Question about Sharp EL-2630P Calculator
My ink ribbon is all the way to the end, but won't reverse direction. it just stays at the end, so now my print is fading even though the ribbon is still good. how do i get the ribbon to reverse direction?
2 Suggested Answers
  • 186 Answers
SOURCE: The ribbon is no longer printing on the tape.
are you sure it uses a ribbon? Or does it use an ink roller. If it uses a ribbon it should reverse by it self. Make sure it is installed properly, there is not a ribbon reverse switch it should do it automatically. if its installed right.
Posted on Jun 17, 2007
I have wep printronix p7500 line printer. I haven't uses the printer since last 24-30 month. when i print a text file using edit.exe. it print quality is very fade. I brought a new ribbon for this printer....
I'm guessing the carrier solvent for the ink has evaporated. (Ribbon is old and dried out - even the new one) In the past, i have sprayed WD40 on unspooled ribbons and rewound them to bring ribbons back to life but that can be messy with spotty results. Suggest you buy direct fro Printronix.....
Oct 01, 2017 | Printronix Office Equipment & Supplies
I have a circa 1940's-50's Royal Desktop Typewriter. The ribbon that was already on it was rather worn and severely faded so I bought new ribbon for it. The only available ribbon was a red-black silk inked...
You have the ribbon on wrong. The ribbon dosen't feed off the spool but take up onto the spool. install the ribbon so that the moving spool is taking up the ribbon.
DickyO
Oct 16, 2010 | Royal MS 25 Typewriter
Print keeps fading, even though using new ink
check your printer settings, make sure color only is not checked off, or if you mainly print black and white documents, you should have that option checked, you may have to go into advance printer options to do this.
Apr 07, 2010 | HP Deskjet 3845 InkJet Printer
The button becomes red once I print a test page
The red light means out of paper or ink ribbon. Some people chose not to use the ink ribbon and get thermal direct paper which requires no ink ribbon but The red light means out of paper or ink ribbon. Some people chose not to use the ink ribbon and get thermal direct paper which requires no ink ribbon but the printer has to be told by the driver not to expect ribbon or the red light will come on. Also not having the correct paper height set in the driver will make the red light come on as well so check the advanced tab in the properties of the driver then click printing defaults. In the ZDesigner driver height and width are entered there. In the zebra universal, its the same path but one extra click. Click paper output and enter the size.
Oct 05, 2009 | Zebra TLP 2844-Z Thermal Label Printer
My printer won't complete the cartridge alignment function. It only prints the first two bars and then stops. When printing the black cartridge looks faded and half printed lines across even though it is a...
My printer does the same thing. I changed the blank ink yesterday (the printer shows the black ink was low) however after trying and trying and not being able to complete the alignment I decided to change the color ink as well.
It worked. Printer works fine now. Sometimes the ink dries up and you have to change it even though you know it should last longer.
Give it a try and let me know.
laura@theprincessandthepup.com
Sep 12, 2009 | HP OfficeJet 6110 All-In-One InkJet...
Mac leopard -epson tx400 - printer grabs paper - printer very noisy, desk shakes with vibration - now the print on paper is faded help!!
Hello, sorry to hear you are having trouble,
So, are we to understand that your printer did not shake with vibrations and make a lot of noise before ?
Most of these ink jet printers have heads that travel very quickly and abruptly from side to side causing shaking and vibrations, especially if it is on a light weight desk or table, sometimes to the point of almost throwing itself right off the table. This is a normal state for the printer to be in.
Then, you say the paper is printed on, it goes right through to the end, no paper jam, but the colors are faded...
How often do you print on this printer ? Sometimes, the Epson print head dry up and only small amounts of ink get through even though the system indicates that the ink is full...
You can certainly perform a head cleaning operation, I recommend doing it several (3) times to be sure, unfortunately, it's a terrible wast of ink.
Finally, have you replace the ink cartridges? If you get a faded output with new cartridges, you may have inadvertently activated the ink saving or draft mode, go through you page set-up or printer option thoroughly.
I'm pretty sure something here will get you out of this mess.
Mar 27, 2009 | Apple iMac 17" Desktop
I have a Xerox Phaser 8400 with image problems. After power up it prints a Startup Page - That page is black text which faded and slightly distorted in some areas and in areas that are in Color only...
What you are describing is a bad print head. You can try running the eliminate light stripes several times, and jet substitution, but most likely the print head will have to be replaced to remedy your problem.
You can try googling. Phaser printer print heads or phaser printheads.
There seems to be a secondary market appearing for those print heads. I can tell you from Xerox, if you have no maintenance agreement, they cost $750 per print head.
Honestly, having worked on about every type of color printer known to man, the new solid ink phaser printers, produce a dry ink image of 2400 x 2400 dpi with ink particles that align end to end. The resolution of those printers are remarkable and can be purchased for less than the price of one of those new print heads.
Now for reliable, albeit somewhat not as sharp a color image, but still exceptional, you really can not beat an HP.
The ink stick technology really no longer has the color vividness advantage it initially had. The inks that align end to end, have ended that advantage and are sure a lot cheaper to operate per page.
Feb 27, 2009 | Xerox Phaser 8400 Laser Printer
Print fades when printing even though it says there is black ink
Is this laser or Ink Jet? Have you tried running a cleaning cycle?
Oct 17, 2008 | HP Office Equipment & Supplies
May 28, 2007 | Sharp EL-2615G Calculator
Sharp EL-2630P Calculator Logo
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
jasbo
jasbo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
