Question about Microlife 3MQ1 Blood Pressure Monitor
Cuff is leaking how much is new how much is
Cuff is leaking how much is new how much is shipping to 94565 3mq1
    Problem Solver:
  • 5 Answers
Contact your vendor.
Posted on Oct 14, 2009
Error code EE or E
Check your user manual, there should be a section on error codes. Most often E or EE errors are leaking cuff or improper use.
Aug 16, 2013 | Omron Hem 712CLCN2 Cuff Blood Pressure...
Upper radiator hose keeps leaking coolant, replaced the cuff ring but still seems to leak after a few days from the cuffed end of the hose. Does it need a new hose?
if it is leaking where it connects to the radiator it might be the radiator itself. take it to a shop and they can pressure test. some shops won't even charge for test.
Sep 14, 2012 | 1995 Buick Regal
My blood pressure machine starts then stops and restarts quite a few times
It sounds as if there's a leak somewhere in the system. Make sure all the lines are well-connected, and that the cuff isn't leaking.
Jul 10, 2011 | Sunbeam DIgital Blood Pressure Monitor...
More frequently my Omron HEM-780 seems flaky. It would apply pressure and count up to 112-120 then start deflating, then inflating, etc. Then it would count down by units and end up displaying E. It would...
Part of the problem may the the placement of the cuff. Generally, if it's not placed correctly. the cuff will re-inflate trying to find the correct stopping point for inflation. Any movement of your arm could cause this. Also, if you haven't replaced the batteries lately, you should do that. Also check to make sure there are no air leaks in the rubber tubing or the cuff. Check your Owners Manual for the exact placement of the cuff.
Feb 07, 2011 | Omron HEM 780 Automatic Blood Pressure...
We have a large adult cuff. The index is in the "select adult cuff" zone. Is there an adult cuff for this unit that is interchangeable ( so we don't have to purchase a whole new unit...just a...
If your arm circumference suit this "large adult cuff" and the machine give good result, you dont need to change the cuff. Otherwise, you can just ask for replace with just a regular size cuff 22 - 32 or 36mm
Jan 06, 2011 | Mabis Health & Beauty
Digital wrist model # SR303S, shows error 3, has new batteries
Possible explanations and work-arounds based on various blood pressure monitors..net is if it has worked religiously like mine had and this error comes up, and the simple fixes below do not work, there is something internally wrong with the unit..there does not seem to be any customer reset or obvious fixes..contact the manufacturer for service..
Error Description Potential cause and remedy
«Err 3» No pressure in the cuff
An adequate pressure cannot be generated in the cuff. A leak
may have occurred. Replace the batteries if necessary. Repeat the
measurement.
Error Codes
Err 0 No pulse is detected
Err 1 Inflation rate is too low
Err 2 Systolic reading unattainable
Err 3 Cuff pressure is too high
Err 4 Diastolic pressure is outside of operation range
Err 5 Cuff deflated too fast
Err 6 Cuff deflated too slow
Err 7 Systolic pressure is outside of operation range
Err 8 Overall pressure is outside of operation range
Err 9 Cuff is unable to inflate to the necessary pressure level
Error No. Possible cause(s)
Err 1 No pulse has been detected. Cuff may be positioned incorrectly.
Err 2 The arm was moved during the measurement.
Err 3 Inflation of the cuff took too long. The cuff is not positioned correctly.
Jan 04, 2011 | Samsung Health & Beauty
I keep getting an error code E83 Timeout:Inflation. I need to be checking my sons BP. Is there a trouble shooting i can perform? What do i do?
How old is the cuff? If it has written on it "single use" and you've been using it a while you may have microleaks which means you need a new cuff. Also, check the hose for holes (usually found where the hose splits and connects to the cuff). Last, check the Dinamap to hose connector are the black orings still on the connecting posts?
Critikon/Ge utilizes the oscillitory method for determining NIBP. In other words, it pressurizes the cuff, stabilizes, decreases pressure slightly, stabilizes, etc. so a leak in the cuff or hose won't allow the pressure to stabilize resulting in an E83 error.
Nov 04, 2010 | General Electric Dinamap ProCare Series...
Cuff won't inflate
It probably has a leak. Examine the hose and cuff for cracks by flexing it , especially at the fitting where the hose attaches to the monitor. Also check where the hose attaches to the cuff. Try replacing the cuff.
Hope it helps. Please let me know.
Thanks
Apr 22, 2010 | Mabis Automatic Digital Blood Pressure...
Walgreens HD303 Blood Pressure Monitor error 3
measurement.
Error Codes
Apr 08, 2010 | Walgreens Wrist Blood Pressure Monitor
Accuracy problem
Hello martintpjr, the difference could be your physical postion,(sitting,laying) location of cuff(on the fore arm), not as relaxed, cuff/tubing has a air leak,or unit is out of calibration. Eliminate the first four than contact the local college or BioMed shop in the local hospital and KINDLY ask if your unit operation/calibration could be checked. Merry Christmas.
Dec 12, 2008 | Omron Automatic Blood Pressure Monitor...
Microlife 3MQ1 Blood Pressure Monitor Logo
181 people viewed this question
Top Microlife Health & Beauty Experts
Colin Stickland
Colin Stickland
Steve
Are you a Microlife Health and Beauty Expert? Answer questions, earn points and help others
