Question about Whirlpool Washing Machines
My whirl pool washing machine no longer spins. I just stopped on day. I can hear the motor trying to turn the drum but it doesnt.
  • 6,784 Answers
Hi. This is a possible broken belt. You will need to access the drive assembly to confirm. The symptoms you have posted will often lead to a separated belt.
NOTE(IF this is a top loader, and you are hearing noise during the spin attempt, this will lead to failed motor coupler. Please disregard this note if the unit is a front-loader)
Posted on Oct 08, 2009
How to fix, no spin on Hotpoint WDF740?
Long shot guess here but ...have you checked / replaced the carbon brushes of the electric motor ???? common problem I have had before.
If it is not the brushes then it could be segments of the motor burnt out which could be expensive.
Sep 07, 2014 | Hotpoint Washing Machines
My Bosch washing machine won't turn the bowl
Hi Justene,
i Think its control circuit has a problem.
or the fuse for motor drive circuit is damaged.
please check with electrician.
regards.
nuwan
Jan 13, 2014 | Bosch Washing Machines
Hotpoint ultima washing machine wma74 drum not turning
If the machine wasn't excessively noisy before and when you select spin only you can't hear the motor running its likely to be the carbon brushes in the motor worn down till they no longer contact stick a new set in if the carbon length sticking out the brass holder is less than around half an inch long
Dec 08, 2013 | Hotpoint Ultima WF860 Front Load Washer
Zanussi Essential 1400 ZWF14070W1
Check the belt that spins the drum for proper tension. If it has stretched you will have a hassle. Often you can loosen a belt pulley and put some extra tension on belt, restore friction and operation till belt is replaced with a nice, new tight one.
Nov 23, 2013 | Washing Machines
Whirl pool washing machine doesnt spin dry
If it wont spin at all, check the lid switch. If it will spin but not fast enough to spin the water out of the clothes, it sounds like the clutch could be slipping.
Aug 08, 2010 | Whirlpool Washing Machines
Wx46500 whirl[pool, the belt below the drum stopped causing a pile of black rubber on the floor. hoe do you change this belt? what caused the problem? Is it worth fixing
Either the belt was worn and has started to slip under load or the drum bearing has started to sieze up.
If you can turn the big wheel on the back of the drum easily it is more than likely that the belt has become slack and the motor pulley has been spinning around on it without gaining traction
Mar 30, 2010 | Washing Machines
DRUM WILL TURN TO EITHER WASH OR SPIN CLOTHES
your belt has probably fell off the back of the drum try turning the tub by hand see if you can hear the motor turning with it
Mar 31, 2009 | GE WSXH208A Front Load Washer
Washing machine won't spin
Do you hear the motor spinning loud whirring noise,when drum is not,if so drum belt has come off or snapped,if no noise possible brushes on motor need replacing
Jan 18, 2009 | Hotpoint Ultima WD72 Front Load...
Whirl pool washer bangs when in spin cycle
if new did you remove shipping strap in back..the unit cant lean more than 2 degrees..make sure clothes are even in tub..try to wash clothes alike..
Dec 25, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Whirl pool duet
Lets run a diagnostic test selecting drain/spin, on spin speed select no spin then press prewash quickly twice, watch for F error codes and write them down, press prewash again to advance past error code seen. Then post back because there are several issues here that can cause this, motor sensor errors, serial communication errors, pump and drain siphon issues.
Sep 14, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Washing Machines Logo
109 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
