Question about Sport & Outdoor - Others
Pioneer amplifier model gr 510
My pioneer amplifier model gr 510 plug in to the wall when i on the switch no power occur. What am i going to do?
    Problem Solver:
  • 20 Answers
Here is some great PC solution by Some FIXYA EXPERT. Get any kinds of PC solution from bellow.
  1. Intel MotherBoard
  2. Mercury Motherboard
  3. Gigabyte Motherboard
  4. MSI Motherboard
  5. P5GC-MX/1333 Motherboard
  6. ASUS Motherboard
  7. IBM
  8. Packard Bell
  9. via
a13
Posted on Oct 10, 2009
I have a pioneer GM-X524 amp connected to a TS-W253C subwoofer and it isn't working. It has 12v power to it and a solid ground, but the power light wont come on and the sub isnt working
there should be 3 power related cables connected to the amplifier:
1-From battery to amp via fuse (positive)
2-From chassis of car to amplifier (negative)
3-From head units (power continuous) (blue or blue/white cable) to the amplifiers remote connection.
this connection enables the amplifier to switch on when the head unit is switched on and off when the headunit is switched off.
I hope this helps and let me know if I can further assist you.
....andy....
Jan 06, 2014 | Pioneer Car Audio & Video
I have an pioneer SA-510 amplifier and i want to know how to connect it to my laptop and what kind of aux i need ? plz help
Just go to Radio Shack and buy a 1/8 male stereo cable and the other end with 2 male RCA plugs and connect them to the AUX or CD input of your receiver, the 1/8 male connector goes to your earphones output of your laptop, hope it helps.
Sep 08, 2013 | Audio Players & Recorders
Receiver keeps going to standby
I don't know about the newer receivers but this sounds like an arching OFF/ON power switch that was a problem on Pioneer receivers years ago. I would bypass the switch and see what happens.
1. Unplug unit from wall.
2. Jumper two wires going to off/on switch using alligator clip with insulated boots on clips.
3. Plug amplifier into disconnected circuit breaker/fuse protected AC strip.
4. Plug AC strip into wall outlet, turn AC strip switch ON and see if problem disappears.
Feb 20, 2013 | Insignia 200W Stereo Receiver
Pioneer audio/video receiver damaged
Hi...
The problem is probably that the bad connection "took out" a couple of the power transistors/power mods in the amplifier
If you need a pro to fix it I can suggest someone depending on where you live
Apr 15, 2010 | Pioneer Audio Players & Recorders
Cannot get power to sub woofer...
Maybe you could name the subwoofer model so we know what it needs for input.
And we need to be careful with the indiscriminate use of the word 'power' in audio discussions. There's wall power and there's amplifier (audio) power.
In the case of subwoofers, some are self-powered (AC power cord plugged into the wall and an amplifier built-in; usually receives subwoofer-specific audio program via RCA cables from YOUR source); others are passive (just get audio power from YOUR amplifier.
Apr 09, 2010 | Pioneer VSX-D504 Receiver
Pioneer M-980 Amplifier not working
Your power switch is arcing.
Needs to be replaced
Check for any fuse on PC boards and make sure theyre ok
Jan 21, 2010 | Pioneer Audio Players & Recorders
Pioneer GM5300T-760amp w/bridgeable
It sound like the Amp is trying to protect itself:
From the manual:
"To prevent malfunction of the amplifier and
speakers, the protective circuit will cut the power
supply to the amplifier (sound will stop) when an
abnormal condition occurs. In such a case, switch
the power to the system OFF and check the
connection of the power supply and speakers."
Although I'm leaning toward the speaker config, double check the obvious first.
  • power cables - both positive and ground heavy enough gauge?
  • speaker cables
  • solid connections, crimps
The next check is the speakers themselves. More info needed.
How many? 1, 2, 4?
Are they 8 Ohms? 4 Ohms?
How are they wired?
  • One to a channel?
  • Series?
  • Parallel?
  • Bridged?
In case you don't have one, here's a link to the
GM-5300t Owners Manual
If you still have problems, get back to me with speaker specs and configuration.
Hope this helps
Mike
Jul 20, 2008 | Pioneer Car Audio & Video
Hook up pioneer stereo amplifier model SA-1270
for audio system always you have left and right channels.
get the output (left&right) from tuner---go to equalizer input left&right.---from equalizer output go to amplifier inputs.and certainly from amplifier output to speaker.
Oct 15, 2007 | Audio Players & Recorders
Pioneer GM-7300M 800 Watt amp will not power on
This may have a different type of triggered turn on wire. On some of the older Pioneer amps (and maybe some new ones) the trigger wire would SUPPLY B+ TO THE RADIO and when the radio was switched on the amp would sense a current draw on that wire and would then switch on. Unlike most common amps which sense the presence of B+ on the trigger wire supplied by the radio and then turn on. Look in your owners manual to see kind of turn on system you have. If you don't have an owners manual then perhaps you can download one from Pioneer support. good luck
Aug 23, 2007 | Pioneer GM-7200M Car Audio Amplifier
Woofer problem
If I am not mistaking here, you need a self powered subwoofer to use with this unit. Those are line driven outputs for this unit. Make sure there is a wall plug on the sub that is plugged in. Good Luck
Jun 07, 2007 | Pioneer VSX-516-K/S Amplifier
Sport & Outdoor - Others Logo
Top Sport & Outdoor - Others Experts
Bill Eager
Are you a Sport and Outdoor - Other Expert? Answer questions, earn points and help others
