Question about Sanyo PLC XU35 Multimedia Projector
I cannot get it to project from my computer. I
I cannot get it to project from my computer. I think the settings were changed but I don't know how. It is model #PLC-xu48
  • 655 Answers
Try to find an oners manual on-line. Most computers you can use the F5 key or ALT F5 to switch screens to multiple.
Posted on Oct 08, 2009
I have a gateway desktop model DX4850 and I am trying to find the driver necessary for it to allow it to receive an internet connection from a smartphone via usb tethering or Bluetooth connection. I...
I don't think your computer has bluetooth, in which case you'll need to use the usb cable. I don't what type of phone you have but your phone should have come with a software. This software should have a feature allowing you to connect your pc to the internet via your phone. Simply change the software internet settings to match the web settings on your phone.... if necessary. There is, however, a more complicated method, if the software doesn't work, then i'll try to explain that method.
Jul 15, 2012 | Cell Phones
I have an acer al1716 monitor and since 2 weeks ago on the screen apears a box with the " input not suppported" message, then the pc shuts down. i may have changed the resolution settings and now...
the video settings on your computer has changed to a setting that the monitor doesn't like! try entering your computer in safe mod and change the setting to a max of 1024x768. however, if your video card has a dual output and you have 2 monitors connected at the same time then this is your problem. make sure that the 17" lcd is monitor 1 and the other monitor #2. one of the monitors is set higher the the 17" lcd and when it is not connected the computer may think this the setting for the 17" lcd and not the other monitor which may be hdmi or 1900x1080 which the 17" cannot read this it is out of range!
Aug 24, 2011 | Acer AL1716 17" LCD Monitor
I just bought a top-end MacBook Air 13.3" 4 GB/256 GB for presentations. I also have a Dell M410HD projector, also quite new (a few months old), which works great with the two PCs (one new, one old)...
They (Apple) might be right. It could be that the projector is damaged, like the bulb, or it could be incompatible with your computer, but I don't think that is the case. Try taking the projector to a computer repair place.
May 17, 2011 | Apple MacBook Pro Notebook
I have a panasonic 52"
The tv projection lamp timer must be reset,read ur ower manual how to do that or call panasonic customers service for the help with the prosedure,sorry i don't remember how to do it anymore.The problems with the HDMI 2 setting all the time.Tries tv unplug,replug the tv back about an hour later for the tv to do a resetting itself back to the factory setting.Than go into the tv Menu changes to all the manually setting and turn off all of the auto functions of the HDMI hubs setting should solved this problems.
May 09, 2011 | Panasonic PT-52DL10 52" Rear Projection...
I want to set up my router,but I don`t know the steps
Are you trying to set up the router.
You can do it manually without the CD.
Make sure that your computer is able to go online through the modem.
If your computer is not able to go online through the modem then you will need to call ISP first.
If your computer is able to go online through the modem
then you need to connect the computer to the router and the modem to the router.
open the set up page of the router and change the settings of the router according to the ISP.
Click Here for step by step by instructions
Apr 02, 2010 | Computers & Internet
Jvc 56dlp connect computer
If you are getting an invalid input its because the resolution setting on your computer is probably set too high. The JVC only accepts 2 resolutions one is like 600x400 and the other is 1280x768. I had this problem all the time with vista. It can't seem to remember what resolution to use. The exact setting are also listed in owners manual.
Apr 08, 2009 | JVC HD-52G786 52" Rear Projection HDTV
Dodge neon 1998 2end cylinder miss fire
if this car has coil on plug set up i would change the coil itself.
Jan 29, 2009 | 2004 Dodge Neon
Direct TV Hookup
please help my remote has change language and jumping chanel and pause on mute
Sep 03, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
Reversing the picture on the monitor
Here is the manual:
ScreenPlay 4805 ScreenPlay 4805
Check page 38 on picture settings, you can revers the image to project from behind a screen (mirror), I don' think you can have picture upside down (180 rotation) using projector settings. You need to reverse image source (eg. picture on computer).
Apr 24, 2008 | InFocus ScreenPlay 4805 Multimedia...
Computer
you will have to do some steps to fix this up
if you have a desktop system...
1. open your system...replug the hard drive connections.
2. you can see the battery on the motherboard...reseat it
3. rest your bios to factory defaults
4 after that initiate the format
plz specify the system model you have..it will help me in gioving you a better solution
Feb 07, 2008 | Computers & Internet
Sanyo PLC XU35 Multimedia Projector Logo
114 people viewed this question
Top Sanyo Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Sanyo Office Equipment and Supply Expert? Answer questions, earn points and help others
