Question about Troy Bilt Tb70ss Gas Trimmer
Troy built weedeater sounds like stuck in medium throttle when throttle is pulled wide open
    Problem Solver:
  • 14 Answers
Check and make sure the spark arrestor on the muffler isn't clogged with carbon.
Posted on Oct 08, 2009
Troy-Bilt Hand-Held Blower dies when warm and throttle wide open
You reported that most of the items I would've suggested, you have checked...
Good job.
A couple more things:
  • Replace fuel filter, it's in the gas tank
  • Check and clean the Spark Arrestor screen at muffler, when they plug up, it's a major restriction to exhaust gas flow
  • And check and adjust High/Low screws at carburetor, video attached.
  • And clean or install rebuild kit for carburetor
Good luck...
One more...
May 30, 2015 | Troy-Bilt Garden
How do I tighten the control cable on my troy built mower?
Push the throttle all the way open and either look at the carburetor to make sure it is pulling the it wide open. You might be able to pull on the wire inside the cable to make sure it is at full throttle. Then tighten the cable down and it should be in the right position.
Col. Dana Gillespie
Oct 12, 2014 | Garden
Throttle stuck wide open
what make model year????? That would help everytime
Jan 08, 2013 | Chevrolet S 10 Cars & Trucks
The governor is stuck wide open. How do you fix it?? Troybilt tiller reardrive 3 horsepower
have you gotten something stuck in the throat of the carb where the throttle butterfly opens and closes to control speed? check this,then check all moving parts on the carb and especially the governor spring that its not caught on something
Mar 31, 2010 | Troy-Bilt Pony Garden Tiller
Weedeater Head won't Turn?
I had the same problem with a Troy Bilt tb65ss. It sat in my garage for a year until I decided to tear it apart. I pulled of the head, removed the debris shield with a Phillips screwdriver, then removed the upper head assembly from the shaft. The inner flex cable is shaped like a square and had wiggled up the shaft until it was no longer engaging. I pulled it down and reassembled the upper head assembly with it engaged. It was a simple fix and took less than 10 minutes. It looks like a terrible design and a repeat problem. If it happens to me again I'll probably jb weld the flex cable in place. Good luck! You can always call the manufacturer and haggle over warranty and haul your trimmer all over town to an authorized dealer who will put it at the back of their pile because you didn't buy it from them or you can fix it in 10 minutes!
Sep 28, 2009 | Troy Bilt Tb70ss Gas Trimmer
Acts like it starving for fuel.
take a compresstion test to see if it's good.
sound like the carb needs to be rebuild but if you cant get a carb kit you have to get a new one. it happen to me one time to no kit had
get new carb.let me know how it go's ok
Jul 23, 2009 | Troy-Bilt 4-Cycle Curve Shaft Gas String...
Throttle Cable Stuck Wide Open?
you need to re coil the spring or replace it for it to pull back in to poistion
Feb 12, 2009 | 2003 Yamaha YZ 250
Weedeater or trimmer
sounds like the carb is still not right or the unit is low on compression - you need 90 lbs min
Oct 12, 2008 | Garden
Troy Bilt Tb70ss Gas Trimmer Logo
229 people viewed this question
Top Troy Garden Experts
Matt Olenzek
Matt Olenzek
Wade Mobley
Wade Mobley
Mike Squire
Are you a Troy Garden Expert? Answer questions, earn points and help others
