Question about Sony Playstation 3 (PS3) Console
Disc drive not reading discs
I'm having problems with my disc rom drive not loading it's displaying the loading icon but no sign of the disc or audio also fan starts on start up but cuts out
    Problem Solver:
  • 5 Answers
Replace the laser but first find out if you have a single or double len
Posted on Oct 08, 2009
I load a dvd in the sylvania sdvd 9009 player and it says no disc after loading
If the DVD loads, there should be something on the display that indicates it is being read (maybe a spinning disc icon). If it tries to read, then displays the "no disc" icon it means either that particular DVD can't be read or the drive has failed. If you try another DVD and get the same result, you can be pretty sure the drive has failed
Dec 16, 2012 | Televison & Video
Remove cdrom drive
Removing the cd rom drive will not make your computer start up. Or are you saying the cd rom drive will not start up? CD rom drives are very sensitive on the disks they read. Most of them have a problem reading some of the discs that someone created on another computer. Make sure you're trying to read store bought discs.
Removing the cdrom drive is very simple. Turn the laptop over and you will normally see a screw with the icon of a circular cd on it. remove that screw then you can grab the cd rom unit by the door and pull it outl
Mar 19, 2012 | HEWLETT-PACKARD Pavilion dv7-1247cl...
Cd rom drive reads some cd's and not others
If those other discs are working in other cdrom drives then you could have a dirty cdrom drive, a laser failure, or it could be a firmware problem in that drive. Check the mfr's website for any firmware updates first. If that should fail, then you will need to replace the drive.
What's happening inside is, you have a laser inside that bounces a beam off the disc and receives the beam into a buffer. The beam scans for and detects "Pits" and "plateaus" on the surface of the disc (it's kinda like morse code on a plastic disc.) and the dots and dashes reflect into the buffer.
If you cannot read a disc, that means the laser is having trouble with either:
1. emitting the beam,
2. targeting the tracks where the pits and plateaus are or
3. receiving the beam into its buffer
SOMETIMES a burned disc is harder to read by a standard reader, but not often. Most times it is a sign of dirt on the buffer receiver, dirt on the lens, or inability to scan the tracks. Try using a cdrom lens cleaner, and update the drive firmware. if that doesnt help you, you need a new drive.
May 17, 2010 | Dell (6T980-A01) CD-ROM Drive
Disc icon does not display after loading a disc, only loading icon
Take a can of air and blow some into the drive. This will make sure there is no dust or dirt affecting the laser.
After this try multiple discs to see if it will read anything, if it doesn't read anything then the laser is bad and would need to be replaced or you can just replace the dvd drive itself, you can get them off of Ebay at a fairly decent price.
Dec 02, 2009 | Sony Playstation 3 (PS3) Console
Bought still life 2, have windows xp...game won't load . It just clicks but won't come up on the screen at all.
Hello mis_74,
First things first What type of Disc Drive are you using ?
CD Rom
CD/DVD Drive
Requirements are that you use a CD/DVD Rom Drive.
Next make sure the disc itself is not smudged with finger prints ect. Also check for scratches on the disc. Making sure it is clean ensures that the laser is correctly reading the disc.
Double check and see if other disc's DVD's and CD's will play in the same drive to ensure the drive itself is not bad.
Post back if you are still having problems after verifying that these things are not causing the issue.
Thank you for choosing Fixya!
Aug 25, 2009 | Microids Still Life for Windows
Hard drive not Reading CD-R Discs
First off. Your hard drive cannot read CD's. Your CD-ROM is not reading CD's. Well a few things can be wrong there. 1. The CD-ROM is dead 2. The drivers for the CD-ROM needs updating 3. The CD that you are trying to read is curropt or damaged.
Start checking to eliminate and let me know.
Aug 13, 2009 | Acer America Co - Aspire Desktop 4GB 640GB...
I have an acer extensa 5420 and the disc drive will not play cds or dvds
Hi, your pc might have a hardware problem issue.
The disc drive might have gone bad already and need to be replace it. If the laptop is still under warranty, I would go ahead and consult with the manufacture for replacement.
yourcan verify if the window is cause the problem by right click on My Computer icon on your desktop and select Manage and Device Manager. If you can see the DVD/CD ROM drive status with Plus sign next to it, click on the plus sight and you should see your dvd/cd rom drive install on your Laptop. This mean window is reconizing the device but the device doesn't read the disc because it has a problem.
Hope this help.
Kam
Dec 10, 2008 | Acer Extensa 4620 Notebook
Relatd to slow working
These are two different problems...
1. most likely you have loaded too many programmes in the startup...uninstall the unwanted programmes...and clean the registry by registry cleaner.... clean your c drive or the drive in which OS is loaded by system tool...disc cleanup (in accessories)
2. increase your RAM if you still want to use all the programmes you have loaded.
