Question about Dryers
Dryer not drying and also get hot cut it self off
  • jamesever329 Oct 08, 2009
    yes vent is clean and strong air flow comes out
  • 636 Answers
Have you checked that vent is clean and clear of obstructions?
Posted on Oct 08, 2009
It doesnt seem to dry very well or takes a really long time
Zannusi Dryer TDS383W element gets Hot (glows)then cuts out after few seconds then if I wait for couple minutes and reset the clock to any set time the element glows hot again until inbuilt thermostats 'click' again cutting out the element,this process is continuous with or without the lid and ducting in place.
Feb 14, 2014 | Zanussi TD4112W Electric Dryer
I ahve a duet gas dryer and it will not get hot
Now did this happen all at once or did it slowly dry clothes slower and slower and then just quit? If it happened slowlt it is because you have some sort of ventalation blockage withing the dryer itself or in the wall of your home. When this happens it will the blow the thermal cut off and this will need to be replaced. If it happened over night then it could be the heating element or the thermal cut off & thermostat. All these can be checked with a volt meter using the setting for continuity.
Mar 26, 2010 | Whirlpool Duet 7.0 Cu. Ft. 7-Cycle Super...
My dryer takes hours to dry one load of clothes. Cleaned all lint from it. It's warm, not hot. Flame is on.
you need to either dismantle the venting pipe ductwork inside the dryer and get inside the duct and loosen all dried on lint which is holding moisture in,otherwise the cycling switch for the flame is cutting out tooooo sooooon and your not drying the load properly per selected load setting
Mar 14, 2010 | Maytag Neptune MDG9700A Gas Dryer
The dryer is not drying the clothes. It takes two
Take you vent off and remove the restrictions. How about a few repair pix?
Sep 25, 2009 | GE Profile Prodigy DPSR513GA Dryer
Whirlpool dryer model LER7646EQ1
Thats what it's supposed to do hopefully the clothes are coming out dry. The dryer has both thermal sesors and fuses that tell the dryer when to heat up and when to cool down. So yes the heating element will come on and go off multiple times in a cycle.
Mar 31, 2009 | Whirlpool LER4634J Electric Dryer
Whirlpool electric dryer, Model LEC6646ANO. On
Make sure the internal and external exhaust vents are not blocked with lint.
Will it complete a 45 minute time dry and dry the laundry?
Mar 09, 2009 | Whirlpool Dryers
Kenmore dryer will not come on at all
Hi thanks for the question. at the back . remove the panel. on the heater on right at the top. small disc . this is a hi limit cut off. check this part if failed replace. also clean all venting. as this could cause the hi limit thermo to fail . thanks the appliance doc
Oct 06, 2008 | Dryers
Keeps on cutting out on Hot drying cycle
this will be a problem with your thermostats 1 of them will have a thermal cut-out switch built onto it this thermostat needs replacing it is faulty
Dec 07, 2006 | Zanussi TC7114W Electric Dryer
Dryers Logo
Top Dryers Experts
Dan Webster
Dan Webster
