Question about Medea 10 Bays VideoRaid RTRX (111473) Drive Case
Describe your Medea 10 Bays VideoRaid RTRX Drive Case Problem. Status light on the front is solid red, indicating a bad controller, controller lights on the back are green, indicating good controller. 9 out of 10 discs have solid red light on back. Computer will not recognize the drive.
  • 835 Answers
You are correct about the solid green lights on the drives means that its working and the red lights means their is an issue with that drive. I do not know exactly what you have but im under the understanding that earlier models have had issues with the flex on the drivers that have caused issues with it. Here is a link for you where you can find and download the newest flex for your device, and update it. This might fix your problem. If it doesn't then its possible that the other 9 have went bad some how, but let me post this link first then i'll give you a way to determine if the others have gone bad.
CLICK HERE FOR FLEX INFO AND DOWNLOAD
At this link their is other links and information and even a hot line # you can call to help you even futher with it.
Now again i don't know exactly what you got so this may not be possible, but power down the device. Just in case thier not hot swappable. Just simply replace the one with the green light, into one of the bays with the red light, and put the red one into the one that light up green. See if their is any changes with the lights.. If the green light moves with the swap then its just the simple fact that what is in the drive bay is bad with the red ones. If the green light just stays where it no matter what you put into that drive from the one that where red in the first place then I'd try the new flex route.
Good luck,
Posted on Oct 08, 2009
How do I program the jamo torsten sound bar to my remote control?
Great product, horrible instructions that focused on every language known to man rather than clear steps. Hope this helps....for the JAMO TORSTEN 2 WAY SOUNDBAR W/ WIRELESS 10" SUB 360 Series, as well as other Klipsch soundbars.
If the SoundBar is in STANDBY mode (solid RED status light), push the <SOURCE> button on the SoundBar until the status light is solid GREEN.
STEP ONE (Place the unit in learning mode): With the status light showing solid GREEN, press and hold the <SOURCE> and <MUTE> buttons on the front of the SoundBar at the same time (approximately 3 seconds) until the status light flashes RED and GREEN.
STEP TWO (Select the function to learn): Press the <MUTE> button once on the SoundBar (the status light changes to solid ORANGE).
STEP THREE (Learn the function): Hold your remote control within one foot and pointed at the front of the SoundBar. Slowly press the <MUTE> button on your remote control four times. On the first three presses, the status indicator light will flicker ORANGE with each press. If the unit has successfully learned the function, on the fourth press of the button, the light will flash GREEN several times and then turn to solid GREEN.
To program the remaining functions, simply repeat all steps, substituting <MUTE> with the new function and button presses (VOLUME UP, and VOLUME DOWN) on steps TWO and THREE.
Apr 28, 2014 | Jamo Torsten Soundbar with 10" Wireless...
I lost my ear piece for my Plantronics Voyager 500A so I am trying to pair a new earpiece. How do I do this?
1. On the base, press and hold both speak volume fine adjust buttons until the blue talk/on line indicator light and red power indicator light (on the front of unit) start to flash.
2. On the headset, press and hold the listen volume adjust + button and call control button until the status indicator flashes red and blue.
3. Pairing is complete when the talk/on line indicator on base illuminates solidly, and the status indicator light on headset flashes blue.
Important: Make sure your headset is not connected to any other Bluetooth device when attempting to pair.
Good luck from Headsets Direct!
Jul 13, 2011 | Plantronics Voyager 500A Deskphone Adapter...
The unit we have is the 5/600 RT3 P/N 904002-02 Turn it on it makes a regular "ticking" sound and i cannot access the drive. the desktop icon has disappeared as well as the rest avenues through...
There exist commercial "data recovery" services that can try to repair your device, just long-enough to rescue and copy your files. For example, see: https://services.seagate.com/index.aspx?lng=en-US for a "no data - no charge" guarantee.
Dec 13, 2010 | Medea VideoRaid 5160 SCSI Ultra160 Hard...
The front LED flashes red & blue when I turn it on. What does this mean?
LED Indicators - LaCie 2big Network
The LED indicators above the drive bays and the front LED indicate drive status and activity.
During Startup
  • Front LED – blinks red/blue until both disks are powered on, then turns solid blue.
  • Rear LEDs – blinks red/blue until corresponding disk is powered on, then turns solid blue.
NOTE: If the device is not able to initiate the boot process following disk startup, the front is solid red.
During Bootup
  • Front LED – solid blue
  • Rear LEDs – solid blue
NOTE: If a disk is failing, both the disk’s corresponding rear LED and the front LED will be solid red.
During RAID Synchronization
  • Front LED – solid red
  • Rear LEDs – The LED corresponding to the original disk will be blinking blue and the one being synchronized is blinking red
  • Once both disks are synchronized, their corresponding rear LED and the front LED will be solid blue.
Apr 06, 2010 | LaCie 2 TB 2big Triple Interface External...
Brother Printer HL 5250DN
A solid red STATUS light with a solid yellow TONER light indicates toner out...replace according to pg. 63 in the manual.
It can also indicate a cartridge position error. Take the DRUM UNIT out of the machine and re-install.
A solid red STATUS light only means:
Front cover open
Fuser cover open
Dust on drum
Too many trays
Buffer error
Print overrun
Memory full
Download full
Font full
See pg.48 ofthe manual.
Oct 02, 2009 | Sport & Outdoor - Others
HL-5140 Brother laser printer red status light remains on.
The red lite indicates one of the following needs to be looked at:
Cover open (Front cover) Close the front cover.
Cover open (Jam clear cover) Close the jam clear cover of the fuser unit.
Memory full - Press the go button.
Print overrun - Press the go button.
Clean drum unit - Clean the corona wire.
Jan 15, 2009 | Brother HL 5140 Laser Printer
Malfunctioning Medea RT 4/180 VideoRaid
Hi again,
Glad to be of some assistance and appreciate the rating too in your Premium Problem.
Pls update status if and when convenient.
Jan 11, 2009 | Medea VideoRaid RT
Flashing device status light
Ok the lightning bolt is your power indicator: solid green-charging, Flashing green-fully charged, flashing red-low battery, flashing red three times the once green-bad battery. the "trash can" looking one is your hard drive activity indicator it will flash while your hard drive is reading and writing.
Nov 20, 2008 | Dell Latitude D600 Notebook
Flashing "F" on front of drive slot
The front panel display contains seven (7) lights which provide the following information: ? Power-On - Steady green glow indicates that power is being supplied to the Data Silo chassis. ? Temperature Warning - Flashing red indicates that internal operating temperature has reached 43? C (109° F). ? Blower 1 or 2 Failure - Flashing red indicates a blower has failed. ? Power Supply 2 Failure - Flashing red indicates second power supply has failed. ? Power Supply 1 Failure - Flashing red indicates first power supply has failed. ? Mute - When switch is depressed, a steady yellow glow indicates the audible warning sounds have been disabled. Depress switch again to enable sounds. ? Reset - Depress switch to reset chassis and clear any error conditions. The specs on the DS550 do not say anything about an F at all? Did you put the correct model number?
Aug 29, 2007 | StorCase 9 Bays Data Silo DS550 Storage...
Medea 10 Bays VideoRaid RTRX (111473) Drive Case Logo
32 people viewed this question
Top Medea Computers & Internet Experts
David Payne
David Payne
Are you a Medea Computer and Internet Expert? Answer questions, earn points and help others
