No picture only sound power supply looks ok no blinking in led in front.
  • sergioaguirr Oct 08, 2009
    i have a sony lcd kdl-40v4100 i have sound but no picture. im not sure if is the inverter. voltages in power supply ok. please help. thanks
    this is not a lcd projection its a lcd flat screen. no picture but sound ok. voltages in power supply ok model kdl-40v4100
  • 6,924 Answers
I would remove the rear panel ,and pull boards out enough to look under them.Look for a cold solder joint holding a heat sink in.These are not done on the assembly line very well,and this could be the problem.You can clean and resolder the heat sink leg back to the board.I hope this is helpful,if so,let us know,thank you.
Posted on Oct 09, 2009
  • 708 Answers
IF you have sound then power supply is ok. sounds like it is time to replace the bulb.
Posted on Oct 08, 2009
  • 11,896 Answers
Most likely a faulty IC or STK depending on what type you have. Capacitors do get overheated easily now-days due to being made cheaper and less room for air movement in the newer style sets.
Samsung Plasma won't power on
this is not a capacitor problem. set is only 18 months old - has something to do with x y sustain boards not allowing smps to power on the high voltages.
May 27, 2013 | Samsung Televison & Video
No picture or sound, will not switch on/but red stand buy led blinks. Model LE19A13BTDG888
Stand by is on the power board but it is possible for standby to be up and running and main supply not working. Did you look for bad caps on power board or any voltages coming out of that board?
Dec 20, 2012 | Televison & Video
42 inch philips lcd no picture no sound
Sometime a no picture, no sound still has the power light or some other led blinking. The blinks might be an error code that will isolate the problem.
In general on LCD TVs with no picture, no sound, no blink code, the main power supply has failed. The capacitors weaken and when bad enough, damage the power supply.
If there is a blink code, the most, if not all of the power supply is OK and the blink code could point to the problem.
Jan 19, 2011 | Philips 42PFL7422D 42 in. LCD TV
I have a z20lcd1 tv and it has no picture
in the lcd tv there are three main parts
1)the inverter board(pannel)
2)the main board .
3)the power supply board.
if there is no power at all them main board is faulty.if no front led light is coming ON there is no power .so the main board is not faulty.on the main board there is a fuse located you have to replace that and check first if still no power main board needs to be checked and replaced
if there is sound but no picture and front led light is blinking then its inverter board panel problem.if this is your case replace inverter panel.its located in the lower side of the lcd in the inner area below the main board.
but if there is just front led light blinking , but no picture or sound then its power supply board problem.
on power supply board there are some capacitors and ic located.if any of the component gets short or budged up then it short the power supply board.so you can check the components on power supply board with multimeter and get it replaced by using soldering iron.
also you can get new replaCEment power supply board.this clears the problem completely.
you can get the required board and components at ----- www.partstore.com -------- or from ------ www.radioshack.com ----
if you are not familiar with doing this you can get it done by local tv repair technician familiar with this model tv.
Nov 03, 2009 | Zenith Z19LCD3 TV
Philips 42pf9630/37a, Blink red LED 7 times, No Picture No Sound
7 blinks indicates a bad buffer board, usually I replaced the Y board and the buffer/s about $500-600 in parts. but before you buy anything open the set and look at the power supply if you see two capacitors that look swollen , bulging on top they need to be changed and may solve the issue. the power supply is middle top . If you are not wanting to repair it yourself then know that you do have some circuit board repairs needed.
thanks
Eric
Aug 17, 2009 | Philips 42PF7320 42 in. EDTV-Ready Plasma...
AKAI LCT26Z4AD wont power up.
Those blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices.
http://homenol.blogspot.com/
If blinks continue without any pause, the main board is faulty.
Mar 10, 2017 | Televison & Video
Power Problem
usually blink code on front gives direction but first thing to do would be to determine if surrounding sustain boards are causing draw on power supply by disconnecting them one at a time from power supply. y is on left looking from back and x is on right looking from back. if led goes solid with either board disconnected check supply voltages and if come up and stay up replace that board. if no change then you would need to verify vs on command coming from logic main to power supply. should be labeled on power supply connector and should be 3 volts. if present replace power supply if not present verify if logic main board sitting underneath signal board has one solid and one blinking led on if verifying normal operation and if so replace small signal board
Aug 15, 2008 | Philips 42PFP5332D 42 in. Plasma...
Philips 42PF9630A 42 in. Plasma 42 in. Plasma
Ok 7 red blinking led, remove the back cover of the TV. Looking at the power supply in the upper left of power supply. If everything is working fine you will see a solid green led if there is an error, you will see this light blinking also. Right below this led on the power board you will see a list of numbers 1-13 this will give u the problems that this led flashing problems are. More and likely u will have a problem with VSET or VSCAN. Which is connected to the Y-Main and Y-buffers,( the board that is too the left of the power supply if u look on the small print on this board you will see that it reads. 42HDV4 Ymain and the 2 small boards connected to it are Y buffers. To be sure that this board is bad if the TV keeps going into error protection. unplug the power supply and wait for the led to stop flashing. Disconnect the cable that plugs into Y-Main from the Power Supply. It should stay running. If u remove this board and look underneath u should be able to see where this board is getting hot. Easiest fix is to order a replacement. Y-main assembly.
May 05, 2008 | Televison & Video
Mitsubishi VS-50607
This model is equipped with a self-diagnosis feature to help with diagnosis of shutdown problems. To activate this turn the unit on let it shutdown then press the input/device and menu buttons on the front panel simultaneously and hold them in for 5 seconds after 5 seconds the power LED on the front panel will blink a two digit sequence. This will be one set of blinks a short pause then another set of blinks, this will repeat 5 times. 1 - 2 = no error detected 2 - 1 = X-ray protect (high voltage or beam current) 2 - 2 = Short protect (short protect monitors low voltage supplies) 2 - 3 = Deflection protect (this could be loss of vertical or horizontal deflection) 2 - 4 = Vertical protect (usually loss of vertical from the source.
Oct 04, 2007 | Mitsubishi VS-50607 50" Rear Projection...
Televison & Video Logo
26 people viewed this question
Top Televison & Video Experts
Electro Med Services...
