Question about Sony Ericsson K800i Cellular Phone
Help k800i emergency calls only, how do i get this off k800i phone
I have the same i don't have a clue?!? HELP US!
Posted on Jul 24, 2008
    Brigadier General:
  • 7,752 Answers
You need to explain the problem more in depth, you can try to search for the network manually.
Posted on Dec 24, 2007
Sony ericesson k810i emergency call only
If your Sony Ericsson K800i Mobile Phone says "Emergency calls only" then it is probably locked with network.
Don't worry you can it easily by using an unlock code.To get this code at low cost visit the site ClassicUnlocking.com with easy step by step unlocking instructions and unlock it.After unlocking it,you can use freely any GSM network SIM card.This is the safe,fast and permanent unlocking method.
Aug 17, 2013 | Sony Ericsson K800i Cell Phones
Sony Ericsson K800i says only emergency calls kindly help me and solve my problem
Assuming that you have a valid SIM in your phone, then the problem is most likely either a poor local cell signal or a damaged phone.
If you only get the problem locally then contact your service provider as there may be an issue with the local cell mast. If you get the same problem everywhere, then look for network options in your phone menu . It's probably going to show you that automatic network selection has been enabled, change it to manual and click on scan for available networks. Manually select your own network from the list. You might see 2G and 3G versions of your network, so choose 3G first and if no improvement try 2G instead. If all this fails then you probably have a phone with a damaged antenna or with damaged RF shielding. Either way, it then needs to go to a repair shop for correct diagnosis and repair.
Sep 21, 2010 | Sony Ericsson K800i Cellular Phone
I have k800i i dropped and now cant text and it say on front of phone emerg call only
Remove the battery and let your unit for 20 minutes . Then try to check whether it is working properly. If you still get the problem then there is damage to the phone due to internal short circuit.
You need to take to service center to get it repaired .
Hope this helps .
Thanks for using Fixya.
Shane
Dec 07, 2009 | Sony Ericsson K800i Cellular Phone
Phone topped up but can only receive or send
Have you tried different sim to see if its sim or phone related? Try your sim in different phone, is it ok? Where did your K800i come from, have you just got it? Could be restricted from networks if it was a reported lost or stolen phone? (would show as emergency calls only, or unregistered sim). Check with your network provider who have access to imei data base and can tell you if its a barred handset.
Also check if phone is in flight mode as then it would not find any network? Normally allows you to select when turned off and on again.
Does it pick up any networks? If you go into settings, then networks, does it find any when you do a manual scan of networks available?
Last explanation could be faulty handset? ;( = ££££££'s
Apr 16, 2009 | Sony Ericsson K800i Cellular Phone
SE K800i volume
Their could potentially be a problem with your Phone speaker, have you made sure you have call volume turned on/up !? when in a call, press the volume adjustment buttons on the side of the phone and a small window should pop up saying Volume. if the call volume is up but there is still a problem with your phone, i would seek professional help from either Sony ericsson or your Mobile phone Carrier
Oct 27, 2008 | Sony Ericsson K800i Cellular Phone
K800i problem
uu have to check the internal speaker . it might be in a problem
Oct 15, 2008 | Sony Ericsson K800i Cellular Phone
Sony Ericsson K800i says insert sim and only allows emergency calls
Your sim card might be loose in it's place. Or you may need to "open line" your phone.
Better solution? Purchase a new sim,not a vodafone sim. For you to know what the problem is.
A rate from you for this solution according to the benefits obtained will be much appreciated. tnx! Further questions? don't hesitate to post......good day!
Sep 16, 2008 | Sony Ericsson K800i Cellular Phone
Unable to get call log details
I'm a user of Sony Ericsson K800i, unable to get call display, ie., missed call list, dialled call list, number display etc.,
Aug 25, 2008 | Sony Ericsson K800i Cellular Phone
Sony erickson k800i
try to select the network manually if this does not work then contact you carrier.
Jun 06, 2008 | Sony Ericsson K800i Cellular Phone
K800i
you might have accidently nocked the internal antenna have you opened it mack up and checked?
Nov 04, 2007 | Sony Ericsson K800i Cellular Phone
Sony Ericsson K800i Cellular Phone Logo
101 people viewed this question
Top Sony Ericsson Cell Phones Experts
270rexton
270rexton
Are you a Sony Ericsson Cell Phone Expert? Answer questions, earn points and help others
