Question about Craftsman Garden
Blades will not disengage
Blades engage but won't disengage. The blade clutch lever is loose about 1/3 of the way and you really have to put pressure on it to engage the blades--much more so than normal. If I drive around with the lever disengaged (and blades still mowing) they will eventually (a minute or two) disengage.
  • 472 Answers
SOUNDS LIKE THE CABEL IS BAD IF IT HAS ONE OR THE ENGAGEMENT IS BENT
Posted on Oct 08, 2009
Testimonial: "This is what I concluded too. I have ordered the part, and we'll see."
What will cause blades on J.Deere G100 mower to Freely turn by hand without causing Spindles or belt to turn even though Bolts are still tight and when installed Blade turned only if spindle turned
Do Ray:
If the blade engagement lever is in the disengaged position, the belt will be loose, allowing you to turn the blades by hand. If you place the blade engagement lever in the engaged position (with the motor off) it will be hard to turn the blades because of the tension on the belt. If the blades are still easy to turn with the blade engagement lever in the engaged position, you need to replace the blade drive belt!
Jun 15, 2015 | Garden
When I engage the lever for the blades to start cutting, the blades don't engage
Check for bad or loose belt also see if you are missing a shear pin in one of your drive pulleys. See if your lever to engage the blades is actually putting driving pressure on the belt. Could be a spring is missing as well.
Apr 12, 2015 | Garden
Craftsman zero turn runs but blades won't engage.
if got elect. pto/ and clutch,could have a wire connector come loose
Oct 21, 2012 | Craftsman Garden
I have a mountfield 1538h-sd blades disengaged while mowing belts seem very slack ,but the belts are all on the pulleys.
The belts may be loose.With the mower off,engage the blades and check the tension.Next would be to get under the mower and check for debris in and around the lever that engages the blades.Sometimes trash will get hung up in there and the blades will disengage.The next step would be to inspect the pulleys for debris and to make sure the spindles are not bent.While at the pulleys make sure there are no burrs or cacks in the pulleys,as that will cause the blades to disengage.
Jun 03, 2011 | Garden
I have a Husqvarna CTH 171. When i engage the blades they
http://weborder.husqvarna.com/order_static/doc/HO/HO2005/HO2005_5321938-34.pdf
This is the owners manual if you do not have one.
There is a brake on the pulley, make sure that is not hanging up.
Please let me know what you find.
Feb 08, 2010 | Husqvarna 23 Hp 48" Deck Yard Tractor
Craftsman riding mower Model 917.270824
I do not believe there is a manual available to the public for troubleshooting, however, you have at least 3 switches to tell the mower to stop when blades are engaged or clutch pedal released.
Seat switch
pedal switch
mower engage switch
The pedal and mower lever switches are identical, and have two sides, one for starting, one for blades turning. One side can fail. The pedal switch is on the frame very close to the pivot point of the pedal/shaft. The mower switch will be under the dash close to the bottom of the lever.
1) Locate and inspect the switches for broken or pinch wires, switch housing, or loose mounting, and how each lever or pedal engages the swtich.
2) This is a picture of the wiring so that you can get a better idea of location.
http://www.searspartsdirect.com/partsdirect/getSubComp.pd?modelNumber=917270824&productCategoryId=1509200&brandId=0247&modelName=TRACTOR&diagramPageId=00011&componentDescription=SCHEMATIC%20DIAGRAM-TRACTOR&documentId=P0811014&blt=06
http://www.searspartsdirect.com/partsdirect/getSubComp.pd?modelNumber=917270824&productCategoryId=1509200&brandId=0247&modelName=TRACTOR&diagramPageId=00001&componentDescription=ELECTRICAL&documentId=P0811014&blt=06
I’m happy to assist further over the phone at https://www.6ya.com/expert/rolandw_c013176d62ee17ae
Nov 11, 2009 | Craftsman Garden
I have rjdeing lawnmower with a BRIGGS&STRATTON 13.5 OHL WHEN YOU PUT IT IN GEAR AND ENGAGE THE BLADE IT LOSES POWER WQNT RUN. FAMLEY 4BSXS.3442VM 275943
if you mean that when you let off the clutch pedal and/or engage the blades, the engine dies, lift the seat and make sure the connector is firmly plugged into the switch attached to the seat.
Sep 28, 2009 | Briggs & Stratton Garden
Craftsman riding mower blades won't disengage
This is too late, but for the next person: There is an extension spring around the cable attached to the blade engage/disengage lever.
On my tractor one end of the spring had the hook broken off or it. Because it is around the cable it is still in place but doesn't stretch when you engage the blade (so can't pull the pulley out and slacken the belt when you disengage).
The replacement is a few dollars and can be bought on ebay or Amazon.
Aug 15, 2009 | Garden
My blades wont engage and just hear click sound?
No permanent solution, but you probably can get by once by "riding" the clutch engagement lever - pushing it only part way forward and holding onto it.
Jun 27, 2009 | Cub Cadet Street Sign- tractor lawn riding...
Garden Logo
893 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Jim Parker
Jim Parker
Dennis Key
Dennis Key
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
