi abdumi0f,
Firstly, open your glove box and make sure Valet Mode is not enabled, if it is not, follow these steps.
Step 1: Open drivers door and leave open.
Step 2: Lock and unlock the driver’s door using the power door lock switch on the door.
Step 3: Insert key into the ignition.
Step 4: Turn key to on position and return to off position. (IMPORTANT - use ON position NOT ACC position). Do this 3 times within 10 seconds. Leave key in the ignition.
Step 5: Open and close the driver’s door 3 times. (Door should be left open after this step).
Step 6: ECU should respond by locking and unlocking the doors.
Step 7: Press any button on remote #1 twice. ECU responds by locking and unlocking the car doors.
Step 8: Press any button on remote #2 (etc.) twice. Each time the ECU will respond by locking & unlocking the doors.
Step 9: Remove the key from the ignition and the ECU will respond a final time with a series of door locks and unlocks. You're done!
Hope this helps,
Lazaruselite
Feb 24, 2009 | 2007 Mercedes-Benz E320 BLUETEC Sedan
Door opener remotes not opening garage door.
You have to sync the remotes to the new code. For older remotes, you can open the remote and match the pin settings.
For newer remotes there's a button that you push in the back of the opener that sets in program mode (for Chamberlain). When you push the remote button, it will acknowledge the remote is programmed.
If this doesn't help, comment back on your particular model and we'll help you with the solution.
Jan 03, 2009 | Sears Craftsman LiftMaster Chamberlain...
Keyless entry remote
Try this, it works on several 2002 models:
Step 2: Lock and unlock the drivers door using the power door lock switch on the door.
Step 5: Open and close the drivers door 3 times. (Door should be left open after this step).
Step 7: Press any button on remote #1. ECU responds by locking and unlocking the car doors.
Step 8: Press any button on remote #2 (etc.) Each time the ECU will respond by locking & unlocking the doors.
Jun 20, 2008 | 2002 Mazda Protege
Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+ Logo
126 people viewed this question
Top Sears Building Materials Experts
Glenn Mayer
Glenn Mayer
Mike
Are you a Sears Building Material Expert? Answer questions, earn points and help others
