Question about RCA HD52W59 HDTV Projection Television
My rca hdtv has a 3d look, and it is blurry, what can i do
My 56 rca hdtv has a 3d look and is blurry, what can i do
I did the convergance,
worked on setup and tried all areas contrast, light dark,
If I could pull the picture in a bit it might get clear.
How can I make the picture smaller?
  • Cordia Dec 26, 2007
    The convergance is good. The +'s line up real well.
    The main problem is that the picture looks cloudy or foggy, not sharp
    How can I fix that???
    Thank you for your help.
    Cordia
  • 143 Answers
This 3d look is coused by bad convergance ics you have to replace them no adustment will fix this
Posted on Dec 24, 2007
  • marco amezcua
    marco amezcua Dec 26, 2007
    ok if you can take the back off so that you can see the pic tubes then you can clean them with windex and a lint free rag try this get back to me k
  • marco amezcua
    marco amezcua Dec 27, 2007
    ok this is what i found out about this set take the back off you have to clean the three picture tubes and the mirror inside the set this will fix your problem the mirror just got dirty that is all windex and a small lint free rag will fix this good luck
Tv is blurry and looks like 3d
Follow the manufactures instructions for adjusting focus and or convergance. If it persists please contact an authorize service center as the adjustment is near HIGH VOLTAGE circuits.
Mar 20, 2011 | RCA HD56W66 56" HDTV
TV is blurry and the red and green look as if the picture is in 3d and I need glasses. Can I fix this myself?
There is almost nothing that can be fixed by yourself if your not trained in high voltages and advanced circuitry now days. This sounds like it could be your color guns going bad or the power supply.
This set also has an issue with The tv convergence board,require 2 STK convergence ICS and some or all it resistors to replaced to solved the tv convergence picture problems.
Jan 12, 2011 | RCA HD56W58 56" HDTV
How do i fix blurry picture on 56 inch toshiba
Ur convergence is dead.Must know how to solders?Must replaced 2 convergence ICS,and some or all it resistors.Tries websites Tv repair World.com,Tvrepairkits.com to buy a cconvergence kit to repair it ur self.The shop will cost u $300 for parts and labors.
Mar 15, 2010 | RCA D52W20 52" Rear Projection HDTV-Ready...
I have a problem with my 56 inch rca tv while looking at it it looks like your watching a 3D movie can you help?
Ur convergence is dead,Buy a convergence kit use what in that kit.U know how to solder right.Tries these websites for kits.Tv Repair World.com or Ebay.com.
Sep 29, 2009 | RCA HD52W59 HDTV Projection Television
3D looking pic. on my RCA-P52813BL
The prob.is ur covergence.Go to menu setup look for convergence,see no convergence.U have an open Fuse(FL231)lacated right side of the Flyback Transformer.There are 3 in a roll small brown rectangle looking caps,but they are fuses.The one in the middle is dead.
Sep 02, 2009 | RCA P52812BL 52" Rear Projection...
Rca 7302rd5 56"hdtv tv looks like a 3d moive
Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
This is a very common failure on these projection sets and a fairly simple DIY fix. All projection sets including Samsung, RCA, Sony, Philip Magnavox, Panasonic, Pioneer, Akai, GE, JVC, Toshiba, and others at some point will have the same problem.
Common Symptoms include....
•Screen looks 3D
•Colors don't line up
•One or more colors can't be adjusted when using the convergence menu.
•Screen is bowed or warped.
•TV shuts off after powering on. Power light will blink. TV may also make a chirping noise.
Here are some photos of convergence problems
fcabb43.pngCONVERGENCE SOLUTION
You can see some more examples and find a fix using this link on Fixya - CLICK HERE
Jul 03, 2009 | RCA R52WM24 52" HDTV Projection Television
The convergence box keeps going out.
this 3d effect is due to what is known as convergence.i work daily on these set in the shop. (thats a good testomony for these LOL) but the first question i ask is 1 in the customer setup do you have convergence option.. Next question is the picture bow tie looking and 3d. if you are missing the convergence option chances are it is the fl231 fuse. then you need to read the fl231 fuse under tips and tricks section of this website. Convegence is controled by three cuicit boards. if any of these need to be replace a technician may need to set or adjust the convergence back to faactory specs
Apr 18, 2009 | RCA HD56W66 56" HDTV
RCA HDTV
go into the menu
looking for set up tab
looking for convergence tab
looking for automatic convergence. apply.
Fixed. NO? tv has a problem in the convergence area. Technican Job
Apr 08, 2009 | RCA R52WM24 52" HDTV Projection Television
FL231 fuse on RCA hd56w66??
the rca itc222 comes in both 56 and 52 version.. If you do not have the convergence option in the customer menu under setup then there is a high chance that the fuse will be the trouble
Oct 02, 2008 | RCA HD56W66 56" HDTV
Go to setup , and conversion settings. set convertions.If it wont set correctly you must replace or let it been replaced by tech. If you are a tech you can set convertions manualy by go in to service menu. It takes sometimes up to 4 hours to set. But remember to save.
Dec 23, 2007 | RCA HD52W59 HDTV Projection Television
RCA HD52W59 HDTV Projection Television Logo
150 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
