Question about ASUS P5P800S Motherboard
New asus mother board, no display
I installed a new asus motherboard. I get no video display on power-up.
I checked all of the usual suspects, cpu is installed correctly, memory is reseated and installed correctly. The power supply is a new 450 watt. All fans are running and in place. I reset the bios and remved all card from slots.
    Scholar:
  • 73 Answers
Do you get a POST beep? If not, then it is possible you ended up with a dead mobo... manufacturing defects do happen, and ASUS will be happy to replace it for you (they're quite good with it, actually).
If you do get a beep code, could you please post what it is?
Posted on Dec 25, 2007
Looking to get new mother board because it went on fire, old mother bd was asus P5VD1-X HAVE INTERL P-4 CHIP AND DDR 400 MEMORY THAT I WOULD LIKE TO KEEP USING WHAT MOTHER BOARD DO YOU SUGGEST
Better to purchase new mobo, cpu n memory. Bcoz the compatible Motherboard for your CPU/Memory is no longer available. If it is available, only from the dead stock or refurbished. Better to purchase new motherboard/cpu/memory
Sep 17, 2010 | VIA Asus P5VD1-X PT880 Ultra Chipset 1066...
Changed out power supply, now can't get video to work
pls ckh ur power supply 5v 12v again other wise change power supply.
pls, chk it is at,or atx power supply.
or ur mother disply ic is damage
inset new display card.
Feb 23, 2010 | Intel ASUS P4S800-MX SiS661FX Motherboard...
MOTHER BOARD NOT POWERING ON
I want you to try first swap the power supply box  of the PC if no change ?
go to the CPU socket remove the CPU check if any component is burnt that area if ok put a new CPU  then on it .
If still behaving the same ,then the mother board is bad get a new mother board
Good luck
Oct 01, 2009 | Foxconn P9657AA-8EKRS2H (6938279104065)...
ASUS K8S-MX PC powers up but no display on monitor and no error codes. Hard drives spin and sounds as if it is in boot routine
OPEN UR CPU AND OUT UR RAM FROM MOTHERBOARD AND START UR PC WITHOUT RAM IS IT BEEP OR NOT IF IT BEEP THEN CLEAN UR RAM AND RE INSERT IN MOTHER BOARD AND THEN START UR PC IS IT OK
IF NOT THEN PICOUT BATERY CELL 2032 FROM MOTHER BOARD AND THEN START UR PC
IS IT BEEP WITHOUT RAM AND CELL IF YES THEN CLEAN UR RAM AND RE INSERT IN MOTHER BOARD AND THEN START UR PC
IF IT IS OK THEN CHANGE UR BATTERY WITH NEW ONE
IF UR PC BEEP WITHOUT RAM BUT NO DISPLAY WITH RAM THEN CHANGE UR RAM WITH NEW ONE.
Jul 01, 2009 | ASUS K8S-MX Motherboard
I am facing 2nd problem with my pc.
Most likely problem is an unsuppoterd cpu. Check the Asus website to see if cpu you installed is compatible with this board.
Dec 22, 2008 | ASUS P4S533-MX Motherboard
The cpu not on
You wil have to give me more details please
Oct 17, 2008 | ASUS P4P800 SE (890552603657) Motherboard
Vcore power adapter for the cpu
Being that it's new it's probably still covered under warranty. Sounds like the motherboard is the suspect.
Jul 23, 2008 | DFI LANParty UT RDX200 CF-DR Motherboard
ASUS P4VP-MX display problem
If I understand you right, your display is not coming on with your new hardware. Try the eliminaion process:
take out the new things. Install them one by one, and try booting each time you install one. If that passes, turn off and install the next one, until you isolate the one failing. Once you know it, installit properly or come back here for help.
Feb 18, 2008 | ASUS P4VP-MX Motherboard
Built a new Computer
What cpu do you use just now? Is it a pcie or agp card that you have? Is the ram ddr or ddr2? What you have ram/graphics wise will effect the upgrade path if you wish to continue using them. How much are you looking to spend?
Jan 04, 2008 | ASUS AI Lifestylestyle M2N-SLI Deluxe...
ASUS P5P800S Motherboard Logo
91 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
David
David
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
