Question about Refrigerators
I am trying to find the part number for a sub zero (model 590) water inlet valve for the ice maker. I am getting stonewalled by the repair company that will not give out the information. Can anyone help me?
  • randy559 Oct 08, 2009
    I have been to that site. But the item# at Repair Clinic does not match the Sub Zero part number I think I need. Do you have a Sub Zero manual that shows the Sub Zero part numbers? I cannot find this on the internet.
  • 11,896 Answers
You can get all the info from www.repairclinic.com
Posted on Oct 08, 2009
  • Nate Stansfield
    Nate Stansfield Oct 08, 2009
    applianceguru.com/view_topic.php?id=21601&forum...
    www.subzero.com/resources/products/downloads/szdesignguide.pdf
    www.ebuild.com/sub-zero...sub-zero-design-guide.../2423_0_2_0.hwx
    www.SubzeroPartsCenter.com
    www.twenga.com/dir-Appliances,Fridge-accessories,Fridge-parts
Sub zero leaks water
You need to replace that water line, except it's not on top on a 632. And those weren't available in 1994. Do you maybe have a 590?
Jun 26, 2014 | Sub-Zero 632 / S
WATER DOESNT SHUT OFF AFTER ICE CUBES ARE MADE- THEN THE CUBES BECOME ONE SOLID BLOCK FROM THE DRIPPING WATER. SERVICE GUY SAID NEED TO REPLACE THE ICE CUBE MAKER: STRANGE THE ICE CUBES ARE PERFECT -...
Replace the water inlet valve to the unit. The valve is not closing completely after the water is called for. By replacing the valve should solve this issue.
I hope this helps.
Sep 12, 2013 | Sub-Zero Refrigerators
Sub zero ice maker waterline frozen
What is the model number of your unit?
Nov 01, 2012 | Refrigerators
My ice maker doesn't work. Where do I start? Model number 561
HI.FIRST MAKE SURE U HAVE TURNED IT ON.SWITCH OR LEAVER.2- WATER ON 3-WATER IN ICE TRAY.4 IF EMPTY PUT SOME ON MANUALY.AND TRY.IF IT WORKS ONCE AND STOPS THEN U HAVE A WATER SUPPLY PROBLEM.CHECK PIPE;WATER VALVE.IF ALL OK THENNNN...ICE MACHINE?HOPE THIS HELPS.ALI
Jun 30, 2012 | Sub-Zero Refrigerators
The ice maker won't stop dripping.
The problem is going to be the water inlet valve isnt fully closing and seeping water through it all the time. To fix it the water inlet valve would need to be replaced,typically on all Sub-Zero brand refrig's the valve will be up by the compressor in the area above the ref. behind the top grill.
Also while up there replacing the water inlet valve be sure to clean all the dust from the condenser coil as well as replacing the water valve.
GENE
Sep 06, 2011 | Sub-Zero Refrigerators
The ice-cube maker on our Sub-Zero 650 has stopped making ice.
try replace the cheapest part first.( vater valve). you only need 2 components to make ice. water valve and ice maker.is simple and easy water valve located in the bottom part of the unit. remove the kick plate. left side. and color blue. ice maker inside the freezer. (DISCONECT POWER BEFORE SERVICE. ALSO TURN WATER SUPPLY OFF.) try main box , garage. and water meter outside your house. good luck
Apr 02, 2010 | Sub-Zero 650 / O Bottom Freezer...
Ice maker made too much ice, then none at all...
buy the water valve and the ice maker. replace. water valve locate in the bottom part of the unit. remove kickplate. (left side blue color). ice maker little trick to replaced. (special the 2 screws in the upper part.) call 1800 222 7820. subzero. for your closest store
Sep 19, 2009 | Sub-Zero Bottom Freezer Refrigerator
Water Leaks from Ice Maker of Sub-Zero 642
Sounds like the water inlet valve to icemaker is leaking - not closing completely after filling the tray. Rare, but possible. Prove it by shutting off icemaker arm or switch. If that is the cause, the drip will continue.
If dripping stops when I/M is off, then it is ice blockage in I/M fill tube and or diverter funnel at end of ice tray. Remove I/M, clean ice from both, and re-assemble.
Replacing that valve (water supply to refrig connects to it in the back) should solve it.
Jun 13, 2009 | Sub-Zero 30.1 cu. ft. Cabinet Depth...
Ice maker will not stop!
You are going to have to replace the dispensor module. Go to http://www.subzero.com/locator/locator.aspx?type=0&zip= for your local parts distributor or service agent. The factory number is 800-222-7820 and they are very helpful.
Dec 18, 2008 | Sub-Zero 30.1 cu. ft. Cabinet Depth...
Refrigerators Logo
66 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