3. Use a cd rom cleaner disc to see it the rom stars reading...or else you will have to replace the CD Rom
Apr 06, 2008 | Computers & Internet
I hate my computer!
No, this doesn't cost unless you sign up for Premium Assistance.
  1. Remove the disc from the drive.
  2. Look at the top of the disc (or game box). Verify whether it is a CDROM or DVD-ROM.
  3. If it is a DVD-ROM, verify the drive on your computer that you are inserting the disc into is capable of reading DVD-ROMs.
  4. Go to My Computer and verify which drive letter is the drive you'll be inserting the disc into.
  5. Insert the disc.
  6. Wait 20 seconds. If the disc doesn't automatically start up, go to step 7.
  7. Open My Computer and double click the drive containing the disc.
  8. If My Computer now shows the disc contents, find the most likely ".exe" file and run it.
Mar 06, 2008 | Computers & Internet
DVD+RW
dot.gif Unable to read a CD-R or other recordable disc. Question: Unable to read a CD-R or other recordable disc.
Answer: Unfortunately this can be a difficult question to answer because of the amount of potential reasons for this issue to occur. Below is a listing of several steps and recommendations that can be taken to help identify the cause of the issue and/or resolve this issue.
Drivers Verify you have the latest drivers installed for the CD-R or recordable drive. There are numerous driver related issues that may cause a CD-R drive or other recordable to stop reading a CD-R disc. If you are running Microsoft Windows verify your drive is properly detected and listed in Device Manager with no conflicts or errors.
If Windows Device Manager detects an error on the drive or if it has other drives listed in Device Manager with errors on them remove the device from Device Manager and reboot the computer to let Windows re-initialize the drive.
If Windows shows no errors, the above steps did not resolve the issue, or you are running a different operating system check with the drive manufacturer for updated drivers. A listing of disc drivers can be found here.
CD-R disk Not all CD-R disks are compatible with all types and speeds of CD-R drives or other recordable drives (especially earlier CD-R drives). Verify the manufacturer gives 100% guarantee for supporting all drives and disc speeds, for example, TDK discs often give a 100% guarantee.
Pre-mastering/Mastering Software Pre-mastering software can sometimes produce incorrect tracks due to bugs. An incorrect ISO image could be generated, or incorrect sub header codes could be recorded in the case of Mode 2 discs. A good way to check whether the incompatibility problems lie with the originating software or with one of the other causes listed above is to test the same disc on several CD-ROM drives. If one drive is capable of reading the disc back correctly, chances are that the problem was not in the mastering, but is one or more of the other factors listed.
Disc is a recordable disc that the drive or player does not support Verify the drive supports the recordable media you are attempting to read. Below are some situations to watch out for.
  • Old CD-ROM or early DVD drive - Some early CD-ROM drives and Gen 1 DVD drives (some of the first DVD drives released) do not support CD-R discs and/or CD-RW discs. Not only does this apply to computers but also home entertainment DVD players.
  • CD-RW in CD-R or CD-ROM drive - CD-R drives are incapable of reading CD-RW drives. If you are using a CD-RW disc verify the drive is a CD-ROM or CD-R drive is capable of reading the disc.
  • DVD recordable discs - If you have a DVD recordable disc and are unable to get it to read verify that the DVD drive is not a Gen 1 DVD drive and/or that it supports reading the DVD recordable media you are using. Additionally a standard CD-ROM, CD-R, CD-RW, etc drive is not able to read DVD discs.
Disc was created incorrectly Make sure you're creating the disc properly. For example, a common mistake users make when creating audio CD's that they can listen to in their computer, car, or home stereo is burning the MP3 files or other files directly to the CD as a Data disc and not an Audio disc. All this will do is burn the data files to the disc and not create an audio disc. This may allow you to listen to the audio files in the computer but will not allow you to listen to the music in the majority of other CD players unless they support MP3 format.
Disc or DVD contains media content not supported by the player Not all home entertainment DVD players are capable of supporting and playing all the different formats movie files and audio files are stored in. Make sure the format or codec of the movie or audio file you're saving to the CD or DVD is supported by the DVD player. If you're computer is capable of playing the files off the DVD but your home entertainment DVD player is not able to play the file it's likely you're encountering this issue.
Bad disc If after reading through the above recommendations you still continue to have the same issue it's possible that the disc is a bad disc. Try re-burning the disc and if possible try a different type of recordable disc.
Computer DVD Support
Click on the above link should get ya back up and going/Good Luck....Please dont for get to Vote.Thank you.
Dec 15, 2007 | HP Pavilion zd8000 Notebook
Sony Playstation 3 (PS3) Console Logo
124 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
marley mcelhinney
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
