Question about Kenmore Microwave Ovens
My kenmore microwave automatically starts and can not be stopped
My kenmore microwave was unplugged by a cleaner. When I plug it back in, the microwave starts by itself (turning on, the plate turns, the inside light on). I'm not able to turn it off. Pressing Stop doesn't stop the heating. When I press Start button, it beeps couple of times. It was working fine before. Can this be easily repaired?
  • Kenmore Master
  • 9,086 Answers
If and when an oven is coming on or doing anything by itself, this is very dangerous and can result in a fire.
So until it is repaired, please leave it unplugged or leave the door open.
Is it possible that some spray cleaner got into the controls?
I always recommend that users instead spray cleaner on a soft cloth then wipe the control panel.
Also, I always recommend non-ammonia cleaners since ammonia can crack and damage plastic.
Otherwise, the spray can get into the controls and lock it up or make it act odd.
If it does not dry out over time, it may need to be manually dried or blown out.
The keypad may be damaged or worn out, or control unit may be damaged.
On some models, the membrane keypad is not available as a separate part, so you would have to order the control panel frame assembly which comes with a new keypad.
In this case, you simply move your circuit board into the new frame. That is a simple do-it-yourself job.
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
Then you unplug the keypad (as per the photo below) and move the circuit board into your frame.
Some connectors on the relays may have a lock:
You can find handy exploded views and get part numbers by entering your full model number at the Sears Parts Site.
A full Sears/Kenmore model number has 3 digits, a dot, then 8 more digits, such as ###.########
Once you have the Sears part number, you can usually get parts cheaper here.
If you might be interested in having us so the work for you, we charge $39.95.
Feel free to contact me directly.
William E. Miller
prototech@usa.net
http://www.microwavedisplay.com
Posted on Oct 10, 2009
I have a Kenmore Elite Microwave Model 721.7915. When opening the door to put an item in, the microwave automatically starts without closing the door or pressing any functions. I have tried unplugging...
The door latch is a safety interlock that prevents your microwave oven from doing what it is doing. The latch has failed and has to be replaced.
Dec 19, 2014 | Kenmore Microwave Ovens
Kenmore 401.80083700 won't turn off
It is one of two things, a defective door switch, or the keypad control board has failed.
Apr 18, 2012 | Kenmore 68361 Microwave Oven
Kenmore microwave - unresponsive keypad
Repaired the unresponsive keypad on my older Kenmore (model 721.68100): Unplug. Remove integral cover for top and sides which is held in place by 5 metal screws. The cover then slides toward the rear. Unplug two connectors to back of keypad and clean them (I used contact spray cleaner). Some of the components retain a charge even when unplugged.
Dec 17, 2009 | Kenmore Microwave Ovens
Microwave stopped working last night
If the microwave worked for a little while after you plugged it in again then it is just overheating.It is usually just dust/dirt collecting on the vents.the fan,and the magnetron(the thing the fan blows on).If cleaning all these doesn't solve the problem you may have a bad high temp overload sensor,and need to replace it.(this sensor is usually mounted directly on the top of the magnetron.The magnetron is the part that actually puts out the microwave signal.I've never seen a reset button.The high temp sensors reset themselves automatically.
Jun 23, 2009 | Panasonic NN-T654SF Microwave Oven
Won't work
unplug your microwave; remove the top under the top you will see a small white cylinder
(a ceramic fuse) it looks like a glass fuse only made of white glass replace this they are sold at radio Shack
Apr 22, 2009 | Kenmore 63682 / 63684 / 63689 Microwave...
KENMORE MICROWAVE (HOUSEHOLD) LOCKED
It sounds like you press STOP two or three times to lock it. Maybe that (or another key) will unlock it.
The lock / unlock procedure will be covered in your owner's manual.
Or you can try a hard reset - unplug it from the wall for one minute, then plug it back in and try again.
If you don't have your manual, you can get one here. (Enter your model number without any spaces)
We're happy to help and we appreciate your thoughtful rating of our answer.
Jun 24, 2008 | Kenmore 62622 Microwave Oven
Kenmore elite microwave touch screen stopped working
Same thing happened to us. We just came back from Sears, where we bought another. Just for giggles, my wife suggested unplugging the old one and plugging it back in again. It works now. New one's going back to the store.
Jun 06, 2008 | Kenmore 63793 Convection / Microwave Oven
Keypad automatically goes to locked.
Need to replace the front panel. Try www.partstap.com
Dec 30, 2007 | Kenmore 62622 Microwave Oven
Kenmore over the range microwave oven
Maybe a short in the plug somewhere?
Dec 12, 2007 | Kenmore 62702 Microwave Oven
Microwave Ovens Logo
481 people viewed this question
Top Kenmore Microwave Ovens Experts
William Miller
William Miller
Chuck
Are you a Kenmore Microwave Oven Expert? Answer questions, earn points and help others
