Question about Whirlpool Washing Machines
How do I clean my washer? It smells so bad!
How do I clean my Whirlpool washer? It smells so bad!
    Problem Solver:
  • 5 Answers
Their is a kit called affresh that runs a cleaning cycle to help with odours,just follow directions on pouch, if seal has already turned u might have to run more than once. affrsh is available at lowes stores in the appliance section. jeb maytag tech.
Posted on Oct 08, 2009
My Duet washer stinks so much. The wash does not come out smelling good. It is clean but it doesn't smell good. I do use those cleaning tablets but it still stinks. It has over-suds many times where...
I have found that using a l/4scoop of oxi cleaner any brand will do along with my regular wash detergent helps keep the odor under control . I leave my door open to the washer when not in use. Occasionally I will clean under the gasket with a mild cleaner. Remember the front loaders use less water and therefor less detergent. Good luck.
Sep 14, 2010 | Whirlpool Duet GHW9150P Front Load Washer
The washer smells bad. We have taken it apart and cleaned between the tubs. The agitator turns in both directions
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Hope your filter is clean. Don’t wait for the machine to jam to look into your filter.
You can use Affresh to clean your front loader. Deposits of soap and other such things can be stuck around the inside tub of your washer. Try this product, it works great on all front loaders. Use very hot water with the Affresh pellet with no clothes and run the machine through a cycle. Also helps with any stagnant water smells. Put the Affresh pellet inside the machine, not in the soap dispenser.
You can give me a ‘very helpful’ rating for the free help, can't you. Thanks.
May 21, 2010 | Whirlpool LSQ9659PW 2 SPD 10 CYC 4 TEMP 5...
Odor problems with whirlpool front load washer
Is the smell of mildew?
Run the washer on empty with beach and soap.
This is a common problem when the front door is left closed after use.
When the washer is not in use leave the front door cracked open. This will help in preventing mold & mildew.
Dec 12, 2009 | Whirlpool GHW9100L Front Load Washer
The washer has a very bad odor. I have tried using different soaps, but it still smells bad. The clothes smell "flat"----no odor----but the laundry room is getting to smell harsh. There is nowater outside...
thedrain has sludged up causing partial blockage. soap powders cause this . check the fall on your drainage. Either attempt self cleaning or get a drainage company to investigate.
Aug 14, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Washer smells bad
Whirlpool and Tide make a cleaner that you put into the washer and run it through a cycle. Front loaders get a build-up that cannot be cleaned by hand. Make sure you are using a detergent that is marked "HE". Do not overfill the detergent or softener cups. I've heard that other used a lot of bleach in a wash cycle to clear out the smell. Bleach is bad to use if you're on a septic system, though.
May 03, 2009 | Maytag Atlantis MAV6000 Top Load Washer
My Whirlpool Duet front loading washer has mold and mildew growing even though I clean it out often. It makes the laundry room smell.
yes they are very good for that... and for the bad news it is almost impossible to get it out.... sorry for the bad news but all of them do it
May 02, 2009 | Whirlpool Duet 3.8 cu. ft. Front Load...
Odor
What type of odor? If it is a bad smell, have you been running the bleach cycle to clean the washer as per manual directions? If not I would try this. Dan
Jan 02, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Bad mold and smell from washwe
i have repaired appliance most my life i tested soaps and softer,at our own family shop,i can tell you that washers do not make mold or bad smells either does cloths its what and how much product that you are pulling in the washer that is molding and smelling and it stays in cloths building up load after load,i have a kenmore he3t front load washer i use 1/3 cup powdered only.armen hammer only. non he only.my washer inside is spotless smells clean and fresh all the time, you will need to clean yours inside out with bleach then use affresh weekly switch to 1/3c powered soap
Nov 15, 2008 | Whirlpool Duet GHW9150P Front Load Washer
I have a Whirlpool Gold Ultimate Care II, Commericial Quality, Super Capacity Plus...it smells. No really it has a terrible odor. It's a sour foul smell. Water and detergent and various clothes washing...
Whirlpool now has cleaning tablets to take the smell out washers. They say they are for HE front load machine but it works on all machines. They are called affresh washer tablets. Just buy some and put all three tablets in the tub with hot water and let the washer go through a cycle with just the tablet(no clothes). By putting all three in the washer at one time it will kill the smell. For later use the package is a three month supply. They cost under 10 dollars.
Nov 14, 2008 | Whirlpool Washing Machines
Our Clothes smell musty and the washer smells too
clogged water screens , defective water level pressure switch , clogged drain, kinked drain hose ,. defective water pump , defective water tempeerture switch, damaged water valve solenoid , water inlet valve has an interal malfunction
Oct 03, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Washing Machines Logo
46 people viewed this question
Dan Webster
Dan Webster
Sal De
